Hi, I need to push a phisical button with HASS, so I connected a GPIO of a Nodemcu with a 10KOhm to soldered to the board of the button, and it works fine with an Arduino code (I can post it if needed). Now wish to bring all my ESP in the house under ESPHOME umbrella, bnut in this case my code is not working.
Need some help please. I have to recreate a simple button press and a double button press. The single button press will close a lock, the double press will opoen a lock.
The below code works for the single press, but not the double press. What am I doing wrong?
Hi! Could you please share the connection physical layout? I would like to control a light either with nodemcu or a physical button using a relay connected to nodemcu.
