ESPHome - how do I use the OR condition here?
Hi y’all,
I have this code:
  - platform: seeed_mr24hpc1
    custom_spatial_static_value:
      on_value:
        if:
          condition:
            sensor.in_range:
              above: 20.0
          then:
            - script.execute: toggle_a0_with_cooldown
    custom_spatial_motion_value:
I’m trying to execute the script, “toggle_a0_with_cooldown”, when either Existence energy (id: eval) is above 20 or Motion energy (id: mval) is above 5. I’m not sure how to type the syntax for this. Here’s my attempt :
      on_value:
        if:
          condition:
            sensor.in_range:
              above: 20.0
              or:
                -sensor.in_range:
                  above: 5
          then:
That def. doesn’t look right. Thanks a lot for your help.
The or should be below the condition key, with the two sensor conditions nest under it.
ESPHome - Automations - Conditions
You can also just do this:
          - if:
              any:
                - sensor.in_range:
                    above: 20.0
                - sensor.in_range:
                    above: 5
              then:
Thanks - both solutions work.
One final, sort of similar syntax related question (I can create another topic on this if it’s out of this thread’s scope)
I have this code where I’m trying to execute the script toggle_a1_with_cooldown using the “for” condition when Motion energy (id: mval) crosses and goes below 5 and stays below 5 for 30 consecutive seconds.
      on_value_range:
        if:
          condition:
            for:
              time: 30sec
              condition:
                below: 5
          then:
            - script.execute: toggle_a1_with_cooldown
Esphome gives me an error that says “Unable to find condition with the name ‘below’.”
A regular google search isn’t giving me many examples where I’m able to see the for condition in action, which is so frustrating. And I’m not able to figure this out even using esphome docs.
Thanks again very much for the help.
Clyde may know a way… but I don’t think you can do it directly like that.
The only thing that comes to mind for me would be to set up a template binary sensor with delayed_on set for your desired duration.
Analog Threshold Binary Sensor — ESPHome combined with a delayed_on filter will do it.
Works! I also had to add the invert: filter
Thank you!
