janbenes
(Jan Benes)
April 9, 2021, 8:10pm
1
Hello all. I have been struggling how to combine filters to take 10 measurements and return average.
The problem is that I use low power sensor and I do not want to take more than 10 measurements in order to save chip power. All methods I tried take measurements all time the esphome is awake and then can return average of last 10 (like moving average). I would like the sensor take exactly 10 measurements (0.1s apart), calculate average and then return exactly 1 result and go back to sleep. Is that actually possible?
It should be possible using these components. Did you try the filter component of the sensors like this.
filters:
- sliding_window_moving_average:
window_size: 10
send_every: 10
send_first_at: 10
- throttle: 10s
Also you might have already put the update interval as 100ms and in deep sleep settings run as 12s
janbenes
(Jan Benes)
April 10, 2021, 8:52am
3
Thank you but this seems it is not working. Your script is simply taking measurements all time until deep sleep, so more than 10. The config is here:
platform: adc
pin: 36
update_interval: 100ms
filters:
window_size: 10
send_every: 10
send_first_at: 10
- throttle: 10s
deep_sleep:
run_duration: 3s #4s
sleep_duration: 20s #15s # 3806s
and the log output is here:
INFO Starting log output from /dev/ttyUSB0 with baud rate 115200
[10:45:46][D][adc:056]: 'Vcc Average': Got voltage=1.10V
[10:45:46][I][mqtt:202]: MQTT Connected!
[10:45:46][C][deep_sleep:013]: Setting up Deep Sleep...
[10:45:46][I][app:059]: setup() finished successfully!
[10:45:46][I][app:105]: ESPHome version 1.16.2 compiled on Apr 10 2021, 10:36:53
[10:45:46][C][wifi:443]: WiFi:
[10:45:46][C][wifi:303]: SSID: 'IoT'
[10:45:46][C][wifi:304]: IP Address: 10.0.0.254
[10:45:46][C][wifi:306]: BSSID: EC:AD:E0:D2:FC:DB
[10:45:46][C][wifi:307]: Hostname: 'average_test'
[10:45:46][C][wifi:311]: Signal strength: -28 dB ▂▄▆█
[10:45:46][C][wifi:315]: Channel: 3
[10:45:46][C][wifi:316]: Subnet: 255.255.255.0
[10:45:46][C][wifi:317]: Gateway: 10.0.0.138
[10:45:46][C][wifi:318]: DNS1: 8.8.8.8
[10:45:47][C][wifi:319]: DNS2: 8.8.4.4
[10:45:47][C][logger:185]: Logger:
[10:45:47][C][logger:186]: Level: DEBUG
[10:45:47][C][logger:187]: Log Baud Rate: 115200
[10:45:47][C][logger:188]: Hardware UART: UART0
[10:45:47][D][adc:056]: 'Vcc Average': Got voltage=1.10V
[10:45:47][C][adc:026]: ADC Sensor 'Vcc Average'
[10:45:47][C][adc:026]: Unit of Measurement: 'V'
[10:45:47][C][adc:026]: Accuracy Decimals: 2
[10:45:47][C][adc:026]: Icon: 'mdi:flash'
[10:45:47][C][adc:035]: Pin: 36
[10:45:47][C][adc:038]: Attenuation: 0db (max 1.1V)
[10:45:47][C][adc:051]: Update Interval: 0.1s
[10:45:47][C][ota:029]: Over-The-Air Updates:
[10:45:47][C][ota:030]: Address: 10.0.0.254:3232
[10:45:47][C][mqtt:051]: MQTT:
[10:45:47][C][mqtt:053]: Server Address: 10.0.0.54:1883 (10.0.0.54)
[10:45:47][C][mqtt:054]: Username: 'janb'
[10:45:47][C][mqtt:055]: Client ID: 'average_test-10521c6d44e4'
[10:45:47][C][mqtt:057]: Discovery prefix: 'homeassistant'
[10:45:47][C][mqtt:058]: Discovery retain: YES
[10:45:47][C][mqtt:060]: Topic Prefix: 'average_test'
[10:45:47][C][mqtt:062]: Log Topic: 'average_test/debug'
[10:45:47][C][mqtt:065]: Availability: 'mqtt_avg_test/status'
[10:45:47][C][mqtt:551]: MQTT Message Trigger:
[10:45:47][C][mqtt:552]: Topic: 'mqtt_avg_test/ota_mode'
[10:45:47][C][mqtt:553]: QoS: 0
[10:45:47][C][mqtt:552]: Topic: 'mqtt_avg_test/sleep_mode'
[10:45:47][C][mqtt.sensor:024]: MQTT Sensor 'Vcc Average':
[10:45:47][C][mqtt.sensor:028]: State Topic: 'average_test/sensor/vcc_average/state'
[10:45:47][C][deep_sleep:020]: Setting up Deep Sleep...
[10:45:47][C][deep_sleep:023]: Sleep Duration: 20000 ms
[10:45:47][C][deep_sleep:026]: Run Duration: 3000 ms
[10:45:48][D][adc:056]: 'Vcc Average': Got voltage=1.10V
[10:45:49][D][adc:056]: 'Vcc Average': Got voltage=1.10V
[10:45:49][I][deep_sleep:067]: Beginning Deep Sleep
So it is reading all time. I would prefer to take just 10 readings and then send average.
janbenes
(Jan Benes)
April 10, 2021, 9:55am
4
I solved it with this:
globals:
- id: bc2
type: long int
restore_value: yes
initial_value: "0"
- id: a_input
restore_value: no
type: float
initial_value: "0.0"
- id: i
type: long int
restore_value: no
initial_value: "0"
on_loop:
lambda: |-
id(i)++;
if (id(i) <= 10) {
id(vcc).update();
float vcc_now = id(vcc).state;
id(a_input) = id(a_input) + vcc_now/10;
delay(100);
if (id(i) == 10) {
id(vcc_average).update();
- platform: adc
pin: 36
internal: true
update_interval: 10s
lambda:
if (id(i) > 1) {
ESP_LOGD("main", "################################## Returns value");
return id(a_input);
else {
ESP_LOGD("main", "################################## Returns NAN");
return NAN;
working well.
