Esphome in home assistant 4ch relay problem
hi. I m Nurettin. I’m having a problem like in the video. please help :worried:
my esphome code:
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: “*"
password: "
logger:
api:
ota:
switch:
  • platform: gpio
    pin: D8
    inverted: yes
  • platform: gpio
    pin: D5
    inverted: yes
  • platform: gpio
    pin: D6
    inverted: yes
  • platform: gpio
    pin: D7
    inverted: yes
relay input voltage: +5v
nodemcu input voltage: +5v
This problem occurs if I turn on all 4 relays
problem youtube videolink: https://www.youtube.com/watch?v=8Y5Eu-sZBP4
Kind of hard to tell from the video (plus I’m not familiar with the module you use). Are you powering all 4 relay coils directly from the esp regulator? Does that relay breakout have optoisolators? If yes and no, that may be your problem. Try measuring your esp 3v3 bus when you have all 4 relays on… does it drop volts? If so, the problem is likely an overloaded regulator. The fix might be to either wire in separate power, or use a relay board with optoisolators (I prefer to do both anytime I’m switching inductive loads from io pins).
thanks.
my part list:
