I am trying to get the light to come on at boot so that there is some indication that it is powered up
Can anyone see what I am missing?
I can select the effects or turn the led on through the web portal no problem
|20:36:34|[D]|[light:036]|‘Built-in RGB LED’ Setting:|
|20:36:34|[D]|[light:047]|State: ON|
|20:36:34|[D]|[light:085]|Transition length: 1.0s|
Am I looking in the right direction?
My esphome1.yaml looks like this
esphome:
esp32:
board: esp32-c6-devkitc-1
flash_size: 8MB
framework:
type: esp-idf
# Enable logging
logger:
level: DEBUG
light:
- platform: esp32_rmt_led_strip # https://esphome.io/components/light/esp32_rmt_led_strip
pin: GPIO8
num_leds: 1
rmt_channel: 0
chipset: WS2812
rgb_order: GRB
name: "Built-in RGB LED"
initial_state:
state: true
color_mode: RGB
brightness: 55%
red: 100%
blue: 100%
green: 0%
effects:
- random:
- strobe:
- flicker:
- addressable_rainbow:
captive_portal:
# Enable Web Server for easy debugging (optional)
web_server:
port: 80
Hellis81
(Hellis81)
February 3, 2025, 10:26am
2
I have never tried initial state on a light.
But you could do a on boot turn on.
esphome:
on_boot:
priority: 601
then:
- light.turn_on:
Like this?
The yaml seems invalid
esphome:
esp32:
flash_size: 8MB
framework:
type: esp-idf
# Enable logging
logger:
level: DEBUG
light:
pin: GPIO8
num_leds: 1
rmt_channel: 0
chipset: WS2812
rgb_order: GRB
on_boot:
priority: 601
then:
- light.turn_on:
initial_state:
#state: true
#color_mode: RGB
brightness: 55%
red: 100%
blue: 100%
green: 0%
effects:
- random:
- strobe:
- flicker:
Gives this when I Validate
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome1.yaml...
ERROR Error while reading config: Invalid YAML syntax:
while parsing a block collection
in "/config/esphome1.yaml", line 15, column 3
expected <block end>, but found '?'
in "/config/esphome1.yaml", line 22, column 3
Hellis81
(Hellis81)
February 3, 2025, 10:42am
4
No…
like this:
esphome:
on_boot:
priority: 601
then:
- light.turn_on:
brightness: 55%
red: 100%
blue: 100%
green: 0%
esp32:
flash_size: 8MB
framework:
type: esp-idf
# Enable logging
logger:
level: DEBUG
light:
pin: GPIO8
num_leds: 1
rmt_channel: 0
chipset: WS2812
rgb_order: GRB
effects:
- random:
- strobe:
- flicker:
I’m not exactly sure about the syntax to turn on the light but perhaps the color_mode is needed. But I don’t think so
Hmm. That seems to create a new light, I get:
ID 'light' conflicts with the name of an esphome integration, please use another ID name.
Which is why I thought it should be after light is loaded
Hellis81
(Hellis81)
February 3, 2025, 11:04am
6
Then just change the id. It has to have some id so that it knows what light to turn on
esphome:
on_boot:
priority: 601
then:
- light.turn_on:
brightness: 55%
red: 100%
blue: 100%
green: 0%
esp32:
flash_size: 8MB
framework:
type: esp-idf
# Enable logging
logger:
level: DEBUG
light:
pin: GPIO8
num_leds: 1
rmt_channel: 0
chipset: WS2812
rgb_order: GRB
effects:
- random:
- strobe:
- flicker:
Couldn't find ID 'very_long_id_that_is_probably_not_used'. Please check you have defined an ID with that name in your configuration.
I might have to have it in the light that I know works with all the defined platform, pin, chipset and such
This board does not have a status led unfortunately.
Hellis81
(Hellis81)
February 3, 2025, 11:15am
8
Did you change it on both places?
oops, I missed the id line in the light.
Config valid!
Bingo!
Thank you so much!
