ESPHome install failed - 404 Client Error
after a fresh install of HassOS 4.15 on my RP3 I was trying to add ESPHome through supervisor but I get a 404 client error, here’s the log:
20-11-07 15:41:36 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image esphome/esphome-hassio-armv7 with tag 1.15.3.
20-11-07 15:43:33 ERROR (SyncWorker_3) [supervisor.docker.interface] Can’t install esphome/esphome-hassio-armv7:1.15.3 -> 404 Client Error: Not Found (“no such image: esphome/esphome-hassio-armv7:1.15.3: No such image: esphome/esphome-hassio-armv7:1.15.3”).
20-11-07 15:43:33 INFO (SyncWorker_3) [supervisor.docker.interface] This error is often caused by not having enough disk space available. Available space in /data is: 52.0 GiB
I can’t figure out what’s the problem, could someone help me?
Did you ever get this figured out? I’m having the same issue.
Hi Patrick,
unfortunately nope, I ended up installing an older version of HassOS on the RP3. Such a pity :frowning:
