ESPHome Installing Yaml File Error
Hello everyone , I just started to work Esp8266 with HomeAssistant. Firstly I use Casaos on my Ubuntu server , HomeAssistant runs on docker.
I installed ESP Home device builder app on casaos created device and configured WiFi. Now I can see and connect my esp 8266 on 192.168.1.109 but when I tried to install yaml file over usb ttl port on server I’m getting an error as below; Could you please help me on this issue ?
WARNING Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NameResolutionError(“<urllib3.connection.HTTPSConnection object at 0x7f8cf8699160>: Failed to resolve ‘api.registry.nm1.platformio.org’ ([Errno -3] Temporary failure in name resolution)”)’: /v3/packages/platformio/platform/espressif8266
