Compiling .pioenvs/konnected-870515/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/konnected-870515/src/esphome/components/sensor/filter.cpp.o
src/esphome/components/mdns/mdns_component.cpp: In member function ‘void esphome::mdns::MDNSComponent::compile_records_()’:
src/esphome/components/mdns/mdns_component.cpp:65:50: error: ‘using element_type = class esphome::api::APINoiseContext’ {aka ‘class esphome::api::APINoiseContext’} has no member named ‘has_psk’
65 | if (api::global_api_server->get_noise_ctx()->has_psk()) {
Compiling .pioenvs/konnected-870515/src/esphome/components/sensor/sensor.cpp.o
*** [.pioenvs/konnected-870515/src/esphome/components/mdns/mdns_component.cpp.o] Error 1
========================== [FAILED] Took 7.57 seconds ==========================
====== [ERROR] /config/esphome/konnected-870515.yaml ======
*** [.pioenvs/konnected-9baeac/src/esphome/components/mdns/mdns_component.cpp.o] Error 1
========================== [FAILED] Took 5.75 seconds ==========================
====== [ERROR] /config/esphome/konnected-9baeac.yaml ======
======================== [SUMMARY] ========================
- /config/esphome/konnected-870515.yaml: FAILED
- /config/esphome/konnected-9baeac.yaml: FAILED
