Esphome & LED Strip LPD8805 & retained settings after power loss
As the title says, i have tried mqtt and also native api and trying to ensure that if my esp board loses power then the led strip maintains the same “on” and “colour” value as previously set.
Can esphome “read” the values in HA and set it to the current value if so how?
This is my device config:
esphomeyaml:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: 'MYWIFI'
  password: 'MYCODE'
# Example configuration entry
mqtt:
  broker: 192.168.1.101
  username: mqttuser
  password: mqttpassword
# Enable logging
logger:
# Enable Home Assistant API
#api:
ota:
light:
  - platform: fastled_spi
    chipset: LPD8806
    data_pin: GPIO12
    clock_pin: GPIO14
    num_leds: 94
    rgb_order: BRG
Mark
