ESPHome light state remember and brightness range
Hi, I want to ask how to make my ESP8266 remember its last state after rebooting, my ESP32 with the same code after reboot remembers the last state and the brightness of monochromatic is the same.
Also, I would like to ask how to make the light turn on and set on some brightness I would set for monochromatic light or set some brightness range. I got working restore_mode but I can’t let my lights run on 100% like it sets when turning on by rebooting :confused:
output:
  - platform: esp8266_pwm
    pin: D1
    frequency: 1000 Hz
light:
  - platform: monochromatic
    output: pwm_output
  - platform: fastled_clockless
    chipset: WS2812
    pin: GPIO12
    num_leds: 80
    rgb_order: RGB
    name: "FastLED WS2811 Light"
check the “esp8266_restore_from_flash” under the below link
just read it well and be aware of the limited number of write cycles
I tried that before, but it makes a really weird effect. when I change the brightness or color of my WS2812 everything flickers like crazy for a second, It is really weird.
And the state of WS2812 does not recover.
esphome:
platform: ESP8266
board: nodemcuv2
esp8266_restore_from_flash: true
wifi:
ssid:
password:
output:
  pin: D1
  frequency: 1000 Hz
light:
  output: pwm_output
  chipset: WS2812
  pin: GPIO12
  num_leds: 80
  rgb_order: RGB
it works perfectly with me, i am attaching my configuration it may help you, i am not actually using fastled i am using neopixel instead
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  manual_ip:
    static_ip: x.x.x.x
    gateway: x.x.x.x
    subnet: x.x.x.x
    dns1: x.x.x.x
  networks:
  - password:
    ssid:
  use_address: x.x.x.x
logger:
  baud_rate: 115200
  hardware_uart: UART0
  tx_buffer_size: 512
api:
  password: ''
  port: 6053
ota:
  safe_mode: true
light:
- platform: neopixelbus
  type: GRB
  pin: 3
  num_leds: 51
  gamma_correct: 1.0
  method: ESP8266_DMA
  variant: 800KBPS
  restore_mode: RESTORE_DEFAULT_ON
Oh, so I changed my code to yours
esphome:
  platform: ESP8266
  board: nodemcuv2
light:
  type: RGB
  pin: 3
  num_leds: 80
  gamma_correct: 1.0
  method: ESP8266_DMA
  variant: 800KBPS
And it does not restore the WS2811. weird
