ESPHome Log viewer not showing anything
Since I upgrade HA to 2023.6.3, ESPHome integration is showing a blank screen when I am trying to view the logs of my integration. Not errors in HA Core or ESPHome logs except for this warning: WARNING 403 GET /run (0.0.0.0).
Anyone can help here?
Hi Mario,
I am experiencing the same :-(. Have you figured out a solution?
No solution yet. Was hoping someone one in the community would help.
Do you run NGINX SSL proxy in front of your HA instance by any chance ? I just noticed that I can see the logs just fine if I connect to HA directly (over HTTP) vs through NGINX. Not sure if that’s just a coincidence.
Hi, yes I noticed the same thing. Cannot see the logs through Nginx but no issues when connected directly through http.
