ESPHome M5Stack CoreS3 and LAN PoE W5500
Hi There,
I tried to get the M5Stack CoreS3 (K128) to work with the M2Stack LAN PoE Base V12 (V012-C-V12).
I got the ethernet working, but in that case i can’t get the display work.
Both need the SPI.
My actual code:
esphome:
  friendly_name: x
  libraries:
    - m5stack/M5GFX@^0.1.11
    - m5stack/M5Unified@^0.1.11
esp32:
  board: esp32-s3-devkitc-1
  flash_size: 16MB
  variant: esp32s3
  framework:
    type: arduino
# Enable logging
logger:
  level: VERY_VERBOSE
# Enable Home Assistant API
api:
  encryption:
    key: x
ota:
  - platform: esphome
    password: "x"
ethernet:
  type: W5500
  mosi_pin: GPIO37 #GPIO38
  miso_pin: GPIO35 #GPIO39
  clk_pin: GPIO36 #GPIO40
  cs_pin: GPIO9 #GPIO41
  reset_pin: GPIO7
  interrupt_pin: GPIO14 #GPIO34
  clock_speed: 15MHz
  manual_ip:
    static_ip: 192.168.x.x
    gateway: 192.168.x.x
    subnet: 255.255.x.x
psram:
  mode: octal
  speed: 80MHz
display:
  - platform: m5cores3_display
    model: ILI9342
    dc_pin: GPIO35
    update_interval: never
    allow_other_uses: true
The problem that I have ist that both (Display and Ethernet) use SPI.
But in the note of ethernet component it sayes:
SPI based chips do not use SPI Bus. This means that SPI pins can’t be shared with other devices.
What can i do?
Best regards,
Adrian
