Hi
i want to display the time on my Display when both sensors are below a certain value. if one of the sensors reaches this value or goes higher i would like to display both sensors every 2 seconds the shown sensor should change. but only the time is shown
substitutions:
device_name: max7219_2
device_description: Display für Temperatur
friendly_name: max7219_2
esphome:
comment: ${device_description}
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
fast_connect: on #we only have one WiFi AP so just use the first one that matches
ap: #since we listed an SSID above, this AP mode will only enable if no WiFi connection could be made
ssid: ${friendly_name}_AP
password: traktor10
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
- platform: homeassistant
entity_id: sensor.bme280_temperature
internal: true
entity_id: sensor.gd_gewachshaus_temperature
internal: true
text_sensor:
name: "Weather Forecast From Home Assistant"
entity_id: input_text.max7219
- platform: wifi_info
ip_address:
name: ESP IP Address
ssid:
name: ESP Connected SSID
time:
font:
- file: "pixelmix.ttf"
globals:
- id: my_global_bool
type: bool
restore_value: no
initial_value: 'true'
spi:
clk_pin: D5
mosi_pin: D7
display:
- platform: max7219digit
cs_pin: D8
num_chips: 12
intensity: 9
lambda: |-
if ((id(ofen_temp1) or id(ofen_temp2)) < 10) {
it.strftime(0, 4, id(digit_font), TextAlign::CENTER_LEFT, "%H:%M:%S", id(hass_time).now());
else if ((id(my_global_bool)) and (id(ofen_temp1) or id(ofen_temp2)) > 10) {
it.printf(0, 4, id(digit_font), TextAlign::CENTER, "Temp-O: %.1f°C", (id(ofen_temp1).state));
else {
it.printf(0, 4, id(digit_font), TextAlign::CENTER_LEFT, "Temp-U: %.1f°C", (id(ofen_temp2).state));
# For example cycle through pages on a timer
interval:
- interval: 2s
then:
- lambda: |-
if (id(my_global_bool)) {
id(my_global_bool) = false;
else {
id(my_global_bool) = true;
#display:
# - platform: max7219digit
# cs_pin: D8
# num_chips: 12
# intensity: 9
# lambda: |-
# it.printf(0, 4, id(digit_font), TextAlign::CENTER_LEFT, "%s", id(max7219).state.c_str() );
# it.scroll(true,1,100,1000,1000);
