I am trying to synchronize my Mitsubishi air conditioner remote control with Home Assistant using ESPHome IR.
The air conditioner is:
- Model: MSZ-GE4017S
- Remote controller: NH151 (marked 726BL)
This air conditioner does not have a CN105 connector, and it cannot be connected to Wi-Fi, so I am trying to control and synchronize it through the IR remote signal.
Hardware:
- Wemos D1 mini (ESP8266)
- IR receiver: GPIO14
- IR transmitter: GPIO4
Software:
- ESPHome 2026.6.1
Problem:
IR reception works correctly.
ESPHome can decode the target temperature from the remote signal, but the operating mode is not decoded correctly.
Results:
- OFF → recognized correctly
- FAN_ONLY → recognized correctly
- COOL → detected as OFF
- HEAT → detected as OFF
- DRY → detected as OFF
Example:
COOL 27°C:
Mode: OFF
Target Temperature: 27.00°C
HEAT 20°C:
Mode: OFF
Target Temperature: 20.00°C
The raw IR signals are received completely with dump: raw.
Configuration:
remote_receiver:
pin:
number: GPIO14
inverted: true
mode:
input: true
pullup: true
dump:
- raw
climate:
- platform: mitsubishi
transmitter_id: ir_transmitter
receiver_id: ir_receiver
I captured raw signals for:
- COOL 27°C
- COOL 28°C
- HEAT 20°C
- DRY
- FAN_ONLY
- OFF
Could someone help identify why the Mitsubishi climate component can decode temperature but not COOL/HEAT mode?
Raw captures:
Summary
INFO ESPHome 2026.6.1
INFO Loaded validated config cache for shinshitsumitsubishiac.yaml, skipping validation.
INFO Starting log output from 192.168.1.34 using esphome API
INFO Successfully resolved shinshitsumitsubishiac @ 192.168.1.34 in 0.000s
INFO Successfully connected to shinshitsumitsubishiac @ 192.168.1.34 in 0.073s
INFO Successful handshake with shinshitsumitsubishiac @ 192.168.1.34 in 2.327s
[21:38:30.221][I][app:151]: ESPHome version 2026.6.1 compiled on 2026-07-26 00:18:53 +0900
[21:38:30.221][C][logger:223]: Logger:
[21:38:30.221][C][logger:223]: Max Level: DEBUG
[21:38:30.221][C][logger:223]: Initial Level: DEBUG
[21:38:30.221][C][logger:230]: Log Baud Rate: 115200
[21:38:30.221][C][logger:230]: Hardware UART: UART0
[21:38:30.298][C][climate_ir:092]: IR Climate '寝室のエアコン'
[21:38:30.299][C][climate_ir:093]: Min. Temperature: 16.0°C
[21:38:30.299][C][climate_ir:093]: Max. Temperature: 31.0°C
[21:38:30.299][C][climate_ir:093]: Supports HEAT: YES
[21:38:30.299][C][climate_ir:093]: Supports COOL: YES
[21:38:30.299][C][remote_receiver:079]: Remote Receiver:
[21:38:30.299][C][remote_receiver:079]: Buffer Size: 2000
[21:38:30.299][C][remote_receiver:079]: Tolerance: 35%
[21:38:30.299][C][remote_receiver:079]: Filter out pulses shorter than: 50 us
[21:38:30.299][C][remote_receiver:079]: Signal is done after 100000 us of no changes
[21:38:30.299][C][remote_receiver:152]: Pin: GPIO14
[21:38:30.299][C][remote_transmitter:017]: Remote Transmitter:
[21:38:30.299][C][remote_transmitter:017]: Carrier Duty: 50%
[21:38:30.299][C][remote_transmitter:152]: Pin: GPIO4
[21:38:30.299][C][captive_portal:133]: Captive Portal:
[21:38:30.299][C][wifi:1531]: WiFi:
[21:38:30.299][C][wifi:1531]: Local MAC: 80:7D:3A:45:29:14
[21:38:30.299][C][wifi:1531]: Connected: YES
[21:38:30.300][C][wifi:1237]: IP Address: 192.168.1.34
[21:38:30.333][C][wifi:1248]: SSID: 'dd-wrt'
[21:38:30.333][C][wifi:1248]: BSSID: 38:97:A4:16:89:98
[21:38:30.333][C][wifi:1248]: Hostname: 'shinshitsumitsubishiac'
[21:38:30.333][C][wifi:1248]: Signal strength: -63 dB ▂▄▆█
[21:38:30.333][C][wifi:1248]: Channel: 6
[21:38:30.333][C][wifi:1248]: Subnet: 255.255.255.0
[21:38:30.333][C][wifi:1248]: Gateway: 192.168.1.1
[21:38:30.333][C][wifi:1248]: DNS1: 192.168.1.1
[21:38:30.333][C][wifi:1248]: DNS2: 0.0.0.0
[21:38:30.334][C][esphome.ota:097]: Over-The-Air updates:
[21:38:30.334][C][esphome.ota:097]: Address: shinshitsumitsubishiac.local:8266
[21:38:30.334][C][esphome.ota:097]: Version: 2
[21:38:30.334][C][safe_mode:058]: Safe Mode:
[21:38:30.334][C][safe_mode:058]: Successful after: 60s
[21:38:30.334][C][safe_mode:058]: Invoke after: 10 attempts
[21:38:30.334][C][safe_mode:058]: Duration: 300s
[21:38:30.417][C][web_server.ota:256]: Web Server OTA
[21:38:30.417][C][api:243]: Server:
[21:38:30.417][C][api:243]: Address: shinshitsumitsubishiac.local:6053
[21:38:30.417][C][api:243]: Listen backlog: 1
[21:38:30.417][C][api:243]: Max connections: 4
[21:38:30.417][C][api:250]: Noise encryption: YES
[21:38:30.418][C][mdns:230]: mDNS:
[21:38:30.418][C][mdns:230]: Hostname: shinshitsumitsubishiac
[21:38:37.102][I][remote.raw:026]: Received Raw: 3402, -1727, 407, -1293, 408, -1294, 407, -442, 409, -442, 410, -441, 408, -1292, 409, -442, 408, -442, 409, -1292, 408, -1293, 408, -442, 408, -1292, 409, -443, 409, -441, 409, -1292, 408, -1293, 408, -442, 409, -1292, 409, -1292, 409,
[21:38:37.102][I][remote.raw:026]: -441, 409, -441, 409, -1292, 410, -440, 409, -442, 409, -1291, 410, -440, 437, -414, 438, -412, 439, -411, 439, -411, 466, -385, 465, -385, 465, -385, 466, -385, 465, -385, 465, -386, 464, -386, 464, -387, 462, -388, 462, -390, 436, -414, 436, -417,
[21:38:37.102][I][remote.raw:026]: 433, -439, 411, -440, 410, -440, 411, -1290, 410, -440, 410, -440, 410, -441, 410, -440, 410, -441, 409, -1292, 409, -1291, 410, -441, 409, -1292, 409, -441, 409, -441, 410, -441, 409, -1292, 409, -1292, 409, -441, 409, -442, 409, -441, 409, -442,
[21:38:37.123][I][remote.raw:026]: 409, -441, 409, -1292, 409, -1292, 409, -441, 409, -1292, 409, -1292, 409, -442, 408, -441, 410, -441, 409, -441, 410, -441, 409, -441, 410, -441, 409, -441, 409, -1292, 409, -441, 409, -441, 410, -441, 410, -441, 409, -441, 409, -441, 409, -442, 409,
[21:38:37.189][I][remote.raw:026]: -441, 409, -441, 410, -441, 409, -441, 410, -441, 409, -441, 409, -441, 409, -442, 409, -441, 409, -441, 409, -442, 409, -441, 409, -441, 409, -441, 409, -442, 409, -441, 410, -441, 409, -441, 409, -441, 409, -442, 409, -441, 410, -441, 409, -442,
[21:38:37.216][I][remote.raw:026]: 408, -442, 409, -441, 409, -441, 409, -442, 409, -441, 409, -1292, 409, -442, 409, -441, 409, -441, 409, -442, 409, -441, 409, -442, 409, -441, 409, -441, 409, -442, 409, -441, 409, -442, 408, -442, 409, -441, 409, -442, 408, -443, 408, -441, 409,
[21:38:37.217][I][remote.raw:026]: -442, 408, -442, 409, -441, 409, -442, 409, -441, 409, -1292, 409, -1292, 408, -442, 409, -441, 409, -1292, 409, -441, 410, -441, 409, -441, 409, -13018, 3402, -1726, 409, -1292, 409, -1292, 408, -442, 408, -442, 409, -442, 408, -1292, 409, -442, 408,
[21:38:37.217][I][remote.raw:026]: -442, 409, -1292, 408, -1293, 408, -442, 408, -1293, 408, -442, 409, -441, 409, -1292, 408, -1293, 409, -441, 408, -1293, 408, -1293, 408, -442, 408, -442, 409, -1292, 408, -442, 408, -442, 408, -1293, 408, -442, 408, -442, 408, -443, 408, -442, 408,
[21:38:37.232][I][remote.raw:026]: -443, 408, -442, 408, -442, 408, -443, 408, -442, 409, -442, 407, -443, 408, -442, 408, -443, 407, -443, 408, -443, 408, -442, 408, -442, 408, -443, 408, -442, 408, -442, 408, -1293, 408, -442, 409, -442, 407, -443, 408, -443, 407, -443, 408, -1293,
[21:38:37.250][I][remote.raw:026]: 408, -1293, 408, -442, 408, -1293, 408, -442, 408, -442, 408, -443, 408, -1292, 408, -1293, 408, -443, 407, -443, 409, -441, 409, -443, 407, -442, 408, -1293, 408, -1294, 407, -442, 408, -1294, 407, -1294, 407, -443, 408, -443, 407, -443, 408, -443,
[21:38:37.299][I][remote.raw:026]: 407, -443, 407, -443, 408, -443, 407, -444, 407, -1293, 408, -442, 408, -443, 408, -442, 408, -443, 408, -442, 408, -443, 407, -443, 408, -443, 408, -442, 408, -443, 407, -443, 408, -443, 407, -443, 408, -443, 407, -443, 408, -443, 407, -443, 407,
[21:38:37.299][I][remote.raw:026]: -444, 407, -443, 407, -444, 407, -443, 407, -443, 407, -443, 408, -443, 407, -443, 407, -444, 407, -444, 406, -444, 406, -443, 408, -443, 408, -442, 408, -443, 407, -443, 407, -443, 408, -444, 406, -1294, 407, -443, 407, -443, 408, -443, 407, -443,
[21:38:37.352][I][remote.raw:026]: 407, -444, 407, -443, 407, -444, 406, -444, 407, -443, 407, -444, 407, -444, 406, -444, 406, -444, 407, -443, 408, -443, 407, -443, 407, -443, 407, -444, 406, -444, 407, -443, 407, -444, 407, -1294, 407, -1293, 407, -443, 407, -444, 407, -1294, 406,
[21:38:37.352][I][remote.raw:035]: -444, 407, -443, 407, -444, 407
[21:38:37.352][S][climate]: '寝室のエアコン' >>
[21:38:37.352][S][climate]: Mode: OFF
[21:38:37.352][S][climate]: Fan Mode: AUTO
[21:38:37.352][S][climate]: Current Temperature: 0.00°C
[21:38:37.352][S][climate]: Target Temperature: 28.00°C
[21:39:53.208][I][remote.raw:026]: Received Raw: 3400, -1726, 408, -1293, 408, -1293, 408, -442, 408, -443, 408, -442, 408, -1294, 408, -441, 408, -443, 408, -1292, 409, -1292, 408, -442, 409, -1292, 408, -442, 409, -442, 409, -1292, 408, -1292, 410, -440, 409, -1292, 409, -1292, 409,
[21:39:53.209][I][remote.raw:026]: -441, 409, -441, 409, -1292, 409, -442, 408, -441, 410, -1292, 409, -440, 437, -413, 438, -412, 439, -411, 440, -410, 466, -384, 467, -384, 466, -384, 465, -386, 464, -386, 465, -385, 465, -385, 464, -387, 463, -388, 461, -390, 436, -415, 436, -414,
[21:39:53.209][I][remote.raw:026]: 435, -416, 434, -439, 411, -440, 410, -1290, 410, -440, 411, -440, 410, -440, 410, -440, 410, -440, 410, -1291, 409, -1292, 409, -441, 410, -1291, 410, -440, 410, -1291, 410, -1291, 410, -441, 409, -1291, 410, -441, 409, -441, 410, -441, 409, -441,
[21:39:53.238][I][remote.raw:026]: 409, -441, 410, -1291, 410, -1291, 409, -441, 409, -1292, 409, -1292, 410, -440, 409, -442, 409, -441, 409, -441, 410, -441, 409, -441, 410, -441, 409, -441, 409, -1292, 409, -441, 410, -440, 410, -441, 409, -441, 410, -441, 409, -441, 410, -440, 409,
[21:39:53.262][I][remote.raw:026]: -441, 410, -441, 409, -441, 409, -442, 408, -441, 410, -441, 409, -442, 408, -442, 409, -441, 409, -442, 409, -441, 409, -441, 410, -441, 409, -441, 409, -442, 409, -441, 409, -441, 409, -442, 409, -441, 409, -441, 409, -442, 409, -441, 410, -441,
[21:39:53.288][I][remote.raw:026]: 409, -441, 409, -441, 409, -442, 409, -441, 409, -442, 409, -1292, 409, -441, 409, -442, 408, -442, 409, -442, 409, -441, 409, -442, 408, -442, 409, -441, 409, -442, 409, -441, 409, -442, 409, -441, 409, -442, 409, -441, 409, -442, 408, -442, 409,
[21:39:53.303][I][remote.raw:026]: -441, 410, -441, 409, -442, 408, -442, 409, -441, 409, -442, 409, -1292, 408, -442, 409, -441, 409, -1292, 408, -442, 409, -442, 408, -442, 408, -13016, 3402, -1726, 408, -1292, 408, -1292, 409, -441, 409, -442, 408, -442, 409, -1292, 408, -442, 408,
[21:39:53.354][I][remote.raw:026]: -443, 408, -1292, 408, -1293, 408, -442, 409, -1292, 408, -442, 409, -442, 408, -1292, 409, -1292, 409, -442, 408, -1292, 409, -1292, 408, -442, 408, -442, 408, -1293, 408, -442, 408, -442, 409, -1292, 408, -442, 408, -442, 408, -442, 408, -442, 409,
[21:39:53.354][I][remote.raw:026]: -442, 408, -442, 409, -441, 408, -442, 409, -442, 408, -442, 408, -443, 408, -442, 408, -443, 407, -443, 407, -443, 408, -442, 408, -443, 408, -442, 408, -442, 408, -443, 408, -1292, 408, -442, 409, -442, 407, -443, 408, -442, 408, -442, 408, -1293,
[21:39:53.417][I][remote.raw:026]: 407, -1293, 408, -442, 409, -1292, 408, -442, 409, -1292, 407, -1293, 408, -442, 408, -1293, 407, -443, 408, -442, 408, -443, 407, -443, 408, -442, 408, -1293, 408, -1292, 408, -443, 408, -1292, 408, -1293, 407, -443, 408, -442, 408, -443, 407, -443,
[21:39:53.444][I][remote.raw:026]: 408, -442, 408, -443, 407, -443, 407, -443, 408, -1293, 407, -443, 408, -443, 407, -443, 407, -443, 408, -443, 407, -443, 407, -443, 407, -443, 408, -443, 407, -443, 407, -443, 408, -442, 408, -443, 408, -442, 408, -443, 407, -443, 407, -443, 408,
[21:39:53.445][I][remote.raw:026]: -443, 407, -443, 407, -443, 408, -443, 407, -443, 407, -443, 408, -443, 407, -443, 407, -443, 409, -442, 407, -443, 407, -444, 407, -443, 407, -443, 407, -444, 406, -443, 407, -443, 407, -443, 408, -1293, 407, -443, 407, -444, 406, -444, 407, -443,
[21:39:53.484][I][remote.raw:026]: 407, -443, 407, -443, 407, -443, 407, -444, 407, -443, 407, -443, 407, -443, 407, -444, 407, -443, 408, -442, 407, -443, 407, -444, 407, -443, 407, -443, 408, -442, 407, -443, 407, -444, 407, -443, 407, -1294, 407, -443, 407, -444, 406, -1294, 407,
[21:39:53.488][I][remote.raw:035]: -444, 406, -444, 407, -443, 407
[21:39:53.488][S][climate]: '寝室のエアコン' >>
[21:39:53.488][S][climate]: Mode: OFF
[21:39:53.488][S][climate]: Fan Mode: AUTO
[21:39:53.488][S][climate]: Current Temperature: 0.00°C
[21:39:53.488][S][climate]: Target Temperature: 27.00°C
[21:43:02.297][I][remote.raw:026]: Received Raw: 3401, -1727, 407, -1292, 409, -1292, 409, -441, 410, -441, 408, -443, 408, -1293, 408, -442, 409, -441, 409, -1292, 409, -1292, 408, -442, 409, -1292, 409, -441, 410, -441, 409, -1292, 409, -1292, 409, -441, 409, -1292, 409, -1291, 409,
[21:43:02.297][I][remote.raw:026]: -442, 408, -442, 409, -1291, 410, -440, 410, -441, 409, -1292, 436, -414, 438, -412, 439, -411, 439, -412, 464, -386, 465, -385, 466, -384, 466, -385, 465, -385, 466, -385, 465, -386, 464, -386, 464, -387, 463, -388, 461, -390, 436, -414, 436, -416,
[21:43:02.297][I][remote.raw:026]: 434, -439, 411, -440, 410, -440, 410, -1292, 409, -440, 410, -441, 409, -441, 410, -441, 409, -441, 410, -441, 409, -1292, 409, -441, 409, -1292, 409, -441, 410, -441, 409, -441, 410, -441, 409, -1291, 409, -442, 409, -441, 410, -440, 410, -441, 409,
[21:43:02.313][I][remote.raw:026]: -441, 410, -441, 409, -442, 408, -441, 410, -1291, 410, -1291, 409, -441, 409, -441, 410, -441, 409, -441, 409, -442, 409, -441, 409, -441, 410, -440, 410, -1291, 410, -441, 409, -441, 409, -442, 409, -441, 409, -442, 409, -441, 409, -441, 409, -442,
[21:43:02.344][I][remote.raw:026]: 409, -441, 409, -441, 410, -441, 409, -441, 409, -442, 409, -441, 409, -441, 409, -442, 409, -441, 409, -441, 409, -442, 409, -442, 408, -442, 408, -442, 409, -441, 409, -441, 409, -442, 410, -440, 409, -442, 409, -441, 409, -441, 409, -442, 409,
[21:43:02.415][I][remote.raw:026]: -441, 409, -441, 409, -442, 409, -441, 409, -442, 409, -1291, 409, -443, 408, -441, 409, -442, 409, -441, 409, -441, 409, -442, 409, -441, 409, -442, 409, -441, 409, -441, 410, -441, 408, -442, 409, -442, 408, -442, 408, -443, 408, -442, 409, -442,
[21:43:02.439][I][remote.raw:026]: 408, -442, 408, -442, 409, -442, 409, -441, 409, -1292, 408, -442, 409, -442, 408, -442, 408, -442, 409, -442, 408, -443, 408, -442, 408, -13018, 3402, -1725, 408, -1293, 408, -1292, 409, -442, 409, -442, 408, -442, 408, -1292, 409, -442, 408, -442,
[21:43:02.439][I][remote.raw:026]: 409, -1292, 408, -1293, 408, -442, 409, -1292, 409, -442, 408, -442, 408, -1293, 408, -1293, 408, -442, 408, -1293, 408, -1293, 408, -442, 409, -442, 408, -1292, 409, -442, 408, -442, 409, -1292, 409, -442, 408, -442, 408, -443, 407, -443, 408, -442,
[21:43:02.439][I][remote.raw:026]: 408, -442, 409, -442, 408, -442, 408, -443, 408, -442, 408, -443, 408, -442, 408, -442, 409, -441, 408, -443, 409, -441, 408, -443, 408, -442, 408, -443, 408, -442, 408, -1293, 408, -442, 409, -442, 408, -442, 408, -442, 409, -442, 408, -442, 408,
[21:43:02.466][I][remote.raw:026]: -1293, 408, -443, 407, -1293, 408, -442, 408, -443, 408, -442, 408, -443, 408, -1293, 407, -443, 408, -442, 408, -443, 408, -442, 408, -443, 408, -442, 408, -443, 408, -442, 408, -1293, 408, -1293, 408, -442, 408, -443, 408, -443, 407, -443, 408,
[21:43:02.514][I][remote.raw:026]: -442, 408, -443, 407, -443, 408, -442, 408, -1293, 409, -442, 408, -442, 408, -443, 408, -442, 408, -442, 408, -443, 407, -443, 408, -442, 408, -443, 408, -443, 407, -443, 407, -443, 408, -443, 407, -443, 407, -443, 409, -442, 407, -443, 408, -443,
[21:43:02.542][I][remote.raw:026]: 407, -443, 408, -443, 407, -443, 408, -443, 408, -442, 408, -442, 408, -443, 407, -443, 407, -444, 407, -443, 407, -443, 408, -443, 407, -443, 407, -444, 408, -442, 407, -443, 407, -444, 407, -1293, 408, -443, 407, -443, 408, -442, 408, -443, 407,
[21:43:02.542][I][remote.raw:026]: -443, 407, -444, 407, -443, 407, -444, 407, -443, 407, -443, 408, -443, 407, -444, 406, -444, 407, -444, 406, -444, 406, -444, 407, -443, 407, -444, 407, -443, 407, -444, 407, -443, 407, -1294, 407, -443, 408, -443, 407, -444, 406, -443, 408, -443,
[21:43:02.589][I][remote.raw:035]: 407, -443, 407, -444, 407
[21:43:02.590][S][climate]: '寝室のエアコン' >>
[21:43:02.590][S][climate]: Mode: OFF
[21:43:02.590][S][climate]: Fan Mode: AUTO
[21:43:02.590][S][climate]: Current Temperature: 0.00°C
[21:43:02.590][S][climate]: Target Temperature: 24.00°C
[21:43:11.349][I][remote.raw:026]: Received Raw: 3401, -1727, 407, -1293, 408, -1293, 408, -443, 407, -443, 408, -443, 407, -1293, 408, -444, 406, -442, 409, -1292, 409, -1293, 408, -441, 409, -1292, 409, -442, 408, -442, 409, -1292, 409, -1292, 409, -441, 409, -1292, 409, -1291, 409,
[21:43:11.350][I][remote.raw:026]: -442, 409, -442, 408, -1292, 410, -441, 408, -442, 409, -1291, 436, -414, 438, -412, 439, -412, 439, -410, 465, -386, 465, -385, 466, -384, 466, -386, 464, -386, 465, -385, 465, -386, 464, -386, 464, -387, 462, -388, 438, -413, 437, -414, 436, -414,
[21:43:11.350][I][remote.raw:026]: 436, -418, 432, -439, 411, -439, 411, -1290, 410, -440, 410, -441, 409, -441, 410, -440, 410, -441, 409, -1292, 409, -440, 410, -441, 409, -1292, 409, -441, 409, -441, 409, -441, 409, -1292, 409, -441, 409, -441, 410, -440, 410, -441, 409, -442, 408,
[21:43:11.365][I][remote.raw:026]: -441, 410, -440, 410, -441, 409, -441, 409, -1291, 409, -1292, 409, -441, 409, -441, 410, -441, 410, -440, 409, -442, 409, -441, 409, -441, 409, -442, 409, -1291, 410, -441, 409, -441, 409, -441, 410, -441, 409, -441, 409, -441, 410, -440, 410, -441,
[21:43:11.543][I][remote.raw:026]: 409, -441, 409, -441, 410, -441, 409, -442, 408, -441, 410, -441, 409, -441, 410, -441, 409, -441, 410, -440, 409, -442, 409, -441, 409, -442, 409, -441, 409, -442, 409, -441, 409, -441, 409, -442, 409, -441, 409, -442, 409, -441, 410, -441, 409,
[21:43:11.543][I][remote.raw:026]: -441, 409, -442, 409, -441, 409, -442, 408, -442, 409, -1292, 409, -441, 409, -441, 409, -441, 409, -442, 409, -441, 409, -441, 409, -441, 409, -442, 410, -440, 409, -442, 408, -442, 409, -441, 409, -441, 409, -442, 408, -442, 409, -442, 408, -442,
[21:43:11.574][I][remote.raw:026]: 408, -442, 409, -441, 410, -441, 408, -442, 409, -1292, 409, -442, 408, -1293, 408, -442, 408, -1293, 408, -1293, 408, -1292, 409, -1292, 409, -13018, 3401, -1726, 409, -1292, 408, -1292, 410, -440, 409, -442, 408, -442, 409, -1292, 408, -442, 408,
[21:43:11.574][I][remote.raw:026]: -442, 409, -1292, 408, -1293, 408, -442, 408, -1293, 408, -442, 408, -442, 408, -1293, 408, -1293, 408, -442, 408, -1293, 408, -1293, 408, -442, 409, -442, 408, -1293, 408, -442, 408, -443, 408, -1292, 409, -441, 409, -442, 408, -442, 409, -442, 408,
[21:43:11.574][I][remote.raw:026]: -442, 408, -443, 408, -442, 408, -442, 409, -442, 408, -442, 408, -443, 408, -442, 408, -442, 408, -443, 408, -442, 408, -442, 408, -443, 408, -442, 409, -442, 407, -443, 408, -1293, 408, -442, 408, -443, 408, -442, 408, -442, 409, -442, 408, -1292,
[21:43:11.574][I][remote.raw:026]: 408, -443, 408, -442, 408, -1293, 407, -443, 408, -443, 407, -443, 407, -1293, 408, -443, 408, -442, 408, -442, 408, -443, 408, -442, 408, -443, 407, -443, 408, -442, 408, -443, 408, -1292, 408, -1293, 408, -442, 408, -443, 407, -443, 407, -443, 408,
[21:43:11.608][I][remote.raw:026]: -443, 407, -443, 408, -442, 408, -442, 408, -1294, 408, -442, 408, -442, 408, -443, 407, -443, 408, -442, 408, -443, 407, -443, 408, -442, 408, -443, 407, -443, 408, -442, 409, -442, 407, -443, 408, -443, 407, -443, 408, -442, 408, -443, 407, -443,
[21:43:11.608][I][remote.raw:026]: 407, -443, 407, -444, 407, -443, 407, -443, 408, -444, 407, -443, 407, -443, 408, -442, 408, -443, 407, -443, 407, -444, 407, -443, 408, -443, 407, -443, 408, -443, 407, -443, 408, -442, 408, -1294, 407, -447, 403, -443, 407, -443, 408, -443, 407,
[21:43:11.609][I][remote.raw:026]: -443, 408, -443, 407, -444, 406, -443, 407, -443, 408, -443, 407, -443, 407, -444, 407, -443, 407, -444, 407, -443, 407, -444, 407, -443, 407, -444, 406, -444, 407, -443, 407, -444, 407, -1294, 407, -443, 407, -1294, 407, -444, 407, -1293, 407, -1294,
[21:43:11.619][I][remote.raw:035]: 407, -1294, 408, -1293, 407
[21:43:11.619][S][climate]: '寝室のエアコン' >>
[21:43:11.619][S][climate]: Mode: OFF
[21:43:11.619][S][climate]: Fan Mode: AUTO
[21:43:11.619][S][climate]: Current Temperature: 0.00°C
[21:43:11.619][S][climate]: Target Temperature: 20.00°C
[21:43:16.345][I][remote.raw:026]: Received Raw: 3400, -1727, 407, -1292, 409, -1293, 408, -442, 408, -443, 407, -443, 408, -1293, 408, -442, 408, -442, 409, -1292, 408, -1293, 408, -442, 409, -1292, 409, -443, 407, -442, 409, -1292, 408, -1292, 409, -442, 409, -1292, 409, -1291, 409,
[21:43:16.345][I][remote.raw:026]: -442, 409, -441, 409, -1291, 410, -441, 409, -441, 436, -1266, 436, -414, 437, -412, 439, -412, 439, -412, 464, -385, 466, -384, 467, -384, 466, -384, 466, -385, 466, -385, 464, -386, 465, -386, 463, -388, 462, -388, 462, -389, 437, -414, 436, -439,
[21:43:16.345][I][remote.raw:026]: 411, -439, 411, -439, 411, -440, 410, -1290, 410, -441, 410, -440, 410, -440, 410, -441, 409, -441, 410, -1291, 409, -1292, 409, -1292, 409, -441, 409, -441, 409, -442, 409, -441, 410, -440, 410, -1291, 409, -442, 408, -441, 410, -441, 409, -441, 409,
[21:43:16.394][I][remote.raw:026]: -441, 409, -441, 410, -441, 409, -441, 409, -1292, 410, -1291, 409, -441, 409, -442, 409, -441, 409, -442, 409, -441, 409, -441, 410, -441, 409, -441, 410, -1292, 409, -441, 409, -441, 411, -440, 409, -442, 408, -442, 409, -441, 409, -441, 410, -441,
[21:43:16.395][I][remote.raw:026]: 409, -441, 409, -441, 409, -442, 409, -441, 410, -441, 409, -441, 409, -441, 409, -442, 409, -441, 409, -442, 409, -441, 409, -441, 410, -441, 409, -441, 409, -442, 409, -441, 409, -442, 408, -442, 409, -442, 408, -442, 409, -441, 409, -441, 410,
[21:43:16.395][I][remote.raw:026]: -441, 409, -441, 409, -442, 408, -442, 409, -442, 408, -1292, 410, -441, 409, -441, 409, -442, 409, -441, 409, -442, 408, -443, 408, -441, 409, -442, 409, -442, 408, -441, 409, -442, 409, -441, 409, -442, 408, -442, 409, -441, 409, -441, 409, -442,
[21:43:16.408][I][remote.raw:026]: 409, -441, 409, -442, 408, -442, 409, -441, 410, -1292, 408, -442, 408, -442, 409, -1292, 408, -442, 408, -1293, 409, -1292, 408, -1292, 409, -13017, 3402, -1726, 409, -1291, 409, -1292, 408, -442, 409, -442, 408, -442, 409, -1292, 409, -442, 408,
[21:43:16.435][I][remote.raw:026]: -442, 408, -1293, 408, -1293, 408, -442, 408, -1294, 407, -442, 408, -443, 408, -1292, 408, -1293, 408, -443, 408, -1292, 409, -1292, 408, -444, 407, -442, 408, -1293, 408, -442, 409, -442, 408, -1294, 407, -442, 408, -442, 409, -442, 408, -442, 408,
[21:43:16.466][I][remote.raw:026]: -443, 408, -442, 408, -442, 409, -442, 408, -442, 408, -442, 409, -442, 407, -443, 408, -442, 409, -442, 408, -442, 408, -443, 408, -442, 408, -443, 407, -443, 408, -443, 407, -1293, 408, -442, 408, -443, 408, -442, 408, -443, 408, -442, 408, -1293,
[21:43:16.516][I][remote.raw:026]: 408, -1293, 408, -1293, 408, -442, 408, -443, 407, -443, 409, -441, 408, -443, 408, -1293, 408, -442, 408, -442, 408, -443, 407, -444, 407, -442, 408, -443, 408, -442, 408, -443, 407, -1294, 407, -1293, 408, -443, 408, -442, 408, -442, 409, -442, 407,
[21:43:16.517][I][remote.raw:026]: -443, 408, -443, 409, -442, 407, -443, 407, -1294, 407, -443, 407, -444, 407, -443, 407, -443, 408, -443, 407, -443, 408, -442, 409, -442, 408, -443, 407, -443, 407, -443, 408, -442, 408, -443, 407, -443, 407, -443, 408, -443, 407, -443, 407, -443,
[21:43:16.535][I][remote.raw:026]: 408, -443, 408, -442, 408, -443, 407, -443, 408, -443, 407, -444, 407, -443, 407, -444, 407, -443, 407, -444, 407, -443, 407, -444, 407, -443, 407, -444, 407, -443, 407, -443, 408, -443, 407, -1294, 407, -443, 407, -443, 408, -443, 408, -442, 408,
[21:43:16.564][I][remote.raw:026]: -443, 407, -443, 407, -444, 407, -444, 406, -444, 407, -443, 408, -443, 407, -443, 407, -444, 407, -444, 406, -443, 408, -443, 407, -443, 408, -443, 407, -444, 406, -444, 406, -445, 406, -1294, 407, -443, 407, -444, 407, -1294, 407, -444, 406, -1294,
[21:43:16.602][I][remote.raw:035]: 408, -1293, 406, -1295, 407
[21:43:16.602][S][climate]: '寝室のエアコン' >>
[21:43:16.602][S][climate]: Mode: FAN_ONLY
[21:43:16.602][S][climate]: Fan Mode: AUTO
[21:43:16.602][S][climate]: Current Temperature: 0.00°C
[21:43:16.602][S][climate]: Target Temperature: 24.00°C
[21:43:27.211][I][remote.raw:026]: Received Raw: 3401, -1727, 408, -1293, 408, -1293, 407, -443, 408, -442, 408, -443, 407, -1293, 408, -442, 409, -442, 408, -1294, 407, -1292, 409, -442, 408, -1293, 408, -442, 408, -442, 409, -1293, 408, -1292, 409, -441, 409, -1292, 409, -1291, 409,
[21:43:27.211][I][remote.raw:026]: -441, 409, -442, 409, -1292, 408, -442, 409, -441, 409, -1291, 410, -441, 409, -441, 436, -414, 438, -412, 439, -411, 465, -386, 465, -385, 465, -386, 464, -386, 465, -385, 465, -386, 464, -387, 463, -387, 463, -388, 461, -389, 437, -413, 437, -415,
[21:43:27.211][I][remote.raw:026]: 435, -416, 433, -440, 411, -439, 410, -441, 409, -441, 409, -441, 409, -441, 410, -440, 410, -441, 409, -1291, 409, -1292, 409, -441, 409, -1292, 409, -441, 409, -1292, 409, -1291, 409, -442, 409, -1292, 409, -441, 409, -442, 409, -442, 408, -441,
[21:43:27.241][I][remote.raw:026]: 409, -442, 409, -1292, 409, -1292, 409, -441, 409, -1292, 409, -1292, 409, -441, 409, -442, 409, -441, 410, -441, 410, -440, 409, -442, 409, -441, 410, -441, 409, -1292, 409, -441, 409, -441, 410, -441, 409, -441, 409, -442, 409, -441, 409, -442, 408,
[21:43:27.275][I][remote.raw:026]: -442, 409, -441, 409, -441, 410, -441, 409, -441, 409, -442, 409, -441, 409, -442, 408, -442, 409, -441, 409, -442, 409, -441, 409, -442, 408, -442, 409, -441, 410, -441, 408, -442, 409, -441, 409, -442, 409, -441, 409, -442, 409, -441, 408, -442,
[21:43:27.275][I][remote.raw:026]: 409, -441, 409, -442, 409, -442, 408, -442, 409, -441, 410, -1291, 409, -441, 409, -442, 408, -442, 409, -441, 409, -442, 408, -442, 409, -442, 408, -443, 408, -441, 410, -441, 409, -441, 409, -443, 408, -441, 409, -442, 408, -443, 408, -442, 408,
[21:43:27.298][I][remote.raw:026]: -442, 409, -442, 408, -442, 409, -441, 409, -442, 409, -441, 409, -1292, 409, -442, 408, -442, 409, -1292, 408, -1294, 407, -1293, 408, -1293, 409, -13018, 3402, -1727, 408, -1292, 408, -1293, 408, -442, 409, -442, 408, -442, 408, -1294, 407, -443,
[21:43:27.328][I][remote.raw:026]: 408, -442, 408, -1293, 408, -1293, 408, -442, 408, -1293, 409, -441, 408, -443, 408, -1293, 408, -1293, 408, -442, 409, -1292, 408, -1292, 409, -442, 408, -442, 408, -1293, 408, -442, 409, -442, 407, -1293, 408, -442, 409, -442, 408, -442, 408, -443,
[21:43:27.366][I][remote.raw:026]: 408, -442, 408, -442, 408, -443, 407, -443, 408, -442, 408, -443, 408, -442, 408, -442, 409, -442, 408, -442, 408, -443, 408, -442, 408, -443, 408, -442, 408, -442, 408, -443, 407, -443, 408, -443, 407, -443, 408, -442, 408, -443, 407, -443, 409,
[21:43:27.397][I][remote.raw:026]: -1293, 408, -1292, 408, -443, 408, -1293, 407, -443, 408, -1293, 407, -1294, 407, -443, 408, -1293, 408, -443, 407, -443, 408, -442, 408, -443, 407, -444, 407, -1294, 407, -1293, 408, -443, 407, -1294, 407, -1294, 407, -443, 407, -443, 408, -443, 407,
[21:43:27.425][I][remote.raw:026]: -443, 408, -443, 407, -443, 408, -443, 407, -443, 408, -1293, 407, -443, 408, -443, 408, -442, 408, -443, 408, -442, 408, -443, 408, -442, 408, -443, 407, -443, 407, -444, 408, -442, 408, -443, 407, -443, 407, -444, 408, -442, 407, -443, 408, -443,
[21:43:27.425][I][remote.raw:026]: 408, -442, 408, -443, 407, -443, 407, -444, 407, -443, 407, -444, 406, -444, 407, -443, 407, -444, 407, -443, 407, -444, 407, -443, 407, -444, 407, -444, 407, -443, 407, -445, 406, -443, 407, -444, 407, -1294, 407, -443, 407, -444, 406, -444, 407,
[21:43:27.470][I][remote.raw:026]: -443, 407, -444, 407, -443, 407, -444, 407, -443, 407, -444, 406, -444, 407, -443, 407, -444, 407, -443, 407, -445, 406, -443, 407, -444, 407, -444, 406, -444, 407, -444, 407, -443, 407, -443, 407, -444, 406, -1295, 406, -444, 407, -444, 407, -1294,
[21:43:27.474][I][remote.raw:035]: 407, -1295, 405, -1295, 406, -1295, 406
[21:43:27.474][S][climate]: '寝室のエアコン' >>
[21:43:27.474][S][climate]: Mode: OFF
[21:43:27.474][S][climate]: Fan Mode: AUTO
[21:43:27.474][S][climate]: Current Temperature: 0.00°C
[21:43:27.474][S][climate]: Target Temperature: 27.00°C
