Esphome multi_click help
Hi, I am having problems with on_multi_click where the physical switch connected to my esp module is not updated with the switch state from home assistant.
The part that is commented out works for keeping sync but doesn’t work for the second part of turning off/on the light.lower_hall.
Please help this has been wreaking my head for months.
binary_sensor:
  - platform: gpio
    filters:
      delayed_on_off: 50ms
    pin:
      number: 3
      mode: INPUT_PULLUP
    on_multi_click:
    - timing:
      - OFF for at least 0.41s
      then:
        # if:
        #   condition:
        #     light.is_on: light_1
        #   then:
        #     - light.turn_off: light_1
        #   else:
        #     - light.turn_on: light_1
    - timing:
      - ON for at least 0.41s
      then:
        # if:
        #   condition:
        #     light.is_off: light_1
        #   then:
        #   else:
    - timing:
      - ON for at most 0.3s
      - OFF for at least 0.1s
      then:
      - homeassistant.service:
          service:  light.toggle
            entity_id:  light.lower_hall
    - timing:
      - OFF for at most 0.3s
      - ON for at least 0.1s
      then:
output:
  - platform: gpio
    pin: 12
light:
  - platform: binary
    output: relay_1
I fixed it.
If anyone is curious on what to do, you need to add a home assistant binary sensor in esphome.
This works for toggle type light switches.
It allows for a single switch to control 2 or more devices independently of each other.
The code below is how it works.
binary_sensor:
  # This is the binary sensor I added
  - platform: homeassistant
    internal: true
  # Pin for physical lightswitch (toogle)
  - platform: gpio
    filters:
    pin:
      number: 3
      mode: INPUT_PULLUP
    internal: true
    on_multi_click:
    - timing:
      then:
        if:
          condition:
            binary_sensor.is_on: lowerhall
          then:
                service:  light.turn_off
          else:
                service:  light.turn_on
    - timing:
      then:
        if:
          condition:
            binary_sensor.is_off: lowerhall
          then:
          else:
    - timing:
      - ON for at least 0.31s
      - OFF for at least 0.31s
      then:
        if:
          condition:
          then:
                  entity_id:  light.hall
          else:
    - timing:
      then:
        if:
          condition:
          then:
          else:
output:
  - platform: gpio
    pin: 12
light:
  - platform: binary
    output: relay_1
