I have an ESP8266 NodeMCU with a DHT22 and 0.96 OLED attached. All working well, except when there is a loss of power.
When power is restored the readout on the screen shows temperature as a negative number. The only way to restore correct operations is to upload to the device again from ESPHome.
Here is my config…
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "<SSID>"
password: "****************"
ap:
ssid: "Housemon Fallback Hotspot"
password: "************"
captive_portal:
time:
- platform: homeassistant
font:
- file: 'slkscr.ttf'
- file: 'BebasNeue-Regular.ttf'
- file: 'arial.ttf'
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
status_led:
pin: GPIO2
- platform: dht
pin: GPIO14
temperature:
name: "Family Room Temperature"
humidity:
name: "Family Room Humidity"
update_interval: 60s
entity_id: sensor.family_room_temperature
internal: true
i2c:
sda: GPIO5
scl: GPIO4
scan: false
display:
- platform: ssd1306_i2c
model: "SH1106 128x64"
address: 0x3C
lambda: |-
// Print "gregoinc" in top center.
it.printf(64, 0, id(font1), TextAlign::TOP_CENTER, "gregoinc");
// Print time in HH:MM formatsensor.family_room_temperature
it.strftime(0, 60, id(font2), TextAlign::BASELINE_LEFT, "%H:%M", id(esptime).now());
// Print inside temperature (from homeassistant sensor)
if (id(inside_temperature).has_state()) {
it.printf(127, 23, id(font3), TextAlign::TOP_RIGHT , "%.1f°", id(inside_temperature).state);
Have tried a number of things, including config changes, but none seem to work?
Any ideas greatly appreciated.
