ESPHome pet feeding timer light
My boy has a fish he needs to feed once every 24 hours. He can’t ever remember if he did or not. So using a nodemcu, 2 ws2811 pixels, and a button. I made this ESPhome script that will keep the light green for 16 hours, then over 8 hours fade from green to red.
the code can be adapted to any feeding cycle though.
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  networks:
  - ssid: "Internet"
    password: "xxx"
  - ssid: "Internet2"
    password: "xxx"
  manual_ip:
    static_ip: 192.168.1.33
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    dns1: 192.168.1.1
  ap:
    ssid: "Fish reminder"
    password: "xxx"
captive_portal:
logger:
api:
ota:
substitutions:
  friendly_name: Fish reminder
globals:
  - id: redv
    type: float
    restore_value: no
    initial_value: '0'
  - id: greenv
    type: float
    restore_value: no
    initial_value: '1'
  - id: dir
    type: int
    restore_value: no
    initial_value: '1'
binary_sensor:
  - platform: homeassistant
    entity_id: input_boolean.fish_reminder
    on_press:
      - script.stop: fade_loop
      - script.stop: fade_red
      - script.execute: fade_reset
      - script.wait: fade_reset
      - script.execute: fade_red
light:
  - platform: fastled_clockless
    chipset: WS2811
    pin: D3
    num_leds: 2
    rgb_order: BRG
    restore_mode: ALWAYS_OFF
    default_transition_length: 0s
  - platform: wifi_signal
    name: "$friendly_name WiFi signal"
    update_interval: 60s
  - platform: uptime
text_sensor:
  - platform: version
    name: "$friendly_name ESPHome version"
script:
  - id: fade_red
    then:
      - light.turn_on:
          brightness: 1.0
          red: 0.0
          green: 0.0
          blue: 1.0
      - delay: 1s
      - light.control:
          red: 0.0
          green: 1.0
          blue: 0.0
      - delay: 1s
      - light.control:
          red: 0.0
          green: 0.0
          blue: 1.0
      - delay: 1s
      - light.control:
          red: 0.0
          green: 1.0
          blue: 0.0
      - delay: 2s
      - light.control:
          transition_length: 5s
          red: 0.0
          green: 1.0
          blue: 0.0
      - delay: 16h
      - script.execute: fade_loop
  - id: fade_loop
    then:
      - light.control:
          red: !lambda |-
            return id(redv);
          green: !lambda |-
            return id(greenv);
          blue: 0.0
      - delay: 150s
      - if:
          condition:
            lambda: |-
              return id(greenv) > 0;
          then:
            - lambda: |-
                if (id(dir) == 1) {
                  if (id(redv) < 0.05) {
                    id(redv) += 0.05;
                  } else if (id(redv) >= 0.99) {
                    id(redv) = 1;
                    id(dir) = 0;
                  } else {
                    id(redv) += 0.01;
                } else {
                  if (id(greenv) > 0.05) {
                    id(greenv) -= 0.01;
                  } else {
                    id(greenv) = 0;
            - script.execute: fade_wait
  - id: fade_wait
    then:
      - script.wait: fade_loop
  - id: fade_reset
    then:
      - lambda: |-
          id(redv) = 0;
          id(greenv) = 1;
          id(dir) = 1;
