Esphome: Philips Series 2200/3200 Smart Coffee Machine
esphome:
  on_boot:
    priority: 900
    then:
      - output.turn_off: display_trip
      - delay: 350ms
      - output.turn_on: display_trip
      - delay: 1200ms
      - delay: 200ms
esp8266:
  board: d1_mini
logger:
  baud_rate: 0
  level: NONE
api:
ota:
  - platform: esphome
wifi:
  ssid: "Bakro 4G"
  password: "Bakro@JW"
  ap: {}
captive_portal:
external_components:
  - source:
      type: local
      path: ./components
uart:
  # Mainboard side
  - id: uart_mainboard
    tx_pin: GPIO1
    rx_pin: GPIO3
    baud_rate: 115200
  # Display side
  - id: uart_display
    tx_pin: GPIO15
    rx_pin: GPIO13
    baud_rate: 115200
philips_coffee_machine:
  display_uart: uart_display
  mainboard_uart: uart_mainboard
  power_pin: GPIO16
  invert_power_pin: false
  model: EP_3243
globals:
  - id: last_drink
    type: std::string
    restore_value: no
    initial_value: '"N/A"'
text_sensor:
  - platform: philips_coffee_machine
    controller_id: coffee_machine
    update_interval: 1s
    lambda: |-
      std::string s = id(status).state;
      std::string lower = s;
      for (auto &c : lower) c = (char) tolower((unsigned char) c);
      if (lower.find("iced coffee") != std::string::npos) return {"Iced Coffee"};
      if (lower.find("latte") != std::string::npos) return {"Latte Macchiato"};
      if (lower.find("cappuccino") != std::string::npos) return {"Cappuccino"};
      if (lower.find("hot water") != std::string::npos) return {"Hot Water"};
      if (lower.find("americano") != std::string::npos) return {"Americano"};
      if (lower.find("espresso") != std::string::npos) return {"Espresso"};
      if (lower.find("coffee") != std::string::npos) return {"Coffee"};
      if (lower == "off") return {"Off"};
      if (lower == "idle") return {"Idle"};
      if (id(last_drink).empty()) return {"N/A"};
      return {id(last_drink)};
    name: "Selected Cup Size"
    update_interval: 1s
    lambda: |-
      std::string d = id(selected_drink).state;
      if (d == "Espresso" || d == "Coffee" || d == "Iced Coffee" ||
          d == "Cappuccino" || d == "Latte Macchiato" || d == "Americano" ||
          d == "Hot Water") {
        int v = (int) id(cup_size_state).state;
        if (v >= 1 && v <= 3) return {to_string(v)};
      return {"N/A"};
    name: "Selected Intensity"
    update_interval: 1s
    lambda: |-
      if (d == "Hot Water" || d == "Off" || d == "Idle" || d == "N/A")
        return {"N/A"};
      int v = (int) id(bean_strength_state).state;
      return {"N/A"};
    update_interval: 1s
    lambda: |-
      if (d == "Cappuccino" || d == "Latte Macchiato") {
        int v = (int) id(milk_foam_state).state;
      return {"N/A"};
    update_interval: 1s
    lambda: |-
      std::string out = "Drink: " + id(selected_drink).state +
                        " | Size: " + id(selected_cup_size).state +
                        " | Intensity: " + id(selected_intensity).state +
                        " | Milk: " + id(selected_milk).state;
      return {out};
number:
    status_sensor_id: status
    type: SIZE
    source: ANY
    name: "Cup Size State"
    type: BEAN
    source: ANY
    name: "Bean Strength State"
    type: MILK
    source: ANY
    name: "Milk Foam State"
script:
  - id: apply_max_defaults
    then:
      - delay: 150ms
      - number.set:
          value: 3
      - delay: 150ms
      - number.set:
          value: 3
      - delay: 150ms
      - number.set:
          value: 3
button:
    on_press:
      - delay: 300ms
      - delay: 800ms
      - delay: 200ms
    on_press:
      - repeat:
          count: 20
          then:
            - uart.write:
                data: [0xD5, 0x55, 0x0A, 0x01, 0x05, 0x01, 0x17, 0x00, 0x00, 0x00, 0x32, 0x23]
      - repeat:
          count: 20
          then:
            - uart.write:
                data: [0xD5, 0x55, 0x01, 0x01, 0x05, 0x01, 0x17, 0x00, 0x00, 0x00, 0x19, 0x16]
      - delay: 800ms
    on_press:
      - repeat:
          count: 20
          then:
            - uart.write:
                data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x01, 0x00, 0x00, 0x21, 0x0A]
    on_press:
      - uart.write:
          data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x00, 0x00, 0x01, 0x25, 0x03]
    on_press:
      - lambda: |-
          id(last_drink) = "Espresso";
      - uart.write:
          data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x02, 0x00, 0x00, 0x35, 0x1C]
      - script.execute: apply_max_defaults
    on_press:
      - lambda: |-
          id(last_drink) = "Coffee";
      - uart.write:
          data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x08, 0x00, 0x00, 0x05, 0x2D]
    on_press:
      - lambda: |-
          id(last_drink) = "Iced Coffee";
      - uart.write:
          data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x20, 0x00, 0x00, 0x1C, 0x26]
    on_press:
      - lambda: |-
          id(last_drink) = "Cappuccino";
      - uart.write:
          data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x04, 0x00, 0x00, 0x1D, 0x30]
    name: "Latte Macchiato"
    on_press:
      - lambda: |-
          id(last_drink) = "Latte Macchiato";
      - uart.write:
          data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x10, 0x00, 0x00, 0x35, 0x17]
    on_press:
      - lambda: |-
          id(last_drink) = "Hot Water";
      - uart.write:
          data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x00, 0x01, 0x00, 0x21, 0x0B]
    name: "Bean Strength"
    on_press:
      - uart.write:
          data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x00, 0x02, 0x00, 0x35, 0x1E]
    on_press:
      - uart.write:
          data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x00, 0x08, 0x00, 0x07, 0x25]
    on_press:
      - uart.write:
          data: [0xD5, 0x55, 0x00, 0x01, 0x05, 0x01, 0x17, 0x00, 0x04, 0x00, 0x1C, 0x34]
output:
  - platform: gpio
    pin: GPIO12
This is what i currently have
Oh, you are using completely different software compared to others in this topic.
Do you have a reason for it ?
Aw, not really. I wasn’t sure how to get it going, so I uploaded your GitHub source zip and got help from codex to get it working. As my machine is an 3347/23, the pins you had in the yaml examples didn’t work for me. The ones in my yaml worked for me.
Can you elaborate on what’s different? I can hopefully try to fix it.
Been messing around a bit took the EP3243 yaml and added my pin configs instead but nothing has worked so far
Here’s a log at the end after powering it on machine comes on but not the display.
[18:53:55.531][D][api:222]: Accept 192.168.1.23
[18:53:55.538][D][api.connection:2229]: Home Assistant 2026.3.1 (192.168.1.23): connected
[18:53:58.421][D][switch:026]: 'Power' Turning OFF.
[18:53:58.421][D][number:025]: 'Coffee beans' >> nan
[18:53:58.428][D][number:025]: 'Coffee size' >> nan
[18:54:01.824][D][switch:026]: 'Cleaning Power' Turning OFF.
[18:54:06.279][D][switch:026]: 'Power' Turning OFF.
[18:54:06.823][D][switch:022]: 'Power' Turning ON.
[18:54:06.823][W][component:579]: api took a long time for an operation (56 ms)
[18:54:06.823][W][component:582]: Components should block for at most 30 ms
[18:54:07.987][W][component:579]: philips_coffee_machine.switch took a long time for an operation (800 ms)
[18:54:07.988][W][component:582]: Components should block for at most 30 ms
[18:54:15.319][E][philips_power_switch:024]: Power tripping display failed!
I was about to order a set of PCBs but, @belastingvormulier if you still have units available from your last order I will love to participate. I’m based in the US in case shipping doesn’t work.
The US is not a problem. the shipping cost is horrendous from the EU tough. + The cables are on back order for over a month now I am still waiting they should arrive next week? but my hopes are low.
Digikey has it all in stock in the US with decent shipping costs if you live there.
For me that is 20$ shipping to the EU and then 20$ shipping back to the US potentially…
So if you are in the US and handy with a iron i would go that way for sure.
Thanks for the reply @belastingvormulier ! I can source the cables from Digi-Key, but I’m running into issues with ordering the PCB (the small board).
I don’t have soldering experience or equipment, so I’m trying to use the assembly option on JLCPCB. However, a few components are out of stock:
• J1 and J2 (6-pin headers)
• The Wi-Fi module
JLCPCB is suggesting the following replacements:
• Wi-Fi module: ESP-12F(ESP8266MOD) | Ai-Thinker | WiFi Modules | JLCPCB
• Headers (J1, J2): PZ254V-11-06P | XFCN | Pin Headers | JLCPCB
Do these substitutions look correct/compatible?
Also, I noticed that the PicoFlex connectors appear to be misaligned (horizontally placed) in the component placement file. (I cannot put screenshots since I am too new :slight_smile: )
My assumption is that they should be positioned vertically, but I’m unsure how precise the placement needs to be.
Any guidance would be really helpful before I submit the assembly order.
Also, if getting the PCB directly from you (without the cables) is an option, I’d be happy to go that route as well. Thanks again for the help!
is the AZDelivery ESP32 D1 Mini NodeMCU WiFi Module + Bluetooth pin compatible with the board: [quote=“The-May, post:1, topic:911784”]
big “simple” with normal parts → easy soldering
[/quote]
Thanks,
Michael
I could send a pcb without cables, but the last time I did that I think the shipping was about 20 bucks + pcb + components.
(also not sure about the tariffs as that should have changed now again with the court ruling)
So all in all its getting towards 40/50$ by the time its all in on doorstep. and then you still need to buy the atom + cables. Its a lot of $$ for automated coffee :coffee:
Is the m5 stack more stable than the esp if switched over to it? Can get the display on for around 20 mins then goes off so unsure if it’s the esp now.
Not more stable… Just smaller + usb-c + in a plastic case.
20 min → off = default coffee machine behavior? it turns itself off normally to save energy.
Machine doesn’t go off just the display, With the esp removed and screen directly plugged in my machine takes almost an hour to go fully off (display stays on until machine turns off) thinking may be an esp issue since it seems to work perfectly at first.
I have fixed the issue my YAML posted
before is all good. The issue got fixed after switching to ESPHome version 2023.5, as mentioned in ESP-Philips-5400-Coffee-Machine/README_EN.md at 276c0d353495f1f47bf0dab6289c9df575aafab3 · DivanX10/ESP-Philips-5400-Coffee-Machine · GitHub.
Unsure exactly why this version doesn’t break it, but I am glad to finally get it working. I just need to polish it up a bit, then I will add it to HomeKit.
In case anyone with the same or similar machine faces the issue, I’d suggest going that route.
Unfortunately went off again the 8266 is not stable has anyone managed a board that used an esp32? Or a drop in replacement for the same board to replace the 8266.
Hi, do you still have a board for sale? I would be interested (just the board) and I am located in germany.
If you’re willing to ship one with cables to the US whenever you have one available, i’d be willing to pay $60+ for a plug and play version! Worth the price to me :slight_smile:
Sorry I’m only responding now, but I replaced it with your code and now it turns on by turning it on 2x, but the display doesn’t. Do you have any ready-made automation instead of turning it on 2x? Thanks
I you are in the US i highly recommend buying most parts there (except the pcb), In the EU the cables seem un-obtainable - I anyone knows a source other than conrad i am happy to source them elsewhere.
I dont have a automation for it. But are you running the latest main code ?
It should have some power on fixes in it that should make it better, But it still is a problem I am unable to solve
Would you please share a link from I can order the plastine the PCB one. Thank you!
