ESPHome Remote Display Viewer for ESP8266/ESP32 (SSD1306 and more no MipiSpi)
oled_stream
An ESPHome component that mirrors a display’s framebuffer
into a web browser, served by the ESP itself.
No cloud, no MQTT, no Home Assistant, no extra hardware. Point a browser at
http://<device-ip>:8080/ and you get a pixel-exact copy of what is on the glass.
Why
Small displays end up in awkward places: inside an enclosure, behind a panel, at
the top of a pole. oled_stream gives you the screen wherever you are on the
network — for debugging a lambda:, for checking a device you cannot reach, or
just for putting the screen on a dashboard.
How it works
The component reads the display’s raw framebuffer and pushes it over a
keep-alive HTTP stream at ~30 fps. The browser page is a small self-contained
viewer that decodes the raw bytes back into pixels — the same work the display
driver does on the device.
Endpoint Serves
GET / the viewer page (~15 KB, self-contained, no CDN)
GET /buffer keep-alive application/octet-stream of raw frames
Each frame is a sync byte, the framebuffer, and the current contrast value. The
stream response carries X-Display-* headers so the viewer knows the geometry
and layout without being told.
Supported hardware
Platform Framework Status
ESP8266 Arduino tested on hardware
ESP32 Arduino supported
ESP32 ESP-IDF should work — the ESP32 path has no Arduino dependency, but it has not been tested on hardware
Any display built on ESPHome’s DisplayBuffer should work. The buffer layout is
detected from the display platform:
Layout Displays
mono_page SSD1306, SSD1305, PCD8544 (Nokia 5110)
mono_row ST7567, ST7920, Waveshare ePaper, Inkplate, MAX7219
gray4_row SSD1322, SSD1325, SSD1327
rgb565_row ILI9XXX, ST7735, ST7789V, SSD1331, SSD1351
If your display is not in the list, the viewer lets you pick the layout by hand.
A note on the name. oled_stream also handles RGB565 TFTs, which are not
OLEDs. The name is historical.
Memory. The component allocates a copy of the framebuffer. That is 1 KB for
a 128x64 mono display, but 150 KB for a 320x240 RGB565 one — more than an
ESP8266 has. On a large colour display, use an ESP32. If the allocation fails
the component marks itself failed and logs it, rather than crashing.
Installation
external_components:
  - source: github://kaboom748/oled_stream
    components: [oled_stream]
    refresh: 1d
Configuration
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
oled_stream:
  - display_id: oled_display
    port: 8080
Option Type Default Description
display_id ID required the display to mirror
port port 8080 TCP port for the viewer
contrast_lambda lambda returns a float in 0.01.0, applied by the viewer
oled_stream is MULTI_CONF: mirror several displays by declaring several
blocks on different ports.
Why there is no width / height
There used to be. The display already knows its own geometry, and asking the user
for it again meant a wrong answer was accepted silently — and then the component
read past the end of the framebuffer, thirty times a second. The dimensions now
come from get_native_width() / get_native_height(), so the two can no longer
disagree.
Upgrading? Delete width: and height: from your YAML. They are now
rejected.
Contrast
ESPHome applies contrast: on the panel itself, and it cannot be read back — so
the viewer has no way to know about it. If you change contrast at runtime, feed
the same value to contrast_lambda and the browser will match the glass:
globals:
  - id: current_contrast
    type: float
    initial_value: "1.0"
oled_stream:
    contrast_lambda: |-
      return id(current_contrast);
Limitations
  • Framework. The ESP8266 path uses Arduino WiFiServer; ESP8266 with
    ESP-IDF is not supported (ESPHome does not support that combination anyway).
  • One viewer at a time. A second GET /buffer replaces the first.
  • Bandwidth. A 128x64 mono display is ~1 KB per frame — around 250 kbit/s at
    30 fps. A large RGB565 panel will saturate the radio; raise the frame interval
    if you try.
  • No authentication. Anyone on your network can watch the screen. Do not
    expose the port to the internet.
Known deviation from ESPHome upstream
display::DisplayBuffer::buffer_ is protected and has no public accessor, so
this component reaches it by casting to a derived type the object is not an
instance of. That is undefined behaviour. It works in practice, but it is
also why this component is not a candidate for ESPHome upstream as-is: a clean
version needs a small upstream change adding a public get_buffer() and
get_buffer_length() to DisplayBuffer. That conversation belongs on the
ESPHome Discord #devs channel before any PR.
If you are here to judge whether to depend on this: the cast is the one thing in
the codebase that is not defensible on its own terms.
Development
esphome config tests/test.esp8266.yaml
ruff check components/oled_stream/
tests/test_oled.cpp is a host-side test that replays a real browser request
against the component and checks the response. It exists because a fixed 256-byte
request buffer once looked perfectly fine and silently broke every request a real
browser made — a browser GET is around 500 bytes, and the terminator never
arrived.
License
Same model as ESPHome: the C++ / runtime code (.cpp, .h, and the embedded
viewer) is GPLv3, the Python code and everything else is MIT. See
LICENSE.
