ESPHome RGB Status LED Package
I have just made a reusable ESPHome package that provides a prioritized RGB status LED system.
:rocket: Features
  • Priority-based LED status handling.
    • booting β†’ boot done β†’ WiFi connected β†’ Home Assistant connected
  • Drop-in ESPHome package - detects system states on it’s own.
  • Works with any RGB LED platform (Neopixel, RMT LED Strip, Cwww, etc.).
  • Optional working states provided (status evaluation, actuator working, beacon activity, …).
:hammer_and_wrench: Set Up
Add the package to your device configuration:
packages:
  rgb_status_led:
    url: https://github.com/Flo-R1der/ESPHome_RGB-Status-LED_Package
    file: status_led_package.yaml
Make sure your project defines the required RGB LED light with the id: system_status_led. The following light configuration has proven to work on a LOLIN C3 Mini (board: lolin_c3_mini):
light:
  - platform: esp32_rmt_led_strip
    id: system_status_led             # DO NOT CHANGE
    pin: GPIO7                        # check your board
    rgb_order: GRB                    # check your board
    num_leds: 1
    chipset: ws2812                   # check your board
    disabled_by_default: true
    default_transition_length: 200ms
    icon: mdi:led-outline
    restore_mode: ALWAYS_OFF
    effects:
      - pulse:
          name: "Slow Pulse"          # REQUIRED
          update_interval: 2s         # can be adjusted
      - pulse:
          name: "Fast Pulse"          # REQUIRED
          update_interval: 500ms      # can be adjusted
NOTE:
The package does not depend on any specific LED chipset or ESP32 variant.
If you prefer another LED type (NeopixelBus, FastLED, CWWW RGB LED), simply keep the ID identical.
:bulb: LED Colors and States
System States
The LED system status follows a strict top-down priority. The highest matching state always wins.
If a condition is no longer fulfilled, the LED falls back to the previous applicable state.
Priority Color + Effect System State Notes
1 Red
fast pulsing
Booting / initialization Shown before WiFi stack is ready
2 Yellow
static
Boot completed Waiting for WiFi / network issue?
3 White
static
WiFi connected network OK, Home Assistant not connected
4 Green
static
Home Assistant connected FULLY STARTED - Normal operating mode
Custom States
Additionally there are LED working states provided, which can be triggered from your main device configuration.
They are meant to signals states separate from the main priority logic.
They temporarily override the LED as long as the script is active, similar to the beacon state.
Script ID Color + Effect Notes (Examples)
led_working_status_1 Blue
slow pulsing
Example: device performing a background task; BT-beacon detected; etc.
led_working_status_2 Purple
slow pulsing
Example: special output is turned on; long-running IΒ²C read; etc.
led_working_status_* add more if you like
To set and reset the working light you can call the following scripts:
  • - script.execute: led_working_status_1 (or any other number)
  • - script.execute: led_system_status (to reset the LED to the system-status)
Example:
binary_sensor:
  - platform: ble_presence
    mac_address: ${ble_beacon_mac}
    timeout: 60s
    on_press:
      then:
    on_release:
      then:
:triangular_flag_on_post: Troubleshooting
LED Does Not Light Up
  • Confirm that the LED hardware definition exists in your main config and uses the same id: expected by the package.
  • Double-check pin numbers, chipset type, and RGB order.
  • Ensure your power supply can drive the LED (WS2812 requires stable 5V).
LED Only Shows One Color or Wrong Colors
  • Incorrect rgb_order.
    Try switching between RGB, GRB, or BRG depending on the LED hardware.
Home Assistant API Status Seems Wrong
  • If API repeatedly connects/disconnects, check your WiFi RSSI.
  • Validate that the ESPHome API is properly configured in Home Assistant.
  • If using VLANS or firewalls, ensure port 6053 is allowed.
:pushpin: Open Topics
  • Add a substitution value for general brightness (now all states are on 50%)
  • Create additional working-status templates with more effects.
  • A selectable β€œstealth mode” (LED off unless error) would be nice.
:heart: Like My Work?
ko-fi
