Esphome rttl passiv buzzer
I’m building a workshop door sensor with rttl buzzer, temp/humidity sensor and a reed sensor. I am using Wemos d1 mini and my config is as follows:
substitutions:
  # Device Names
  friendly_name: "workshop"
esphome:
  platform: ESP8266
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "top_secret_code"
  services:
    - service: workshhop_play_rtttl
      variables:
        song_str: string
      then:
        - rtttl.play:
            rtttl: !lambda 'return song_str;'
ota:
  password: "top_secret"
wifi:
  networks:
  - ssid: !secret wifi_ssid
  - ssid: !secret wifi2_ssid
  manual_ip:
    static_ip: 192.168.x.x
    gateway: 192.168.x.x
    subnet: 255.255.255.0
    dns1: 192.168.x.x
    dns2: 192.168.x.x
captive_portal:
#WiFi Signal
  - platform: wifi_signal
    name: ${friendly_name} WiFi Signal Sensor
    update_interval: 180s
  - platform: dht
    pin: 5
    temperature:
      name: ${friendly_name} Temperature
    humidity:
    update_interval: 60s
binary_sensor:
#Reed sensor
  - platform: gpio
    pin:
      number: 4
      mode: INPUT_PULLUP
    device_class: door
time:
  - platform: homeassistant
output:
  - platform: esp8266_pwm
    pin: 14
rtttl:
  output: buzzer
Everything works fine but the buzzer seems to be picking up line noise or wifi noise and you can hear very faint clicking from the buzzer.
I have another similar sensor setup in my other workshop but based on nodemcu 32 and there is no problems like that
Is that something that is caused by wemos d1 mini? (this is my first project based on this board) Any way of eliminating it?
This must be wemos d1 related - as I had fresh delivery of wemos s2 boards I tried one of them and voila no annoying buzzing and clicking.
