myle
(StePhan McKillen (Other kiwi Here))
1
have this
select:
icon: mdi:trash-can-outline
optimistic: true
restore_value: true
options:
- Landfill
- Glass
- Recycling
- Recycling/Glass
on_value:
then:
- logger.log:
format: "Chosen option: %s (index %d)"
args: ["x.c_str()", "i"]
- light.turn_on: **??????????**
which I can see in home assistant the select box
the light bit
light:
- platform: neopixelbus
type: GRB
variant: ws2812
pin: GPIO4
num_leds: 5
# default_transition_length: 7.5s
effects:
# Use default parameters:
- addressable_color_wipe:
colors:
- red: 100%
green: 0%
blue: 0%
num_leds: 5
add_led_interval: 50ms
so when i select the Landfill in the select part how do i turn on its effects
am i barking up the wrong tree
as i have this in HA
zoogara
(Daryl)
2
Something like this?
select:
optimistic: true
restore_value: true
options:
- Landfill
- Glass
- Recycling
- Recycling/Glass
on_value:
then:
- logger.log:
args: ["x.c_str()", "i"] then:
- if:
condition:
lambda: |-
return x == "Landfill";
then:
- light.turn_on:
- if:
condition:
lambda: |-
return x == "Glass";
# etc for other states
Try this:
select:
optimistic: true
restore_value: true
options:
- Landfill
- Glass
- Recycling
- Recycling/Glass
on_value:
then:
- logger.log:
# - light.turn_on: **??????????**
- lambda: |-
auto call = id(wastebin_lid).turn_on();
// set parameters (optional)
// call.set_transition_length(1000); // in ms
// call.set_brightness(1.0); // 1.0 is full brightness
// call.set_color_mode(ColorMode::RGB_COLD_WARM_WHITE);
// call.set_rgb(0.5, 0.25, 1.0); // color in RGB order, this example is purple
// call.set_cold_white(0.5);
// call.set_warm_white(0.75);
call.set_effect(id(set_interval).state);
// perform action:
call.perform();
light:
type: GRB
variant: ws2812
pin: GPIO4
num_leds: 5
effects:
colors:
- red: 100%
green: 0%
blue: 0%
num_leds: 5
myle
4
Thanks understand sort of what it doing
but if I add your bit
it does not connect to the wifi
if i take out the
it joins the network
on_value:
then:
- logger.log:
- lambda: |-
//call.set_effect(id(set_interval).state);
call.perform();
looks like more reading
myle
5
got it sorted
had to add a if statement
on_value:
then:
- logger.log:
- if:
condition:
lambda: |-
return x != "None";
then:
- lambda: |-
call.perform();
thank you
zoogara walberjunior
next problem how the hell do i turn off the BLUE status LED
here is full working code
esphome:
esp8266:
# board: esp01_1m
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
- platform: esphome
password: 'nottellingyou'
wifi:
networks:
ssid: "IOT"
password: "imnottellyou"
ap:
ssid: "Wastebin Fallback Hotspot"
captive_portal:
web_server:
port: 80
version: 3
select:
optimistic: true
restore_value: false
options:
- "OFF"
- Landfill
- Glass
- Recycling
on_value:
then:
- logger.log:
- if:
condition:
lambda: |-
return x != "OFF";
then:
- lambda: |-
call.perform();
- if:
condition:
lambda: |-
return x == "OFF";
then:
- lambda: |-
auto call = id(wastebin_lid).turn_off();
call.perform();
light:
type: GRB
variant: ws2812
pin: D2 #GPIO4
num_leds: 5
effects:
colors:
- red: 100%
green: 0%
blue: 0%
num_leds: 5
colors:
- red: 0%
green: 0%
blue: 100%
num_leds: 5
colors:
- red: 100%
green: 100%
blue: 0%
num_leds: 5
reverse: false
binary_sensor:
- platform: gpio
pin:
number: GPIO0
inverted: true
name: wastebin lidswitch
filters:
# debounce delay
- delayed_off: 10ms
switch:
- platform: gpio
pin: GPIO2
name: wastebin lidswitch disable
restore_mode: ALWAYS_OFF
Try creating an output on the gpio02 port and turning it off after booting is complete.
GPIO02 HIGH at boot
connected to on-board LED, boot fails if pulled LOW
myle
7
thanks bro
got it sorted
- platform: monochromatic
disabled_by_default: True
name: Status - LED
output: out_led
default_transition_length: 0s
effects:
- pulse:
transition_length: 0.0s
update_interval: 0.25s
- pulse:
update_interval: 0.025s
on_turn_on:
- delay: 3s
- light.turn_off: led
output:
platform: esp8266_pwm
pin:
number: GPIO2
inverted: true
dont unstand how it works it works lol found is on line
and even found how to disable them looking good now
as I dont want them showing in HA
Remove the name, the entity will be internal only
myle
9
thanks, bro make cents
now the next part when we have recycling and glass on the same day
having the two colours half yellow and other half blue
bloody more reading
