I have a board near my mechanical ventilation to control the setpoint of this fan. I would like to the board to report back it’s interpreted setpoint from my automations. All the automations work as expected. I’m able to adjust the setpoint. However, the value I read back in HA is interpreted as a string. I would like to be able to plot it in a graph instead.
I have the following configuration in ESP home, but I’m not sure what to change in order for it to read as a float (or integer). In the logs it even reports
“‘Fan setpoint’: Sending state 24.00000 with 1 decimals of accuracy”, which leads me to believe it actually is a float.
perhaps a second question related to the configuration above. I noticed the Fan connected to the board only starts picking up on the pwm output starting at 15% and saturates above 80%, is there any way I can scale the output of the fan definition, such that 0% fan setting, corresponds with 15% pwm output, and 100% fan setting, corresponds with 80% pwm output, if that makes sense?
I think that could work for the value reported back to home assistant (since a filter can be applied to a sensor), but what I’m trying to achieve is that when I set the speed of the fan entity in home assistant to 100%, the corresponding output of the pwm output signal in esphome is set to 80% (for example).
I found the solution to the second problem.
The output can be altered as following:
where the max_power' corresponds with the fraction at a 100% output and min_power’ the fraction at 0% output.
