ESPHome Sensor naming driving me nuts
I’m experimenting with a simple ESPHome project:
substitutions:
  devicename: energy-meter-01
  friendly_name: Energy Meter 01
esphome:
switch:
  - id: relay
    platform: gpio
So far so good.
Now, if I name my switch
The resulting Home Assistant sensor is (friendly)named
"Relay"
and the entity_id is just
switch.relay
Good, but not very useful if you have multiple devices.
If I name the switch
the resulting sensor is now named
"Energy Meter 01 Relay"
(much better), however the entity_id now becomes
energy_meter_01_energy_meter_01_relay
I’m clearly missing something.
Please help!
The behaviour of friendly_name became a feature a few releases back, so possibly you should be working with that rather than substitutions (which was the old approach). Or try using another term than friendly_name if you want to use the substitution approach - you may be getting some interactions with a reserved field?
ESPHome Core Configuration — ESPHome.
Still, even if I do define friendly_name (as a part of the esphome domain) and do not prefix the sensor (i.e. relay) name using substitution, I don’t get automatic prefixes to the entities as per the documentation. If I do prefix them I get double prefixes…
