I have a Sonoff S31 wifi A/C outlet with ESPHome that I am using to monitor my refrigerator. I use it to troubleshoot by monitoring the current load. When I view the current value graph over long periods, like a month, it is crashing my HA Yellow host. Sometimes it’s okay but mostly not. When initially viewing the device current attribute it seem to be updating much faster than the 60s update_interval value. I have tried very long update_interval values like 10min but it is not having any effect. It seems more like the device is sending updates as soon as the current value changes. There are constant small changes because of the compressor motor. Not sure what to do. Perhaps filtering the current sensor to remove the small fluctuations but the update interval is not doing what I expected.
Is your sensor data being stored by regular time slices or by changes in value? Is your sensor resolution to poofteenth decimal places? Your database may be overloaded with too many data points, hence causing your graphing to crash.
Stepping back: why the need to monitor your refrigerator so closely? Is it having problems?
Post your code (formatted in forum </> formatting please) and we can try to see where the issue is.
Yes it is having problems and has been for a while. Whirlpool French door reefers of this vintage (2014) have a problem with freezing up. There was a class action lawsuit over this. Watching the current draw to see how often the compressor runs and when the defrost cycle is active.
Excessive data points is exactly what I am thinking.
Update:
I found this filter suggestion in the ESPHome CSE7766 platform documents. This is working correctly.
- platform: wifi_signal
name: "Mon1 wifi_signal"
update_interval: 60s
- platform: cse7766
current:
accuracy_decimals: 1
filters:
- throttle_average: ${update_interval}
voltage:
filters:
power:
filters:
- platform: integration
sensor: mon1_power
time_unit: h
unit_of_measurement: kWh
filters:
- multiply: 0.001
That yaml may solve your data collection issue, but check the common faults for freezing which are poor door seals, bad or sticky thermostat, inadequate defrosting, and insufficient internal airflow past the thermostat to accurately monitor temperatures, often caused by recirculating fan failure, or just having too much stuff in the fridge. Some people treat them as a storage cupboard, and this is reflected in the power consumption figures.
Not sure about your class action - just general comment.
I haven’t read up on filters lately, but there seem to be quite a few options in the documents.
I see you have an 60 second interval on your WiFi signal sensor, but not on your cse7766 and power monitor sensors. Is that deliberate?
I have been through this with this particular refrigerator since 2018. I have replaced door seals, defrosted both evaporator coils, checked and replaced fans. After diagnosis by repairman the refrigerator evap fan was replaced. The coil was completely iced over. That $500 experiment fixed nothing. Some research suggested low refrigerant as a cause of icing. I bought and installed a piercing valve and added refrigerant, which fixed that problem. That was a year ago. Now I found the refrigerator evap coil frozen over again. The fan was operating. I decided to add more refrigerant but that did nothing. Subsequently checked the freezer evap coil which was slightly iced. I added more refrigerant but I think it was now overcharged based on some ugly noises emanating. Basically, I have given up and ordered a new fridge which unfortunately won’t be delivered until Mar 17th. Based on my last experience with Lowe’s delivering a special order dishwasher, I am not holding my breath. In the meantime the freezer has become even warmer, not able to sustain less than 20⁰. I now am the proud owner of a 7cuft chest freezer to keep stuff actually frozen.
The Sonoff S31 fortunately is working correctly.
