ESPHOME : simulate the activation of a GPIO (General Purpose Input/Output) pin
hello ,
Hello, I would like to create a button on a web interface that can simulate the activation of a GPIO (General Purpose Input/Output) pin on an ESP32 microcontroller. This would allow me to test and manipulate my pulse counter without having to physically interact with the ESP32 device, such as going outside to manually activate the GPIO pins. The goal is to have a button on the web interface that, when clicked, triggers the pulse counter as if the GPIO pin had been activated. This would provide a convenient way to test and debug the pulse counter functionality without the need for physical access to the ESP32 device.
it this a possible way in ESPHOME ?
kind regards
 - platform: pulse_counter
   pin:
     number: GPIO12
     inverted: True
     mode: INPUT_PULLUP
   update_interval : 10s
   accuracy_decimals: 0
   total:
    name: "rainWater Meter Total"
    unit_of_measurement: "L"
    accuracy_decimals: 3
    device_class: water
    state_class: total_increasing
    filters:
      - multiply: 1
button:
   # Optional variables:
   icon: "mdi:emoticon-outline"
   on_press:
     - logger.log: "create event so i can create a software puls to tippingbucket "
switch:
  - platform: gpio
    pin: GPIOXX
    on_turn_on:
    - delay: 100ms
    - switch.turn_off: testbutton
and put a jumper wire between this pin and your input pin
hmmm…so i got to go outside for making the jumper wire
thanks for the suggestion
