I had trouble finding the right value for timeout on MagicSwitch external component by ssieb since my Sonoff Basic R4 is connected to 3 physical switches (2x no. 6 and 1x no. 7) so typical situation 3 switches controlling 1 light.
I did not wanted to mess with the wiring much and thanks to this setup the reported pulse value was all over the place ranging from 1 200us to 80 000us… So the lower you go the more probable is registering the switch press but in the 2000 region it starts registering multiple pulses and turns on and off multiple times on one press. Below 1000 it register pulses without pressing the switch.
Wanted to share this code that debounces the multiple “false” triggering since it might be useful to someone. It is cruel and probably not the correct solution but it works…
esphome:
friendly_name: basic-r4
platformio_options:
board_build.mcu: esp32c3
board_build.variant: esp32c3
esp32:
variant: ESP32C3
board: esp32-c3-devkitm-1
framework:
type: esp-idf
#this is taken from ESPhome devices website. I did not mess with it..
sdkconfig_options:
CONFIG_BT_BLE_50_FEATURES_SUPPORTED: y
CONFIG_BT_BLE_42_FEATURES_SUPPORTED: y
CONFIG_ESP_TASK_WDT_TIMEOUT_S: "10"
mdns:
logger:
level: DEBUG
api:
encryption:
key: "le secret key"
ota:
- platform: esphome
password: "le secret pass"
wifi:
ssid: !secret wifi_ssid
#fast connect not necessary actually I would recommend to disable it for testing
fast_connect: True
ap:
# Magic switch mode
external_components:
- source:
type: git
url: https://github.com/ssieb/esphome_components
components: [ magic_switch ]
refresh: 1min
magic_switch:
pin: 5
timeout: 1000us #feel free to mess with this value for me anything below 1000 can trigger on its own
on_switch:
- script.execute: main_light_toggle
esp32_ble_tracker:
scan_parameters:
active: true
interval: 1100ms
window: 1100ms
bluetooth_proxy:
active: true
binary_sensor:
- platform: gpio #to enable physical button on sonoff
pin:
number: GPIO9
mode:
input: true
pullup: true
inverted: true
on_press:
then:
- light.toggle: main_light
output:
- platform: gpio #work around to show the relay as light in HA
pin: GPIO04
light:
- platform: status_led #my desired LED behaviour
pin:
number: GPIO6
inverted: false
disabled_by_default: True
icon: "mdi:led-outline"
- platform: binary #work around to show the relay as light in HA
output: main_relay
restore_mode: ALWAYS_OFF
on_turn_on:
- script.execute: blink_status_led
on_turn_off:
script:
- id: main_light_toggle #script that "debounces" the pulses
mode: single #this is crucial if not single it wont work
then:
- light.toggle:
- delay: 150ms #prolly can be much less but this works good enough.
- id: blink_status_led #my desired LED behaviour
mode: restart
then:
- light.turn_on:
- delay: 500ms
- light.turn_off: status_led_onboard
I would recommend starting with the default template from Sonoff BASIC R4 v1.0 | ESPHome Devices and figuring out the typical pulse value and implement this in case of troubles I had.
