i am trying to use the sprinkler component of esphome to turn off a specific valve when my tank is full, my setup uses the same bore pump for irrigation and to fill my house water tank so i do need to co-ordinate the two, but i cant figure out how to turn off the valve “correctly” within esphome when treating it as just one of the irrigation zones and the tank becomes full. i am aware that my current usage of the sensor on_value_range will not work if the tank is already full and the tank filler turns on, that’s a future problem that probably involves on_value instead of on_value_range, or a check when the gpio switch is turned on for that valve.
esphome:
friendly_name: irrigation
esp8266:
board: nodemcuv2
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
actions:
- action: start_full_cycle
then:
- sprinkler.start_full_cycle: sprinkler_ctrlr
- action: start_single_valve
variables:
valve: int
then:
- sprinkler.start_single_valve:
valve_number: !lambda 'return valve;'
- action: next_valve
then:
- sprinkler.next_valve: sprinkler_ctrlr
- action: previous_valve
then:
- sprinkler.previous_valve: sprinkler_ctrlr
- action: shutdown
then:
- sprinkler.shutdown: sprinkler_ctrlr
- action: shutoff_filler
then:
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Irrigation Fallback Hotspot"
captive_portal:
- platform: "jsn_sr04t"
update_interval: 10s
on_value_range:
- above: 1.5
then:
valve_number: 5
run_duration: 900s
- below: 0.5
then:
#fixme turn off the tank filler valve here
name: "Irrigation Zone Remaining Time"
icon: mdi:progress-clock
device_class: duration
unit_of_measurement: min
update_interval: 2s
lambda: |-
if (id(sprinkler_ctrlr).time_remaining_active_valve().has_value())
return id(sprinkler_ctrlr).time_remaining_active_valve().value() / 60;
else
return 0;
name: "Irrigation Total Cycle Time Enabled Valves"
unit_of_measurement: h
update_interval: 2s
lambda: |-
return id(sprinkler_ctrlr).total_cycle_time_enabled_valves() / 60 / 60;
name: "Irrigation Total Cycle Time Incomplete Valves"
update_interval: 2s
lambda: |-
return id(sprinkler_ctrlr).total_cycle_time_enabled_incomplete_valves() / 60 / 60 ;
sprinkler:
- id: sprinkler_ctrlr
main_switch: "bore pump"
auto_advance_switch: "irigation Auto Advance"
valve_overlap: 5s
multiplier_number:
name: "irrigation multiplier"
initial_value: 1.0
min_value: 0.1
max_value: 2
valves:
- valve_switch: "Olive Irrigation"
enable_switch: "Enable Olive Irrigation"
pump_switch_id: bore_pump_sw
run_duration_number:
name: "Olive Irrigation Duration"
initial_value: 30
min_value: 10
max_value: 120
valve_switch_id: olive_irrigation_sw
- valve_switch: "Hazels Irrigation"
enable_switch: "Enable Hazel Irrigation"
name: "Hazels Irrigation Duration"
initial_value: 90
min_value: 10
max_value: 120
valve_switch_id: hazel_irrigation_sw
- valve_switch: "shelterbelt Irrigation and troughs"
enable_switch: "Enable Shelterbelt Irrigation"
name: "Shelterbelt Irrigation Irrigation"
initial_value: 60
min_value: 10
max_value: 120
valve_switch_id: shelterbelt_irrigation_sw
- valve_switch: "Impact Irrigation"
enable_switch: "Enable Impact Irrigation"
name: "Impact Irrigation Irrigation"
initial_value: 70
min_value: 10
max_value: 120
valve_switch_id: impact_irrigation_sw
- valve_switch: "Garden Irrigation"
enable_switch: "Enable Garden Irrigation"
name: "Garden Irrigation Duration"
initial_value: 30
min_value: 10
max_value: 120
valve_switch_id: garden_irrigation_sw
- valve_switch: "Tank Filler"
enable_switch: "Enable Tank Filler"
run_duration: 3600s
valve_switch_id: tank_filler_sw
switch:
- platform: gpio
pin: GPIO04
- platform: gpio
pin: GPIO05
- platform: gpio
pin: GPIO12
- platform: gpio
pin: GPIO14
- platform: gpio
pin: GPIO02
- platform: gpio
pin: GPIO09
- platform: gpio
pin: GPIO10
uart:
tx_pin: D8
rx_pin: D7
baud_rate: 9600
