Hello together,
if I would like to use HA new longterm statistics with sensors from esphome, e. g. room temperature and so on do I have to add state_class and so in my esphome yaml files for each sensor which I define there?
Hello together,
You shouldn’t have to do anything to be able to use it with long term stats.
Have a look at the sensor attributes in Developer Tools / States. Does it have these attributes?
state_class: measurement
unit_of_measurement: °C # or F
friendly_name: Something
icon: mdi:thermometer
device_class: temperature
yes
friendly_name: 1OG_MobiUM2 Temp
Then there is nothing for you to do. It will just work. Try the statistics graph.
THX works for some of my esp sensors:
in some cases I only get
friendly_name: 1OG Balkon Temp
without state_class and I cannot add them in the statistic
some other of the sensors connected to the same device show:
unit_of_measurement: µg/m³
friendly_name: 1OG Balkon Partikel <10.0µm µg/m³
icon: mdi:chemical-weapon
and work fine with the statistic.
What can I do?
Best regards,
Stefan
When was the last time you updated those ESP boards?
THX,
I updated all devices to last Version.
Now everything is fine.
Best regards,
Stefan
