I use esphome with time based cover.
Is it possible for making a return of the position?
Hello
you might find more help here… ESPHome - Smart Home Made Simple — ESPHome or in the EspHome Discord
First things first. Post your configuration so we can see what you’re doing and it would also be helpful to know if and what kind of door position sensors you’re using like a reed switch, 2x reed switches, rotary encoder, voltage/current meter etc as an example.
cover:
- platform: time_based
name: "Menger badkamer"
open_action:
- switch.turn_on: I2Cout2_4
open_duration: 140sec
close_action:
- switch.turn_on: I2Cout2_5
close_duration: 140sec
stop_action:
- switch.turn_off: I2Cout2_4
- switch.turn_off: I2Cout2_5
manual_control: True
I want to copy the poition into a number.
But where can i find the poisiton?
- number.set:
value: !lambda |-
return id(rolluik3).position * 100 //position is value 0.0-1.0
You really gotta use the Esphome documentation. It answers almost all of your questions and so much more.
hey, this doesn’t works for me
cover:
device_class: damper
open_action:
then:
- switch.turn_on: klepopen
open_duration:
seconds: 140
close_action:
then:
- switch.turn_on: klepdicht
close_duration:
seconds: 140
stop_action:
then:
- switch.turn_off: klepdicht
- switch.turn_off: klepopen
button:
- platform: restart
on_press:
then:
- script.execute: standklepcontroleren
script:
- id: standklepcontroleren
then:
- number.set:
value: !lambda |-
return id(drieweg).tilt * 100;
number:
min_value: 0
max_value: 10000
step: 0.01
optimistic: True
restore_value: True
unit_of_measurement: '%'
I’ll get all the time ‘0’ when I press the button
does time_based cover have .tilt?
