Hey everyone,
I ran into this weird situation today. I have 3 devices connected to a WiFi AP - 2 of which are esp32c3 mmwave occupancy sensors and the other one’s a esp32s3 relay. The power to the site was down for a couple mins earlier today and so all devices had to reconnect with the AP (even the main router restarted after the power failure so all ip addresses were reset). The relay was pretty quick to connect, but I’m not sure what’s going on with the mmwaves. I see the values - but they’re not changing. It’s still. The values ALWAYS change every few secs. HA doesn’t even show them as Unavailable. So weird.
Here’s the esphome yaml for one of the mmwave sensors (the other’s is pretty much the same - just the name change):
substitutions:
friendly_name: "mmwave1"
esphome:
friendly_name: "${friendly_name}"
name_add_mac_suffix: true
project:
version: "1.0"
platformio_options:
board_build.flash_mode: dio
board_build.mcu: esp32c3
# external_components:
# - source: github://limengdu/mmwave-kit-external-components@main
# refresh: 0s
esp32:
board: esp32-c3-devkitm-1
variant: esp32c3
framework:
type: esp-idf
# Enable logging
logger:
hardware_uart: USB_SERIAL_JTAG
level: DEBUG
ota:
- platform: esphome
mqtt:
broker: 192.168.0.250
username: user
password: user123
discovery_unique_id_generator: mac
wifi:
reboot_timeout: 20s
ssid: "wifi1"
password: "passwd1"
fast_connect: True
power_save_mode: none
captive_portal:
uart:
baud_rate: 115200
rx_pin: 4
tx_pin: 5
parity: NONE
stop_bits: 1
seeed_mr24hpc1:
text_sensor:
- platform: seeed_mr24hpc1
heart_beat:
product_model:
product_id:
hardware_model:
hardware_version:
keep_away:
name: "Active Reporting Of Proximity"
motion_status:
name: "Motion Information"
custom_mode_end:
name: "Custom Mode Status"
binary_sensor:
has_target:
name: "Presence Information"
custom_presence_of_detection:
name: "Static Distance"
movement_signs:
name: "Body Movement Parameter"
custom_motion_distance:
name: "Motion Distance"
custom_spatial_static_value:
custom_spatial_motion_value:
custom_motion_speed:
custom_mode_num:
name: "Current Custom Mode"
switch:
underlying_open_function:
name: Underlying Open Function Info Output Switch
button:
restart:
custom_set_end:
name: "End Of Custom Mode Settings"
select:
scene_mode:
unman_time:
name: "Time For Entering No Person State (Standard Function)"
existence_boundary:
name: "Existence Boundary"
motion_boundary:
name: "Motion Boundary"
number:
sensitivity:
custom_mode:
existence_threshold:
name: "Existence Energy Threshold"
motion_threshold:
name: "Motion Energy Threshold"
motion_trigger:
name: "Motion Trigger Time"
motion_to_rest:
name: "Motion To Rest Time"
custom_unman_time:
name: "Time For Entering No Person State (Underlying Open Function)"
And here’s the relay yaml:
esphome:
esp32:
board: esp32-s3-devkitc-1
flash_size: 8MB
framework:
type: arduino
# Enable logging
logger:
level: DEBUG
ota:
- platform: esphome
preferences:
flash_write_interval: 20s
mqtt:
username: user
password: user123
wifi:
reboot_timeout: 20s
ssid: "wifi1"
password: "passwd1"
fast_connect: True
binary_sensor:
- platform: status
- platform: gpio
pin:
number: 0
ignore_strapping_warning: true
mode:
input: true
inverted: true
disabled_by_default: true
on_press:
then:
- button.press: restart_button
switch:
- platform: gpio
pin: GPIO1
restore_mode: RESTORE_DEFAULT_ON
- platform: gpio
pin: GPIO2
- platform: gpio
pin: GPIO41
- platform: gpio
pin: GPIO42
- platform: gpio
pin:
number: GPIO45
- platform: gpio
pin:
number: GPIO46
uart:
- id: modbus_uart
tx_pin: GPIO17
rx_pin: GPIO18
baud_rate: 9600
# buzzer
output:
- platform: ledc
pin: GPIO21
rtttl:
output: buzzer
gain: 30%
light:
- platform: neopixelbus
type: RGB
variant: 800KBPS
pin: GPIO38
num_leds: 1
button:
- platform: restart
entity_category: config
- platform: factory_reset
- platform: safe_mode
internal: false
Don’t bother commenting if you all you’re going to do is to suggest using a static ip/reserve dhcp. I know very well how important/useful that is. At the moment, I do not have access to router settings to know what its dhcp pool is/check list of connected devices. I will soon though. Until then, I’m curious to know why this is happening. Shouldn’t the mmwaves auto connect, like the relay did? Is there something in the yaml that’s making it not auto connect? And if it didn’t auto connect, why does it not show as Unavailable on HA? Stuff like this I find super annoying since it seems so random at first as to why this could be happening. The router had rebooted many times before and never has such a thing happened.
