Hello everybody,
My Name is Dan and new here on the forum but not new in ESPhome and Hass. For quite some time i have been building sensors and more to connect with Hass.
Now i’m ussing the weak points of the ESPhome as an alarm trigger. When multiple devices are disconnected from Wifi or when Wifi is jammed.
So i build an ESP8266 with a 136db sirene, colour led and its own powersuply.
My goal is that when the sirene is disconnected from Wifi( Jammed) or gets stolen. The sirene goes off.
The problem now is that when there is a Wifi glitch, the siren goes off. Can’t figure out what code off Yaml is best for this to fix a delay or reset wifi.
wifi:
ssid: !secret wifi_ssid
min_auth_mode: wpa2
# Turn on Alarm when disconnected from Wifi to avoid jamming and theft
on_disconnect:
- delay:
30s
- switch.turn_on:
ap:
ssid: "Alarm Fallback Hotspot"
password: "xxxxxxxxx"
captive_portal:
switch:
- platform: gpio
pin: GPIO5
icon: mdi:volume-high
restore_mode: RESTORE_DEFAULT_OFF
on_turn_on: # sirine active time
- delay: 30s
- switch.turn_off: sirene
icon: mdi:alarm-light-outline
optimistic: true
entity_category: config
on_turn_on:
then:
- light.turn_on:
effect: pulse
brightness: 100%
red: 0%
green: 0%
blue: 100%
# - switch.turn_on:
# id: sirene
on_turn_off:
then:
- light.turn_off: activity_led
# - switch.turn_off:
# id: sirene
icon: mdi:fire-alert
optimistic: true
on_turn_on:
then:
- light.turn_on:
effect: pulse
brightness: 100%
red: 100%
green: 0%
blue: 0%
- switch.turn_on:
on_turn_off:
then:
- switch.turn_off:
optimistic: true
on_turn_on:
then:
- light.turn_on:
effect: pulse
brightness: 100%
red: 40%
green: 30%
blue: 10%
- switch.turn_on:
on_turn_off:
then:
- switch.turn_off:
# Configure LED
light:
- platform: neopixelbus
variant: WS2812
pin: GPIO4
num_leds: 8
flash_transition_length: 500ms
type: GRB
restore_mode: ALWAYS_OFF #normal OFF
effects:
- pulse
- pulse:
transition_length: 1s
update_interval: 0.5s
min_brightness: 0%
max_brightness: 100%
Hass Rapberry pi 5
Wifi Ruckus zonedrirector
