ESPHome with display. Linking a button to home Assistant light
Hi
I’ve got myself a couple of Guition 4848S040 displays and fairly quickly got OpenHasp working on one with screen buttons able to control lights and cover in HA.
I then tried to do the same with Tasmota and although I got stuff on the display, got nowhere trying to link to HA!
I’m now trying with ESPHome. I’ve loaded the example code given for the Guition display found here.
I don’t know a lot about ESPHome and am having trouble finding an example of linking a simple on/off light (light.light_switch_lounge_main) already in HA to the button in the sample code (lv_button_1).
I tried, as a starter, the following entry:
binary_sensor:
  - platform: homeassistant
    entity_id: light.light_switch_lounge_main
    on_state:
      then:
        if:
          condition:
            lambda: 'return Lounge_Main_Light.state = "on";'
          then:
            - lvgl.widget.update:
                text_color: 0xFFFF00
                state:
                  checked: true
          else:
                text_color: 0xB6B6B6
                state:
                  checked: false
but whilst it validates ok, it fails to compile with the error:
/config/esphome/display-4848s040.yaml: In lambda function:
/config/esphome/display-4848s040.yaml:141:14: error: 'Lounge_Main_Light' was not declared in this scope
  141 |             lambda: 'return Lounge_Main_Light.state = "on";'
Maybe I’m trying to use it before it’s fully defined!
Any help appreciated.
I persevered and got it working (almost perfectly!)
This snippet creates the binary sensor in ESPHome from the actual light in HA and updates the button and its lightbulb icon colours.
binary_sensor:
    name: "Lounge Main Light"
    on_state:
      then:
        if:
          condition:
            binary_sensor.is_on: lounge_main_light
          then:
                state:
                  checked: true
          else:
                state:
                  checked: false
This snippet creates the button and triggers a toggle for the internal_light.
lvgl:
  pages:
      widgets:
        - button:
            height: 223
            checkable: true
            widgets:
              - label:
                  text_font: light40
                  align: top_left
                  text: $lightbulb
              - label:
                  align: bottom_left
                  text: "Center Light"
                  long_mode: dot
            on_click:
              light.toggle: internal_light
And lastly, this snippet creates the internal_light and sets up the actions when the screen button is pressed. Apparently, I should be using action terminology as services have been renamed as such in HA, but I just copied a real life example I found in the forum rather than those cryptic examples given in the docs!
light:
  - platform: binary
    output: internal_relay_1
    on_turn_on:
      then:
        homeassistant.service:
          service: light.turn_on
    on_turn_off:
      then:
          service: light.turn_off
I say it ‘almost works’ because it reacts properly when the light is turned on/ff in HA and when turned on/off with the button in ESPHome. Except when turned on in HA and the off from ESPHome. In that case the button shows it as having gone off but the light stays on. A second press briefly brings the button light back on but the actual light does go off followed by the button light. Does that make sense?
Any clues anyone?
For some reason, the example of doing this state change from the ESPHome LVGL cookbook uses a text sensor:
text_sensor:
    entity_id: light.remote_light
    on_value:
      then:
            state:
              checked: !lambda return (0 == x.compare(std::string{"on"}));
              disabled: !lambda return ((0 == x.compare(std::string{"unavailable"})) or (0 == x.compare(std::string{"unknown"})));
        - lvgl.label.update:
            text: !lambda |-
              static char buf[10];
              std::string icon;
              if (0 == x.compare(std::string{"on"})) {
                  icon = "\U000F0335";
              } else {
                  icon = "\U000F0336";
              snprintf(buf, sizeof(buf), "%s", icon.c_str());
              return buf;
This is what I copied for my display and it works fine. The use of lambda for state checking is not something I would normally do either, but it works.
Thanks, I’ll give it a go to see if it works 100%.
  on_value:
        state:
          checked: !lambda return x == "on";
          disabled: !lambda return x == "unavailable" || x == "unknown";
        text:
          format: "%s"
          args: ['x == "on" ? "\U000F0335" : "\U000F0336"']
Hello, I can’t get this example to work. I’m not a programmer. I would be grateful for any help. The output component is reporting an error.
INFO ESPHome 2025.12.0-dev
INFO Reading configuration /config/esphome/zentraleinheit01.yaml...
INFO Detected timezone 'Europe/Vienna'
Failed config
light.binary: [source /config/esphome/zentraleinheit01.yaml:458]
  'output' is a required option for [light.binary].
  platform: binary
  on_turn_on:
    then:
      homeassistant.action:
          entity_id: light.tischzentrale01
  on_turn_off:
    then:
Here is my current configuration.
binary_sensor:
#text_sensor:?
######### für licht remote button
#    widget: light_btn01
#    trigger_on_initial_state: true
#    publish_initial_state: true # wird entfernt
    on_state:
      then:
        if:
          condition:
            binary_sensor.is_on: tischzentrale01_button01
          then:
                state:
                  checked: true
          else:
                state:
                  checked: false
output:
  - platform: ledc
    pin: GPIO22
    frequency: 1000Hz
########## für licht ??????
#  - platform: template
#    id: remote_relay01
#    type: float
#    write_action:
#      if:
#        condition:
#          light.is_on: remote_light01
#        then:
#          - light.turn_on: tischzentrale01_button01
#        else:
#          - light.turn_off: tischzentrale01_button01
light:
########## für licht neu
  - platform: binary
    output: remote_relay01
    on_turn_on:
      then:
    on_turn_off:
      then:
lvgl: #...sniped
        - button:
            height: 223
            checkable: true
            widgets:
              - label:
                  #text_font: light40
                  align: top_left
                  text: $lightbulb
              - label:
                  align: bottom_left
                  long_mode: dot
            on_click:
              light.toggle: remote_light01
