Esphome with epaper
I am having an issue getting my epaper display to work properly.
I am trying to just get date calendar to print , it showed me last night “No data available” , but then I went to bed, and this morning I found that it is showing me the proper calendar date. My thinking is that when I deploy the code to it, it doesn’t get the values from home assistant right away so values are empty, but it gets values few seconds after it refresh the screen. Later on, when screen refresh it grabs the values. Is there a way to make sure the values refresh when I deploy the code? it is making it hard for me to troubleshoot and continue dev on it without seeing the results right away.
This is my code (I tried to add a screen update on value, but it isn’t working)
esphome:
  platform: esp32
  board: esp32dev
  on_boot:
    priority: 600
    then:
      - script.execute: update_screen  #
      - delay: 15s  # Add a small delay to ensure all sensors are ready
      - script.execute: update_screen  # Trigger again to ensure update
# Wi-Fi configuration
wifi:
  ssid: "ddar4"
  password: "xxxx"
  ap:
    ssid: "esphomeddar4"
    password: "xxxx"
# Enable logging, API, and OTA updates
logger:
api:
  encryption:
    key: "xxxxx"
ota:
  platform: esphome
script:
  - id: update_screen
    then:
      - component.update: eink_display
time:
  - platform: sntp
    on_time:
      - seconds: 0
        minutes: 0
        hours: 0
        then:
          - script.execute: update_screen  # ✅ Refresh at midnight
      - seconds: 0
        minutes: 0
        hours: 8
        days_of_week: MON-SUN
        then:
          - script.execute: update_screen  # ✅ Refresh every morning
      - seconds: 0
        minutes: 0
        hours: 16
        then:
          - script.execute: update_screen  # ✅ Refresh in the afternoon
spi:
  clk_pin: 13
  mosi_pin: 14
font:
  - file: "fonts/GothamRnd-Book.ttf"
  - file: "fonts/GothamRnd-Bold.ttf"
text_sensor:
  # Date from Home Assistant
  - platform: homeassistant
    entity_id: sensor.current_day_name
    on_value:
      then:
    entity_id: sensor.current_day_number
    on_value:
      then:
    entity_id: sensor.current_month
    on_value:
      then:
  # Calendar Events
    entity_id: sensor.esp_calendar_data
    attribute: event_title_1
    attribute: event_start_1
    attribute: event_title_2
    attribute: event_start_2
display:
  - platform: waveshare_epaper
    cs_pin: 15
    dc_pin: 27
    busy_pin: 25
    reset_pin: 26
    reset_duration: 2ms
    model: 7.50inv2
    rotation: 270°
    update_interval: never
    lambda: |-
      ESP_LOGI("display", "Updating ePaper Calendar...");
      it.fill(Color(0, 0, 0));
      if (id(current_day_name).has_state() &&
          id(current_day_number).has_state() &&
          id(current_month).has_state()) {
        std::string formatted_date = id(current_day_name).state + " " +
                                      id(current_day_number).state + " " +
                                      id(current_month).state;
        ESP_LOGI("display", "Formatted Date: %s", formatted_date.c_str());
        it.printf(240, 40, id(bold30), TextAlign::CENTER, "%s", formatted_date.c_str());
      } else {
        ESP_LOGE("display", "Date sensors missing!");
        it.printf(240, 40, id(bold30), TextAlign::CENTER, "No Date Available");
      // Step 2: Draw a Horizontal Line
      it.filled_rectangle(50, 90, 380, 2);
Just so I can troubleshoot, I put the update_interval to 5s , and after I did it showed the date properly. Is it possible to ask it to not refresh the screen after I deploy the code but to wait 60 seconds before first refresh?
