Hi ,
I use midea_mini_dongle and it works perfect on home assistant , but when I try to turn on the aircon via the HomeKit app nothing happened, I hear the AC beeping it doesn’t turn on .( I can use it to turn off)
The issue was started when the fan speed bar added , can you help me to solve this issue ?
This is not a homekit forum. If you use home assistant someone may be able to help you.
Yes sure , I mean in the home assistant ui everything work but in the home assistant ( integration ) it’s not …
seems contrary to
“Homekit” home-assistant integration , now its clear?
I think I see now. Logs?
