ESPHome with SCD4X and calibration button: Sensor doesn't inherit from scd4x
Hi all,
I’m currently implementing a combined temp/hum and co2 sensor with ePaper display, based on LilyGo T5-4.7 Plus (ESP32-S3), BME280 and a SCD40 CO2 sensor.
Now i want a button that I can press in HA to force recalibration of the CO2 sensor.
Here’s my current code:
esphome:
  friendly_name: Multi-Sensor-Display SchlafZi
  platformio_options:
    board: lilygo-t5-47-plus
    board_dir: boards
esp32:
  variant: esp32s3
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: !secret home_assistant_encryption_key
ota:
  password: !secret ota_password
wifi:
  networks:
    - ssid: !secret wifi_ssid
  reboot_timeout: 15min
  ap:
    ssid: Multi-Sensor-Display-SchlafZi
    password: !secret fallback_ssid_password
mqtt:
  broker: <removed>
  username: <removed>
  password: !secret mqtt_password
  client_id: multi-sensor-display-schlafzi
external_components:
  # https://github.com/nickolay/esphome-lilygo-t547plus
  - source: github://nickolay/esphome-lilygo-t547plus
    components: ["t547"]
#deep_sleep:
#  run_duration: 30s
#  sleep_duration: 1min
i2c:
  - id: bus_a
    sda: GPIO17
    scl: GPIO18
    #frequency: 10khz
    # There is some problems with i2c scan so turn scan off if problem appear on your board
    scan: False
  # BME 280 temp/hum sensor
  - platform: bme280
    temperature:
      #oversampling: 16x
      device_class: temperature
      unit_of_measurement: "°C"
      accuracy_decimals: 1
    #pressure:
    #  name: "BME280 Pressure"
    humidity:
      device_class: humidity
      unit_of_measurement: "%"
    address: 0x76
    i2c_id: bus_a
    update_interval: 60s
  # SCD40 CO2 sensor
  - platform: scd4x
    co2:
      device_class: carbon_dioxide
      unit_of_measurement: "ppm"
      accuracy_decimals: 0
    altitude_compensation: 500m
    address: 0x62
    i2c_id: bus_a
button:
    name: "CO2 manual calibration (only in fresh air for at least 20min)"
    entity_category: "config"
    on_press:
      then:
      - scd4x.perform_forced_calibration:
          value: 419
time:
  - platform: homeassistant
    timezone: Europe/Berlin
In the button section “co2” is unerlined red and says:
ID ‘co2’ of type sensor::Sensor doesn’t inherit from scd4x::SCD4XComponent. Please double check your ID is pointing to the correct value.
ID “co2” is assigned to the co2 component of platform scdx4, so I don’t understand why gives an error on the button…
Can anyone help? Do I have an error in my brain :laughing: or is this a bug?
Thanks, Matthias
Oh d**n it…
Easy solution:
button:
    on_press:
      then:
          value: 419
          #id: co2
Not setting an ID does what I want. Works now, I think I misunderstood the docs in this point…
