Hi I have installed esphome on a esp32 vroom c3 and installed a water meter yaml and connected a sensor , everything works perfectly but there are more pins that are not used, I want to connect 2 relais and a door sensor on it . But is it wise to do that becose the watermeter part is sending data every 2 a 3 seconds , don’t want to make things to difficult for the esp
Shall I put a second esp beside this one or shall I connect the extra parts and change the yaml and everything shall work ( if I do it right afcourse haha ) meby someone have tips?
With kind regards
Bob
