The devices ( yaml code) have not all disappeared in the esp home. They all still work and in the homeassistant gui they are all present and the measured values are displayed. But I can no longer see or edit the yaml code. I use the latest version
These two statements are opposite:
Try explaining again. You can drag and drop screenshots here if it helps.
Do the yaml files still exist in config/esphome?
Try restarting the ESPHome Builder add-on.
If that does not help then try clearing your web browser or app frontend cache.
Both tested, nothing helps
Any idea?
Try restarting base OS where HA is installed ( HAOS, Pi, VM…). Not just HA core restart, but base system restart.
Same as before
Check the add-on logs.
Try a PC instead of your phone.
Also on the pc the same ( cache cleared)
Esphome addon deinstalled / new installed
Still the same problem
I have a vague memory this happened to me also.
I believe I just uninstalled ESP-Home and then installed it again.
But I’m not sure. I remember it being not a restart needed, it was something more but it just worked when I did it.
Make a backup before you do, and at least you can get back to this state.
What do the addon logs say?
Found this thread:
Empty ESPHome window, missing devices - ESPHome - Home Assistant Community
when i uninstall esp home and install it again i see the device entries (yamol code) for a short moment but after a short time they disappear again.
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/30-esphome-fork.sh
cont-init: info: /etc/cont-init.d/30-esphome-fork.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service esphome: starting
s6-rc: info: service esphome successfully started
[07:18:42] INFO: [32mStarting ESPHome dashboard… [0m
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service discovery: starting
[07:18:42] INFO: [32mWaiting for ESPHome dashboard to come up… [0m
2025-06-10 07:18:43,595 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome…
[07:18:43] INFO: [32mStarting NGINX… [0m
2025-06-10 07:18:43,896 INFO 200 GET /devices (0.0.0.0) 1.42ms
[07:18:44] INFO: [32mSuccessfully send discovery information to Home Assistant. [0m
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
2025-06-10 07:23:43,389 INFO 200 GET /devices (0.0.0.0) 3.32ms
2025-06-10 07:26:51,601 INFO 200 GET / (0.0.0.0) 16.38ms
2025-06-10 07:26:51,753 INFO 200 GET /static/fonts/material-icons/material-icons.css?hash=ead4c276 (0.0.0.0) 7.59ms
2025-06-10 07:26:51,816 INFO 200 GET /static/css/esphome-2.css?hash=b92d56a2 (0.0.0.0) 2.10ms
2025-06-10 07:26:51,893 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2?hash=570eb838 (0.0.0.0) 2.90ms
2025-06-10 07:26:51,897 INFO 200 GET /static/js/esphome/index-D2ez82lt.js (0.0.0.0) 16.85ms
2025-06-10 07:26:52,243 INFO 200 GET /devices (0.0.0.0) 2.05ms
2025-06-10 07:26:52,247 INFO 200 GET /static/images/logo-text.svg (0.0.0.0) 1.54ms
2025-06-10 07:26:52,273 INFO 200 GET /static/js/esphome/c.LrLk5ueh.js (0.0.0.0) 25.93ms
2025-06-10 07:26:52,449 INFO 101 GET /compile (0.0.0.0) 1.24ms
2025-06-10 07:26:52,605 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/air-quality.yaml’
2025-06-10 07:26:53,748 INFO Process exited with return code 0
2025-06-10 07:26:53,783 INFO 200 GET /static/js/esphome/c.CsuD-Bo9.js (0.0.0.0) 3.67ms
2025-06-10 07:26:53,805 INFO 200 GET /static/js/esphome/c.DaYIS3VI.js (0.0.0.0) 1.29ms
2025-06-10 07:26:53,808 INFO 200 GET /static/js/esphome/c.poAaLtz1.js (0.0.0.0) 2.08ms
2025-06-10 07:26:54,004 INFO 101 GET /compile (0.0.0.0) 0.96ms
2025-06-10 07:26:54,035 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/bewasserung.yaml’
2025-06-10 07:26:54,384 INFO Process exited with return code 2
2025-06-10 07:26:54,544 INFO 101 GET /compile (0.0.0.0) 1.18ms
2025-06-10 07:26:54,615 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/dallastemp.yaml’
2025-06-10 07:26:54,894 INFO Process exited with return code 2
2025-06-10 07:26:55,071 INFO 101 GET /compile (0.0.0.0) 1.05ms
2025-06-10 07:26:55,098 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/hydrophonic.yaml’
2025-06-10 07:26:55,438 INFO Process exited with return code 0
2025-06-10 07:26:55,648 INFO 101 GET /compile (0.0.0.0) 0.81ms
2025-06-10 07:26:55,691 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/maba1.yaml’
2025-06-10 07:26:56,032 INFO Process exited with return code 0
2025-06-10 07:26:56,218 INFO 101 GET /compile (0.0.0.0) 1.17ms
2025-06-10 07:26:56,262 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/pflanzensensor.yaml’
2025-06-10 07:26:56,907 INFO Process exited with return code 0
2025-06-10 07:26:57,087 INFO 101 GET /compile (0.0.0.0) 1.19ms
2025-06-10 07:26:57,137 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/plantsensor.yaml’
2025-06-10 07:26:57,228 INFO 200 GET /devices (0.0.0.0) 2.40ms
2025-06-10 07:26:57,479 INFO Process exited with return code 0
2025-06-10 07:26:57,655 INFO 101 GET /compile (0.0.0.0) 1.14ms
2025-06-10 07:26:57,690 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/tanne.yaml’
2025-06-10 07:26:58,166 INFO Process exited with return code 0
2025-06-10 07:27:02,265 INFO 200 GET /devices (0.0.0.0) 5.06ms
2025-06-10 07:27:02,949 INFO 200 GET /edit?configuration=pflanzensensor.yaml (0.0.0.0) 2.87ms
2025-06-10 07:27:03,027 INFO 200 GET /static/js/esphome/monaco-editor/esm/vs/editor/editor.worker.js (0.0.0.0) 3.19ms
2025-06-10 07:27:03,319 INFO 101 GET /ace (0.0.0.0) 1.08ms
2025-06-10 07:27:03,522 INFO Running command ‘esphome --dashboard -q vscode --ace /config/esphome’
2025-06-10 07:27:03,533 INFO 200 GET /static/fonts/codicon.ttf (0.0.0.0) 3.26ms
2025-06-10 07:27:11,492 INFO 304 GET /devices (0.0.0.0) 1.08ms
2025-06-10 07:27:16,487 INFO 304 GET /devices (0.0.0.0) 2.87ms
2025-06-10 07:27:21,537 INFO 304 GET /devices (0.0.0.0) 13.32ms
2025-06-10 07:27:26,504 INFO 304 GET /devices (0.0.0.0) 2.93ms
2025-06-10 07:27:31,505 INFO 304 GET /devices (0.0.0.0) 2.94ms
2025-06-10 07:27:37,391 INFO 304 GET /devices (0.0.0.0) 1.11ms
2025-06-10 07:27:43,429 INFO 304 GET /devices (0.0.0.0) 3.37ms
2025-06-10 07:27:49,373 INFO 304 GET /devices (0.0.0.0) 2.92ms
2025-06-10 07:27:55,366 INFO 304 GET /devices (0.0.0.0) 2.80ms
2025-06-10 07:28:01,389 INFO 304 GET /devices (0.0.0.0) 5.00ms
2025-06-10 07:28:07,393 INFO 304 GET /devices (0.0.0.0) 3.40ms
2025-06-10 07:28:12,450 INFO 304 GET /devices (0.0.0.0) 6.22ms
2025-06-10 07:28:18,383 INFO 304 GET /devices (0.0.0.0) 1.09ms
2025-06-10 07:28:24,377 INFO 304 GET /devices (0.0.0.0) 5.11ms
2025-06-10 07:28:30,390 INFO 304 GET /devices (0.0.0.0) 1.07ms
2025-06-10 07:28:36,386 INFO 304 GET /devices (0.0.0.0) 2.51ms
2025-06-10 07:28:42,385 INFO 304 GET /devices (0.0.0.0) 2.55ms
2025-06-10 07:28:43,391 INFO 200 GET /devices (0.0.0.0) 3.19ms
2025-06-10 07:28:47,529 INFO 304 GET /devices (0.0.0.0) 2.71ms
2025-06-10 07:28:53,382 INFO 304 GET /devices (0.0.0.0) 2.95ms
2025-06-10 07:28:58,375 INFO 304 GET /devices (0.0.0.0) 3.02ms
2025-06-10 07:29:03,424 INFO 304 GET /devices (0.0.0.0) 3.46ms
2025-06-10 07:29:09,382 INFO 304 GET /devices (0.0.0.0) 1.08ms
2025-06-10 07:29:15,375 INFO 304 GET /devices (0.0.0.0) 2.90ms
2025-06-10 07:29:25,325 INFO 304 GET /devices (0.0.0.0) 2.59ms
2025-06-10 07:29:32,416 INFO 304 GET /devices (0.0.0.0) 1.61ms
2025-06-10 07:29:40,428 INFO 304 GET /devices (0.0.0.0) 2.96ms
2025-06-10 07:29:46,328 INFO 304 GET /devices (0.0.0.0) 2.00ms
2025-06-10 07:29:54,486 INFO 304 GET /devices (0.0.0.0) 2.63ms
2025-06-10 07:30:00,462 INFO 304 GET /devices (0.0.0.0) 2.89ms
2025-06-10 07:30:06,452 INFO 304 GET /devices (0.0.0.0) 2.94ms
2025-06-10 07:30:15,210 INFO 304 GET /devices (0.0.0.0) 3.09ms
2025-06-10 07:30:26,293 INFO 304 GET /devices (0.0.0.0) 2.72ms
2025-06-10 07:30:31,348 INFO 304 GET /devices (0.0.0.0) 1.59ms
2025-06-10 07:30:37,284 INFO 304 GET /devices (0.0.0.0) 2.41ms
2025-06-10 07:30:45,504 INFO 304 GET /devices (0.0.0.0) 0.95ms
2025-06-10 07:30:57,251 INFO 304 GET /devices (0.0.0.0) 3.10ms
2025-06-10 07:31:07,020 INFO 304 GET /devices (0.0.0.0) 2.13ms
2025-06-10 07:31:16,652 INFO 304 GET /devices (0.0.0.0) 2.51ms
2025-06-10 07:31:24,215 INFO 304 GET /devices (0.0.0.0) 5.51ms
2025-06-10 07:31:33,563 INFO 304 GET /devices (0.0.0.0) 2.52ms
2025-06-10 07:31:41,613 INFO 304 GET /devices (0.0.0.0) 2.56ms
2025-06-10 07:31:51,499 INFO 304 GET /devices (0.0.0.0) 4.08ms
2025-06-10 07:31:57,262 INFO 304 GET /devices (0.0.0.0) 1.22ms
2025-06-10 07:32:08,456 INFO 304 GET /devices (0.0.0.0) 2.95ms
2025-06-10 07:32:21,565 INFO 304 GET /devices (0.0.0.0) 1.50ms
2025-06-10 07:32:27,577 INFO 304 GET /devices (0.0.0.0) 2.62ms
2025-06-10 07:32:33,466 INFO 304 GET /devices (0.0.0.0) 3.81ms
2025-06-10 07:32:45,347 INFO 304 GET /devices (0.0.0.0) 1.13ms
2025-06-10 07:32:51,932 INFO 304 GET /devices (0.0.0.0) 1.10ms
2025-06-10 07:32:58,430 INFO 304 GET /devices (0.0.0.0) 2.60ms
2025-06-10 07:33:09,665 INFO 304 GET /devices (0.0.0.0) 2.90ms
2025-06-10 07:33:22,299 INFO 304 GET /devices (0.0.0.0) 1.14ms
2025-06-10 07:33:28,857 INFO 304 GET /devices (0.0.0.0) 3.51ms
2025-06-10 07:33:39,024 INFO 304 GET /devices (0.0.0.0) 1.57ms
2025-06-10 07:33:43,389 INFO 200 GET /devices (0.0.0.0) 3.01ms
2025-06-10 07:33:45,013 INFO 304 GET /devices (0.0.0.0) 2.89ms
2025-06-10 07:33:51,012 INFO 304 GET /devices (0.0.0.0) 2.54ms
2025-06-10 07:33:57,222 INFO 304 GET /devices (0.0.0.0) 2.51ms
2025-06-10 07:35:49,691 INFO 304 GET / (0.0.0.0) 1.73ms
2025-06-10 07:35:49,862 INFO 200 GET /devices (0.0.0.0) 3.01ms
2025-06-10 07:35:58,301 INFO 304 GET / (0.0.0.0) 2.61ms
2025-06-10 07:35:58,511 INFO 304 GET /devices (0.0.0.0) 2.90ms
2025-06-10 07:38:43,389 INFO 200 GET /devices (0.0.0.0) 2.95ms
2025-06-10 07:43:43,390 INFO 200 GET /devices (0.0.0.0) 4.54ms
2025-06-10 07:44:16,904 INFO 304 GET /devices (0.0.0.0) 3.12ms
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service discovery: stopping
s6-rc: info: service discovery successfully stopped
s6-rc: info: service nginx: stopping
[07:45:01] INFO: [32mService NGINX exited with code 0 (by signal 0) [0m
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service esphome: stopping
s6-rc: info: service init-nginx successfully stopped
[07:45:01] INFO: [32mService ESPHome dashboard exited with code 256 (by signal 15) [0m
s6-rc: info: service esphome successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-banner: starting
[34m----------------------------------------------------------- [0m
[34m Add-on: ESPHome Device Builder [0m
[34m Build your own smart home devices using ESPHome, no programming experience required. [0m
[34m Add-on version: 2024.12.4 [0m
[35m There is an update available for this add-on! [0m
[35m Latest add-on version: 2025.5.2 [0m
[35m Please consider upgrading as soon as possible. [0m
[34m System: Home Assistant OS 15.2 (amd64 / generic-x86-64) [0m
[34m Home Assistant Core: 2025.5.3 [0m
[34m Home Assistant Supervisor: 2025.05.3 [0m
[34m Please, share the above information when looking for help [0m
[34m or support in, e.g., GitHub, forums or the Discord chat. [0m
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
[07:45:32] INFO: [32mConfiguring timezone (Europe/Zurich)… [0m
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
[07:45:34] INFO: [32mStarting ESPHome dashboard… [0m
[07:45:34] INFO: [32mWaiting for ESPHome dashboard to come up… [0m
2025-06-10 07:45:34,853 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome…
[07:45:34] INFO: [32mStarting NGINX… [0m
2025-06-10 07:45:35,806 INFO 200 GET /devices (0.0.0.0) 1.64ms
[07:45:35] INFO: [32mSuccessfully send discovery information to Home Assistant. [0m
2025-06-10 07:48:18,001 INFO 200 GET / (0.0.0.0) 14.51ms
2025-06-10 07:48:18,215 INFO 200 GET /static/js/esphome/index-CjmNQrAE.js (0.0.0.0) 25.76ms
2025-06-10 07:48:18,619 INFO 200 GET /devices (0.0.0.0) 1.20ms
2025-06-10 07:48:18,715 INFO 200 GET /static/js/esphome/c.cX0mllH7.js (0.0.0.0) 25.66ms
2025-06-10 07:48:18,857 INFO 101 GET /compile (0.0.0.0) 1.45ms
2025-06-10 07:48:19,013 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/air-quality.yaml’
2025-06-10 07:48:19,860 INFO 200 GET /static/js/esphome/c.CA5FuP–.js (0.0.0.0) 2.42ms
2025-06-10 07:48:19,865 INFO 200 GET /static/js/esphome/c.C5Kj3QjI.js (0.0.0.0) 13.16ms
2025-06-10 07:48:19,867 INFO 200 GET /static/js/esphome/c.DmkbxwLf.js (0.0.0.0) 2.43ms
2025-06-10 07:48:20,018 INFO Process exited with return code 0
2025-06-10 07:48:20,181 INFO 101 GET /compile (0.0.0.0) 0.41ms
2025-06-10 07:48:20,235 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/bewasserung.yaml’
2025-06-10 07:48:20,652 INFO Process exited with return code 2
2025-06-10 07:48:20,923 INFO 101 GET /compile (0.0.0.0) 1.20ms
2025-06-10 07:48:20,981 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/dallastemp.yaml’
2025-06-10 07:48:21,363 INFO Process exited with return code 2
2025-06-10 07:48:21,547 INFO 101 GET /compile (0.0.0.0) 1.16ms
2025-06-10 07:48:21,708 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/hydrophonic.yaml’
2025-06-10 07:48:22,111 INFO 200 GET /edit?configuration=hydrophonic.yaml (0.0.0.0) 1.97ms
2025-06-10 07:48:22,130 INFO Process exited with return code 0
2025-06-10 07:48:22,339 INFO 101 GET /ace (0.0.0.0) 1.19ms
2025-06-10 07:48:22,377 INFO Running command ‘esphome --dashboard -q vscode --ace /config/esphome’
2025-06-10 07:48:22,521 INFO 101 GET /compile (0.0.0.0) 0.85ms
2025-06-10 07:48:22,572 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/maba1.yaml’
2025-06-10 07:48:22,984 INFO Process exited with return code 0
2025-06-10 07:48:23,177 INFO 101 GET /compile (0.0.0.0) 1.01ms
2025-06-10 07:48:23,226 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/pflanzensensor.yaml’
2025-06-10 07:48:23,869 INFO Process exited with return code 0
2025-06-10 07:48:24,077 INFO 101 GET /compile (0.0.0.0) 1.19ms
2025-06-10 07:48:24,116 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/plantsensor.yaml’
2025-06-10 07:48:24,539 INFO Process exited with return code 0
2025-06-10 07:48:24,715 INFO 101 GET /compile (0.0.0.0) 0.43ms
2025-06-10 07:48:24,747 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/tanne.yaml’
2025-06-10 07:48:25,292 INFO Process exited with return code 0
2025-06-10 07:48:26,949 INFO 200 GET /devices (0.0.0.0) 5.62ms
2025-06-10 07:48:31,945 INFO 304 GET /devices (0.0.0.0) 1.38ms
2025-06-10 07:50:09,120 INFO 304 GET / (0.0.0.0) 1.97ms
2025-06-10 07:50:09,271 INFO 304 GET /devices (0.0.0.0) 2.49ms
2025-06-10 07:50:14,267 INFO 304 GET /devices (0.0.0.0) 1.02ms
2025-06-10 07:50:19,277 INFO 304 GET /devices (0.0.0.0) 2.72ms
[07:50:33] INFO: [32mService NGINX exited with code 0 (by signal 0) [0m
[07:50:33] INFO: [32mService ESPHome dashboard exited with code 256 (by signal 15) [0m
s6-rc: info: service base-addon-timezone: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-timezone successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
[07:50:39] INFO: [32mStarting ESPHome dashboard… [0m
[07:50:40] INFO: [32mWaiting for ESPHome dashboard to come up… [0m
2025-06-10 07:50:41,095 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome…
[07:50:41] INFO: [32mStarting NGINX… [0m
2025-06-10 07:50:41,328 INFO 200 GET /devices (0.0.0.0) 1.40ms
[07:50:41] INFO: [32mSuccessfully send discovery information to Home Assistant. [0m
2025-06-10 07:50:42,475 INFO Updated air-quality with mdns version 2025.5.2 (was 2024.12.4)
2025-06-10 07:55:41,402 INFO 200 GET /devices (0.0.0.0) 4.26ms
2025-06-10 07:56:06,462 INFO 200 GET / (0.0.0.0) 14.86ms
2025-06-10 07:56:06,751 INFO 200 GET /devices (0.0.0.0) 2.94ms
2025-06-10 07:56:11,750 INFO 304 GET /devices (0.0.0.0) 3.04ms
2025-06-10 07:56:16,990 INFO 304 GET /devices (0.0.0.0) 2.53ms
2025-06-10 07:56:22,488 INFO 304 GET /devices (0.0.0.0) 2.52ms
2025-06-10 07:56:28,470 INFO 304 GET /devices (0.0.0.0) 2.87ms
2025-06-10 07:56:34,482 INFO 304 GET /devices (0.0.0.0) 0.92ms
2025-06-10 07:56:40,517 INFO 304 GET /devices (0.0.0.0) 1.38ms
2025-06-10 07:56:46,514 INFO 304 GET /devices (0.0.0.0) 1.24ms
2025-06-10 07:56:52,510 INFO 304 GET /devices (0.0.0.0) 2.49ms
2025-06-10 07:56:59,000 INFO 304 GET /devices (0.0.0.0) 2.84ms
2025-06-10 07:57:04,838 INFO 304 GET /devices (0.0.0.0) 2.87ms
2025-06-10 07:57:10,476 INFO 304 GET /devices (0.0.0.0) 2.89ms
2025-06-10 07:57:18,547 INFO 304 GET /devices (0.0.0.0) 2.80ms
2025-06-10 07:57:28,470 INFO 304 GET /devices (0.0.0.0) 4.27ms
2025-06-10 07:57:39,125 INFO 304 GET /devices (0.0.0.0) 1.30ms
2025-06-10 07:57:46,529 INFO 304 GET /devices (0.0.0.0) 2.91ms
2025-06-10 07:57:51,530 INFO 304 GET /devices (0.0.0.0) 2.77ms
2025-06-10 07:57:58,040 INFO 304 GET /devices (0.0.0.0) 4.56ms
2025-06-10 07:58:09,811 INFO 304 GET /devices (0.0.0.0) 2.42ms
2025-06-10 07:58:19,011 INFO 304 GET /devices (0.0.0.0) 3.04ms
2025-06-10 07:58:30,756 INFO 304 GET /devices (0.0.0.0) 1.53ms
2025-06-10 07:58:39,761 INFO 304 GET /devices (0.0.0.0) 3.08ms
2025-06-10 07:58:51,804 INFO 304 GET /devices (0.0.0.0) 2.92ms
2025-06-10 07:59:03,842 INFO 304 GET /devices (0.0.0.0) 2.87ms
2025-06-10 07:59:09,802 INFO 304 GET /devices (0.0.0.0) 2.61ms
2025-06-10 07:59:19,171 INFO 304 GET /devices (0.0.0.0) 2.93ms
2025-06-10 07:59:31,028 INFO 304 GET /devices (0.0.0.0) 2.89ms
2025-06-10 07:59:40,155 INFO 304 GET /devices (0.0.0.0) 3.22ms
2025-06-10 07:59:54,078 INFO 304 GET /devices (0.0.0.0) 5.27ms
2025-06-10 08:00:03,475 INFO 304 GET /devices (0.0.0.0) 2.92ms
2025-06-10 08:00:13,684 INFO 304 GET /devices (0.0.0.0) 2.58ms
2025-06-10 08:00:21,955 INFO 304 GET /devices (0.0.0.0) 2.87ms
2025-06-10 08:00:30,965 INFO 304 GET /devices (0.0.0.0) 3.01ms
2025-06-10 08:00:41,399 INFO 200 GET /devices (0.0.0.0) 2.90ms
2025-06-10 08:00:43,270 INFO 304 GET /devices (0.0.0.0) 1.14ms
2025-06-10 08:00:52,365 INFO 304 GET /devices (0.0.0.0) 4.55ms
2025-06-10 08:01:04,071 INFO 304 GET /devices (0.0.0.0) 2.65ms
2025-06-10 08:01:14,664 INFO 304 GET /devices (0.0.0.0) 0.98ms
2025-06-10 08:01:22,377 INFO 304 GET /devices (0.0.0.0) 2.57ms
2025-06-10 08:01:30,179 INFO 304 GET /devices (0.0.0.0) 2.94ms
2025-06-10 08:01:38,834 INFO 304 GET /devices (0.0.0.0) 1.03ms
2025-06-10 08:01:46,592 INFO 304 GET /devices (0.0.0.0) 3.42ms
2025-06-10 08:01:51,604 INFO 304 GET /devices (0.0.0.0) 7.61ms
2025-06-10 08:01:58,175 INFO 304 GET /devices (0.0.0.0) 2.49ms
2025-06-10 08:02:05,400 INFO 304 GET /devices (0.0.0.0) 2.48ms
2025-06-10 08:02:11,662 INFO 304 GET /devices (0.0.0.0) 2.64ms
2025-06-10 08:02:17,408 INFO 304 GET /devices (0.0.0.0) 1.43ms
2025-06-10 08:02:23,387 INFO 304 GET /devices (0.0.0.0) 1.11ms
2025-06-10 08:02:29,404 INFO 304 GET /devices (0.0.0.0) 6.96ms
2025-06-10 08:02:35,413 INFO 304 GET /devices (0.0.0.0) 2.00ms
2025-06-10 08:02:41,386 INFO 304 GET /devices (0.0.0.0) 1.07ms
2025-06-10 08:02:47,417 INFO 304 GET /devices (0.0.0.0) 2.49ms
2025-06-10 08:02:53,428 INFO 304 GET /devices (0.0.0.0) 2.71ms
2025-06-10 08:02:59,394 INFO 304 GET /devices (0.0.0.0) 2.94ms
2025-06-10 08:03:05,418 INFO 304 GET /devices (0.0.0.0) 3.16ms
2025-06-10 08:05:41,399 INFO 200 GET /devices (0.0.0.0) 2.97ms
2025-06-10 08:10:41,399 INFO 200 GET /devices (0.0.0.0) 2.58ms
2025-06-10 08:12:32,473 INFO 304 GET /devices (0.0.0.0) 2.90ms
2025-06-10 08:12:47,001 INFO 304 GET / (0.0.0.0) 1.97ms
2025-06-10 08:12:47,197 INFO 304 GET /devices (0.0.0.0) 3.19ms
2025-06-10 08:12:52,267 INFO 304 GET /devices (0.0.0.0) 2.91ms
2025-06-10 08:15:41,399 INFO 200 GET /devices (0.0.0.0) 2.72ms
[08:17:43] INFO: [32mService NGINX exited with code 0 (by signal 0) [0m
[08:17:43] INFO: [32mService ESPHome dashboard exited with code 256 (by signal 15) [0m
[08:19:21] INFO: [32mStarting ESPHome dashboard… [0m
[08:19:22] INFO: [32mWaiting for ESPHome dashboard to come up… [0m
2025-06-10 08:19:24,192 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome…
[08:19:24] INFO: [32mStarting NGINX… [0m
[08:19:25] INFO: [32mSuccessfully send discovery information to Home Assistant. [0m
2025-06-10 08:20:06,587 INFO 200 GET /devices (0.0.0.0) 2.51ms
2025-06-10 08:25:05,957 INFO 200 GET /devices (0.0.0.0) 2.98ms
2025-06-10 08:27:57,916 INFO 304 GET / (0.0.0.0) 9.84ms
2025-06-10 08:27:58,045 INFO 200 GET /devices (0.0.0.0) 3.49ms
2025-06-10 08:28:03,057 INFO 304 GET /devices (0.0.0.0) 2.61ms
2025-06-10 08:28:08,078 INFO 304 GET /devices (0.0.0.0) 2.77ms
2025-06-10 08:28:15,662 INFO 304 GET / (0.0.0.0) 1.56ms
2025-06-10 08:28:15,817 INFO 304 GET /devices (0.0.0.0) 6.38ms
2025-06-10 08:30:05,956 INFO 200 GET /devices (0.0.0.0) 2.56ms
2025-06-10 08:35:05,955 INFO 200 GET /devices (0.0.0.0) 2.25ms
2025-06-10 08:39:56,423 INFO 304 GET / (0.0.0.0) 1.60ms
2025-06-10 08:39:56,954 INFO 304 GET /devices (0.0.0.0) 2.26ms
2025-06-10 08:40:01,587 INFO 304 GET /devices (0.0.0.0) 2.54ms
2025-06-10 08:40:05,955 INFO 200 GET /devices (0.0.0.0) 2.56ms
2025-06-10 08:40:06,625 INFO 304 GET /devices (0.0.0.0) 2.61ms
2025-06-10 08:40:08,195 INFO 200 GET /edit?configuration=secrets.yaml (0.0.0.0) 1.74ms
2025-06-10 08:40:08,598 INFO 101 GET /ace (0.0.0.0) 1.44ms
2025-06-10 08:40:08,659 INFO Running command ‘esphome --dashboard -q vscode --ace /config/esphome’
2025-06-10 08:40:11,367 INFO 304 GET /devices (0.0.0.0) 2.22ms
2025-06-10 08:40:16,627 INFO 304 GET /devices (0.0.0.0) 2.53ms
2025-06-10 08:40:22,599 INFO 304 GET /devices (0.0.0.0) 2.66ms
2025-06-10 08:40:28,634 INFO 304 GET /devices (0.0.0.0) 2.21ms
2025-06-10 08:40:34,613 INFO 304 GET /devices (0.0.0.0) 2.25ms
2025-06-10 08:40:40,625 INFO 304 GET /devices (0.0.0.0) 1.59ms
2025-06-10 08:40:46,985 INFO 304 GET /devices (0.0.0.0) 2.27ms
2025-06-10 08:40:54,807 INFO 304 GET /devices (0.0.0.0) 1.93ms
2025-06-10 08:41:04,313 INFO 304 GET /devices (0.0.0.0) 4.32ms
2025-06-10 08:41:11,796 INFO 304 GET /devices (0.0.0.0) 4.48ms
2025-06-10 08:41:24,018 INFO 304 GET /devices (0.0.0.0) 2.79ms
2025-06-10 08:41:32,712 INFO 304 GET /devices (0.0.0.0) 2.69ms
2025-06-10 08:41:41,762 INFO 304 GET /devices (0.0.0.0) 1.40ms
2025-06-10 08:41:53,814 INFO 304 GET /devices (0.0.0.0) 2.60ms
2025-06-10 08:42:02,946 INFO 304 GET /devices (0.0.0.0) 2.51ms
2025-06-10 08:42:12,190 INFO 304 GET /devices (0.0.0.0) 2.03ms
2025-06-10 08:42:20,807 INFO 304 GET /devices (0.0.0.0) 3.97ms
2025-06-10 08:42:33,154 INFO 304 GET /devices (0.0.0.0) 1.03ms
2025-06-10 08:42:42,662 INFO 304 GET /devices (0.0.0.0) 2.26ms
2025-06-10 08:42:49,384 INFO 304 GET /devices (0.0.0.0) 2.25ms
2025-06-10 08:42:56,211 INFO 304 GET /devices (0.0.0.0) 1.84ms
2025-06-10 08:43:05,009 INFO 304 GET /devices (0.0.0.0) 2.70ms
2025-06-10 08:43:10,723 INFO 304 GET /devices (0.0.0.0) 2.72ms
2025-06-10 08:43:20,105 INFO 304 GET /devices (0.0.0.0) 2.61ms
2025-06-10 08:43:25,087 INFO 304 GET /devices (0.0.0.0) 2.22ms
2025-06-10 08:43:31,873 INFO 304 GET /devices (0.0.0.0) 1.78ms
2025-06-10 08:43:43,160 INFO 304 GET /devices (0.0.0.0) 2.60ms
2025-06-10 08:43:54,144 INFO 304 GET /devices (0.0.0.0) 2.71ms
2025-06-10 08:44:03,026 INFO 304 GET /devices (0.0.0.0) 3.11ms
2025-06-10 08:44:15,512 INFO 304 GET /devices (0.0.0.0) 2.31ms
2025-06-10 08:44:27,228 INFO 304 GET /devices (0.0.0.0) 1.91ms
2025-06-10 08:44:38,801 INFO 304 GET /devices (0.0.0.0) 2.11ms
2025-06-10 08:44:46,452 INFO 304 GET /devices (0.0.0.0) 2.43ms
2025-06-10 08:44:56,175 INFO 304 GET /devices (0.0.0.0) 1.02ms
2025-06-10 08:45:05,955 INFO 200 GET /devices (0.0.0.0) 2.65ms
2025-06-10 08:45:06,548 INFO 304 GET /devices (0.0.0.0) 3.21ms
2025-06-10 08:45:18,224 INFO 304 GET /devices (0.0.0.0) 1.78ms
2025-06-10 08:45:26,460 INFO 304 GET /devices (0.0.0.0) 1.01ms
2025-06-10 08:45:34,709 INFO 304 GET /devices (0.0.0.0) 2.26ms
2025-06-10 08:45:40,841 INFO 304 GET /devices (0.0.0.0) 2.55ms
2025-06-10 08:45:51,190 INFO 304 GET /devices (0.0.0.0) 2.97ms
2025-06-10 08:46:03,678 INFO 304 GET /devices (0.0.0.0) 5.08ms
2025-06-10 08:46:11,364 INFO 304 GET /devices (0.0.0.0) 2.23ms
2025-06-10 08:46:25,834 INFO 304 GET /devices (0.0.0.0) 2.54ms
2025-06-10 08:46:36,814 INFO 304 GET /devices (0.0.0.0) 1.38ms
2025-06-10 08:46:43,831 INFO 304 GET /devices (0.0.0.0) 0.96ms
2025-06-10 08:46:50,897 INFO 304 GET /devices (0.0.0.0) 2.13ms
2025-06-10 08:46:58,156 INFO 304 GET /devices (0.0.0.0) 4.92ms
2025-06-10 08:47:04,181 INFO 304 GET /devices (0.0.0.0) 2.37ms
2025-06-10 08:47:11,181 INFO 304 GET /devices (0.0.0.0) 2.99ms
2025-06-10 08:47:26,316 INFO 304 GET /devices (0.0.0.0) 2.62ms
2025-06-10 08:47:35,863 INFO 304 GET /devices (0.0.0.0) 6.11ms
2025-06-10 08:47:43,071 INFO 304 GET /devices (0.0.0.0) 2.71ms
2025-06-10 08:47:50,774 INFO 304 GET /devices (0.0.0.0) 0.97ms
2025-06-10 08:50:05,955 INFO 200 GET /devices (0.0.0.0) 2.60ms
2025-06-10 08:55:05,955 INFO 200 GET /devices (0.0.0.0) 2.63ms
2025-06-10 09:00:05,955 INFO 200 GET /devices (0.0.0.0) 2.60ms
2025-06-10 09:05:05,954 INFO 200 GET /devices (0.0.0.0) 2.28ms
2025-06-10 09:10:05,954 INFO 200 GET /devices (0.0.0.0) 2.29ms
2025-06-10 09:15:05,955 INFO 200 GET /devices (0.0.0.0) 2.66ms
2025-06-10 09:20:05,954 INFO 200 GET /devices (0.0.0.0) 1.98ms
2025-06-10 09:25:05,955 INFO 200 GET /devices (0.0.0.0) 2.66ms
2025-06-10 09:30:05,954 INFO 200 GET /devices (0.0.0.0) 2.32ms
2025-06-10 09:35:05,956 INFO 200 GET /devices (0.0.0.0) 2.86ms
2025-06-10 09:40:05,954 INFO 200 GET /devices (0.0.0.0) 2.15ms
2025-06-10 09:45:05,955 INFO 200 GET /devices (0.0.0.0) 2.62ms
2025-06-10 09:50:05,955 INFO 200 GET /devices (0.0.0.0) 2.64ms
2025-06-10 09:55:05,955 INFO 200 GET /devices (0.0.0.0) 2.70ms
2025-06-10 10:00:05,956 INFO 200 GET /devices (0.0.0.0) 3.08ms
2025-06-10 10:05:05,955 INFO 200 GET /devices (0.0.0.0) 2.61ms
2025-06-10 10:10:05,955 INFO 200 GET /devices (0.0.0.0) 2.57ms
2025-06-10 10:15:05,955 INFO 200 GET /devices (0.0.0.0) 2.62ms
2025-06-10 10:20:05,955 INFO 200 GET /devices (0.0.0.0) 2.57ms
2025-06-10 10:23:30,245 INFO 304 GET /devices (0.0.0.0) 7.51ms
2025-06-10 10:25:05,955 INFO 200 GET /devices (0.0.0.0) 2.58ms
2025-06-10 10:30:05,954 INFO 200 GET /devices (0.0.0.0) 2.20ms
2025-06-10 10:35:05,957 INFO 200 GET /devices (0.0.0.0) 3.46ms
2025-06-10 10:40:05,955 INFO 200 GET /devices (0.0.0.0) 2.65ms
2025-06-10 10:45:05,954 INFO 200 GET /devices (0.0.0.0) 2.26ms
2025-06-10 10:50:05,955 INFO 200 GET /devices (0.0.0.0) 2.64ms
2025-06-10 10:55:05,955 INFO 200 GET /devices (0.0.0.0) 2.61ms
2025-06-10 11:00:05,955 INFO 200 GET /devices (0.0.0.0) 2.29ms
2025-06-10 11:03:24,552 INFO 304 GET / (0.0.0.0) 0.99ms
2025-06-10 11:03:24,792 INFO 304 GET /devices (0.0.0.0) 2.57ms
2025-06-10 11:03:29,789 INFO 304 GET /devices (0.0.0.0) 2.56ms
2025-06-10 11:03:34,776 INFO 304 GET /devices (0.0.0.0) 2.55ms
2025-06-10 11:05:05,954 INFO 200 GET /devices (0.0.0.0) 2.28ms
Update the add-on. You are five months behind.
New installed
[11:43:09] INFO: Starting ESPHome dashboard…
[11:43:09] INFO: Waiting for ESPHome dashboard to come up…
2025-06-10 11:43:10,842 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome…
[11:43:10] INFO: Starting NGINX…
2025-06-10 11:43:11,202 INFO 200 GET /devices (0.0.0.0) 3.15ms
[11:43:11] INFO: Successfully send discovery information to Home Assistant.
2025-06-10 11:43:37,129 INFO 200 GET / (0.0.0.0) 13.90ms
2025-06-10 11:43:37,366 INFO 200 GET /static/fonts/material-icons/material-icons.css?hash=ead4c276 (0.0.0.0) 3.34ms
2025-06-10 11:43:37,452 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2?hash=570eb838 (0.0.0.0) 0.98ms
2025-06-10 11:43:37,649 INFO 200 GET /static/css/esphome-2.css?hash=b92d56a2 (0.0.0.0) 2.85ms
2025-06-10 11:43:37,759 INFO 200 GET /static/js/esphome/index-D2ez82lt.js (0.0.0.0) 11.48ms
2025-06-10 11:43:39,345 INFO 200 GET /devices (0.0.0.0) 2.63ms
2025-06-10 11:43:39,515 INFO 200 GET /static/js/esphome/c.LrLk5ueh.js (0.0.0.0) 43.46ms
2025-06-10 11:43:39,566 INFO 200 GET /static/images/logo-text.svg (0.0.0.0) 0.88ms
2025-06-10 11:43:40,007 INFO 101 GET /compile (0.0.0.0) 1.51ms
2025-06-10 11:43:40,514 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/air-quality.yaml’
2025-06-10 11:43:41,579 INFO Process exited with return code 0
2025-06-10 11:43:42,926 INFO 101 GET /compile (0.0.0.0) 1.21ms
2025-06-10 11:43:46,834 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/bewasserung.yaml’
2025-06-10 11:43:46,945 INFO 200 GET /devices (0.0.0.0) 1.44ms
2025-06-10 11:43:47,115 INFO 200 GET /static/js/esphome/c.CsuD-Bo9.js (0.0.0.0) 5.63ms
2025-06-10 11:43:47,131 INFO 200 GET /static/js/esphome/c.poAaLtz1.js (0.0.0.0) 2.45ms
2025-06-10 11:43:47,150 INFO 200 GET /static/js/esphome/c.DaYIS3VI.js (0.0.0.0) 1.70ms
2025-06-10 11:43:47,170 INFO Process exited with return code 2
2025-06-10 11:43:48,011 INFO 101 GET /compile (0.0.0.0) 1.65ms
2025-06-10 11:43:48,203 INFO Running command ‘esphome --dashboard compile --only-generate /config/esphome/pflanzensensor.yaml’
2025-06-10 11:43:48,213 INFO 200 GET /edit?configuration=bewasserung.yaml (0.0.0.0) 2.59ms
2025-06-10 11:43:48,239 INFO 200 GET /static/js/esphome/monaco-editor/esm/vs/editor/editor.worker.js (0.0.0.0) 1.94ms
2025-06-10 11:43:48,631 INFO 101 GET /ace (0.0.0.0) 0.87ms
2025-06-10 11:43:48,686 INFO Running command ‘esphome --dashboard -q vscode --ace /config/esphome’
2025-06-10 11:43:48,779 INFO 200 GET /static/fonts/codicon.ttf (0.0.0.0) 3.81ms
2025-06-10 11:43:48,818 INFO Process exited with return code 0
[11:44:10] INFO: Service NGINX exited with code 0 (by signal 0)
[11:44:10] INFO: Service ESPHome dashboard exited with code 256 (by signal 15)
[11:44:13] INFO: Starting ESPHome dashboard…
[11:44:14] INFO: Waiting for ESPHome dashboard to come up…
2025-06-10 11:44:14,820 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome…
[11:44:15] INFO: Starting NGINX…
[11:44:15] INFO: Successfully send discovery information to Home Assistant.
2025-06-10 11:44:18,262 INFO 304 GET / (0.0.0.0) 7.02ms
2025-06-10 11:44:18,460 INFO 200 GET /devices (0.0.0.0) 2.76ms
2025-06-10 11:44:23,403 INFO 304 GET /devices (0.0.0.0) 2.57ms
[11:45:11] INFO: Service NGINX exited with code 0 (by signal 0)
[11:45:11] INFO: Service ESPHome dashboard exited with code 256 (by signal 15)
[11:45:15] INFO: Starting ESPHome dashboard…
[11:45:15] INFO: Waiting for ESPHome dashboard to come up…
2025-06-10 11:45:16,089 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome…
[11:45:16] INFO: Starting NGINX…
[11:45:16] INFO: Successfully send discovery information to Home Assistant.
And what version of home assistant are you running?
