Thanks for the response and the example, this is very useful.
Thanks for the example!
I tried this with generic MG 946R servo. With this servo I used idle position 0% and limits 3.5% to 12.5%.
EDIT:
Nevermind, it seems to work again after another upload.
Hi all,
I’ve strange problem with esphome.
I’ve uploaded a configuration to a Wemos d1 mini.
It worked flawless the first time…
now the board works and I can upload new configuration both via usb that via Ota but I get an error when I try to see the logs.
INFO Reading configuration...
File "/usr/local/bin/esphomeyaml", line 11, in <module>
load_entry_point('esphomeyaml', 'console_scripts', 'esphomeyaml')()
File "/opt/esphomeyaml/esphomeyaml/__main__.py", line 505, in main
return run_esphomeyaml(sys.argv)
File "/opt/esphomeyaml/esphomeyaml/__main__.py", line 495, in run_esphomeyaml
return POST_CONFIG_ACTIONS[args.command](args, config)
File "/opt/esphomeyaml/esphomeyaml/__main__.py", line 297, in command_logs
return show_logs(config, args, port)
File "/opt/esphomeyaml/esphomeyaml/__main__.py", line 224, in show_logs
raise ValueError
ValueError
Thanks for any hint
Im tryng to make the servo move with a potentiometer
https://pastebin.com/E8N8TXqc
This only retuns four values 0, 3, 9 and 12
What am i doing wrong?
Me too! This project is amazing and I’m going to move all my ESP devices over to it asap. The one thing which is stopping me at the moment is the ability for my current firmwares to “remember” their state following a power cycle/ restart.
I.e. tasmora does a " DEFAULT the relay(s) will power on with the last saved state on a reboot/restart."
See:
And espurna has a toggle to remember the last light status including colour value.
Is there anyway these can be included? Or find out how they do it?
Check out the gpio switch options in esphome:
restore_mode ( Optional ): Control how the GPIO Switch attempts to restore state on bootup.
RESTORE_DEFAULT_OFF
(Default) - Attempt to restore state and default to OFF if not possible to restore.RESTORE_DEFAULT_ON
- Attempt to restore state and default to ON.ALWAYS_OFF
- Always initialize the pin as OFF on bootup.ALWAYS_ON
- Always initialize the pin as ON on bootup.
yep i saw those, but looks like they relate to GPIO switch only.
There’s an enhancement request on the way…
Does anybody know if its possible to use the restore_mode option with lights (instead of switches) ?
light:
- platform: binary
output: relay
output:
- platform: gpio
pin: GPIO12
I have a sonoff basic configured as above so it is exposed to HA as a light rather than switch, but i can only see the restore_mode option on the switch component.
edit: found a solution after posting
esphome:
on_boot:
priority: 49
then:
- light.turn_on: sonoff_kitchen
platform: ESP8266
board: esp01_1m
board_flash_mode: dout
Not sure if this has been mentioned. I am using the latest version of esphome and have noticed the below since changing over from the older version.
I have 16 relays connected to a single nodemcu esp8276. When i update the nodemcu or restart hass all the relays cycle on then off one at a time, but very quickly, a fraction of a secord. The previous verson of esphome did not do this. How would I prevent this from happening? Can take a video if it makes it easier to see what’s happening.
“latest” and “previous” are not versions.
Latest = 1.11.1
Previous = 1.10.1
I am trying to implement an MPU6050 on my Node MCU. When I get everything going, I have no problem connecting, the 6050 is seen on the I2C bus, and the pins are correctly connected. However, I only get 0 back for all my sensors, and 36.5 back for my temp sensor on it at all times.
Seems in my reading ghat this has to do something with some kind of sleep mode perhaps, but can’t figure out how to turn it off.
My code is below, with the new name changes for v 0.88
Any help that could be offered would be greatly appreciated!
esphome:
platform: ESP8266
board: nodemcuv2
arduino_version: recommended
wifi:
ssid: redacted
password: redacted
manual_ip:
static_ip: redacted
gateway: redacted
subnet: redacted
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
mqtt:
broker: redacted
username: redacted
password: redacted
i2c:
sda: D2
scl: D1
scan: True
- platform: mpu6050
address: 0x68
accel_x:
name: "MPU6050 Accel X"
accel_y:
name: "MPU6050 Accel Y"
accel_z:
name: "MPU6050 Accel z"
gyro_x:
name: "MPU6050 Gyro X"
gyro_y:
name: "MPU6050 Gyro Y"
gyro_z:
name: "MPU6050 Gyro z"
temperature:
name: "MPU6050 Temperature"
Hi everyone ,
Quick question, if I use the native API to set up EspHome is it possible to set up a 2 way switch setup i.e 1 light 2 switch’s ( 3 way in US). I’ve done this in tasmota with mqtt messages on button presses, but is this possible in someway using the API integration?
With HA you can set this quite easy, almost hardware agnostic. Just set an automation that will trigger depending on buttons pressed (can have as many switches as one likes and there is no need for going with 3/4 physical wires to each switch to achieve the same).
- alias: multi way switch
initial_state: 'on'
- platform: state
entity_id: binary_sensor.binary_sensor_1, binary_sensor.binary_sensor_2, binary_sensor.binary_sensor_3
.#actually can use quite a few different type of switches, not necessarily set as binary sensors (but for binary sensors HA will set them to off even if they don't send a different signal)
to: 'on'
- service: light.toggle # service can also be switch.toggle (if the light is controlled by a switch).
entity_id: light.light_a
Thanks for this , now that you have explained it I feel silly not thinking about using HA to automate the process which is pretty obvious .
Appreciate the help though
FWIW, I attempted this and had similar results with the accelerometer/gyro sensor (MPU6050).
