Recently, I realised how little resources are available when it comes to IR codes, I know you can just use an IR-receiver to quickly get these codes but that might not always be the case, e.g. for beginners, if you do not have access to the device, etc. So, taking inspiration from Flipper-IRDB, I took it upon myself to create a little database of my own for ESPHome IR codes in the form of a snippet of the yaml code. I know many would just ask why you can’t just use the codes from Flipper-IRDB, and the problem is not all Flipper Zero and ESPHome codes share a common way of being formatted, which makes it a nightmare for any beginner wanting to use those codes for his project.
It is still a young project and so far I only have a few IR codes from devices I own but if everyone just contributes a little or even helps translate the codes from Flipper-IRDB, it would help a lot:
