If deconz can emulate Merros hub you can try , but normally merros hub give ifttt Apple kit and Alexa and google home Support and addon on hassio I think use Merros api so probably is better you buy hub version and after pairing you try to emulate with deconz
I ordered one to try.
I would not recommend this, it makes alot of noise when opening and closing.
It seems to have A Open Close percentage, if i use it manualy it wil open more as i turn the knob (it feels verry cheap).
as for integrating with home assistant, i managed to bind it to my Zigbee2MQTT but i cant control it.
This might be of the lack of knowledge for HA, i moved to a new home and i used Domoticz in the past.
I can see the Radiator valve in HA it updates when i turn the knob but the responce is slow.
