Ethernet connection issue, Wifi settings not holding
I’ve just set up Home Assistant on a RPi 3B and it boots up just fine. I wasn’t able to access it via the Ethernet connection, so I hooked up a kb/mouse/monitor and started with the CLI. I was able to set up a Wifi connection and I’m able to get into HA from my iPad and iPhone via Wifi.
BUT:
1-Seems like when it reboots, the Wifi settings are lost. How can I make this permanent? I would have thought that Wifi settings could be done via the UI under Settings, but not. [Yes, I would rather use a wired connection but see next question].
2-Ethernet doesn’t want to connect. I have a good connection (lights on the RPi port are what I would expect). Tried a different cable although both are known good cables. Connecting to a switch that my desktop computer is also hard-wired to. Checked my Router and there is no RPi wired connection. I ran “ip addr show” from the CLI and there is no IP4 address for the Ethernet port. See attached screen grab. Any idea why?
Thanks.
Forgot to mention - I set the wifi up as static, both on the HA and in my router. When it reboots, it just doesn’t connect to wifi.
You could rule out the ethernet port by sticking Raspbian on another SD card and booting into that. If the ethernet port is fried it won’t work with that either.
OK, kind of strange answer here.
I ran a regular RPi OS on the board and it also didn’t connect to on the ethernet port. So I tried a crossover cable (I already tried 2 different cables from 2 different manufacturers) and the crossover cable worked!
Then I swapped the HA SD card back in (still with crossover cable) and ethernet is working.
I have the RPi connected to my usual 16 port Linksys switch like all my other wired ethernet devices so I shouldn’t need a crossover cable. But since it’s working, I’m not going to ask why.
Thanks.
