Ethernet does not connect after reboot
I have got ha os running for some time now (several months). Today after a reboot I cannot connect anymore. When connecting to the server I get rtl_rxtx_empty_cond see screenshot. Someone else having the same problems?
It’s installed on a Intel NUC BOXNUC7PJYHN2
I found this solution but pacman is not found and I have no internet connection (external wifi via usb can be a solution for it) Realtek r8186 rtl_rxtx_empty_cond == 0 / Newbie Corner / Arch Linux Forums
I got wifi working but would like to use wired.
Will update if I find a solution
I only use ethernet wherever possible, so my HA is hard waired. However, I’d like to see the resolution here too although my issue might or might not have the same cause. I have different hardware but whenever I have to reboot there si no network connectivity unless there is a second reboot. So for things to work on any reboot it has to be two reboots. Weird. Running a Raspberry Pi 4b 8 Gig RAM with a 1TB SSD (no MicroSD):
System Information
version core-2023.3.5
installation_type Home Assistant Supervised
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.10.10
os_name Linux
os_version 5.10.0-21-arm64
arch aarch64
timezone America/New_York
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 5000
Installed Version 1.31.0
Stage running
Available Repositories 1316
Downloaded Repositories 22
AccuWeather
can_reach_server ok
remaining_requests 47
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Debian GNU/Linux 11 (bullseye)
update_channel stable
supervisor_version supervisor-2023.03.1
agent_version 1.4.1
docker_version 23.0.1
disk_total 915.4 GB
disk_used 17.9 GB
healthy true
supported true
supervisor_api ok
version_api ok
installed_addons AppDaemon (0.11.0), Core DNS Override (0.1.1), Duck DNS (1.15.0), File editor (5.5.0), Home Assistant Google Drive Backup (0.110.1), Log Viewer (0.14.0), Mosquitto broker (6.1.3), Samba share (10.0.0), Terminal & SSH (9.6.1), AdGuard Home (4.8.3)
Dashboards
dashboards 5
resources 15
views 29
mode storage
Recorder
oldest_recorder_run February 19, 2023 at 6:50 PM
current_recorder_run March 21, 2023 at 10:02 PM
estimated_db_size 1882.71 MiB
database_engine sqlite
database_version 3.38.5
