Hi guys,
I’m running around with frustrated thoughts on this eufy issue. I’ve got all the integrations right, installed in serveral different ways.
I had it working on p2p which was so slow I almost needed to wait 1 minute for the stream to be active. Once it was active it would freeze after 30/40 seconds. So I thought let’s try it with rtsp but this never worked, beter to worst, it did something with the doorbel camera.
Let me explain it.
The camera has a couple different statuses regarding streaming. (Idle, preparing and streaming)
Before I tried to stream it through rtsp it worked with p2p. When hitting start streaming p2p the status would change from idle to preparing to streaming. Once I clicked stop streaming it would stop the stream and sets the camera in idle again…
Now, since my tinkering around with the rtsp, when I hit stream with p2p it goes from idle to preparing and stays there stuck. It does go back to idle when I hit stop stream but it will never go to status streaming.
I’ve googled the h*ll out of it and try different couple of solutions but nothing worked. Changed settings in the eufy app and try different combination from settings hoping it would play again.
I reinstalled HA and fully reset my camera and integrations.
My question is, is there some one who has to same problem, and maybe got it solved in some magical way? I’m going nuts at the moment not know what to do next to get it back to work.
Hope someone can help!
