Eufy Security Integration
@benm7
Perhaps below is useful for you? The turn_on / turn off switch with device ids turns on the spotlight. This is optional
I take this snap to check if the container is out on trash day. If not it sends a reminder. Light is turned on to distinguish green and grey (although not yet implemented)
alias: LLM check
description: ""
triggers: []
conditions: []
actions:
  - action: eufy_security.start_rtsp_livestream
    metadata: {}
    data: {}
      entity_id:
        - camera.front_yard_garage
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
  - type: turn_on
    device_id: 5017dff2d2b001762e55b13b62f2da05
    entity_id: df3f6b61c781a8ebcd28540ed1da722e
    domain: switch
  - action: camera.snapshot
    metadata: {}
      filename: /config/www/front_snapshot.jpg
      entity_id:
  - action: eufy_security.stop_rtsp_livestream
    metadata: {}
    data: {}
      entity_id:
  - type: turn_off
    domain: switch
  - action: llmvision.image_analyzer
      provider: 01JK47MAF4T772ZG4RWSF29365
      message: how many containers do you see? Just give me an integral number.
      image_file: /config/www/front_snapshot.jpg
      max_tokens: 5
      temperature: 0.2
      include_filename: false
      use_memory: false
    response_variable: response
mode: single
Hi Team,
Does anyone have a fix for the Eufy Doorbell Battery %age not updating? My integration shows 100%, the doorbell is actually at 39%.
thanks in advance
Update: Got it working. I also didn’t read that we need to install the add-on and the custom component integration. Though the error below still exist and there is post about it. Not sure what it breaks as this is my first Eufy integration use.
Hello. I just received the Eufy S120. Prior to purchasing it, I breifly viewed the supported device list and the S120 is supported. However, I failed to read deeply and saw a post saying the supported device needs to match the model number and not device name. My device model is T81A. Am I sol??
Supported:
Solar Wall Light Cam S120 (T84A0)
I’ve installed the eufy security addon. Started and the log shows this error but it does see my device. Frankly, I am not sure what entities shows up in Ha if it does work. Right now, there is no entity at all. I have not install the webrtc yet though, I don’t think this matter since no entity is showing up related to the camera device.
log:
2025-06-03 08:17:33.003 INFO eufy-security-ws Eufy Security server listening on host 0.0.0.0, port 3000
2025-06-03 08:17:39.269 ERROR eufy-security-ws:eufy-security-client [push] [PushNotificationService.registerGcm] Register GCM - Status return code not 200 {
status: 400,
statusText: 'Bad Request',
data: 'Error=Invalid argument for the given fid.'
2025-06-03 08:17:39.273 ERROR eufy-security-ws:eufy-security-client [push] [PushNotificationService.registerGcm] Register GCM - Generic Error {
error: {
cause: undefined,
message: 'RegisterGcmError: Google register to GCM failed',
context: {
status: 400,
stacktrace: 'RegisterGcmError: Google register to GCM failed\n' +
' at PushNotificationService.registerGcm (/usr/src/app/node_modules/eufy-security-client/build/push/service.js:378:27)\n' +
' at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n' +
' at async /usr/src/app/node_modules/eufy-security-client/build/push/service.js:240:41\n' +
' at async PushNotificationService.loginPushCredentials (/usr/src/app/node_modules/eufy-security-client/build/push/service.js:238:16)\n' +
' at async PushNotificationService._open (/usr/src/app/node_modules/eufy-security-client/build/push/service.js:722:32)\n' +
' at async PushNotificationService.open (/usr/src/app/node_modules/eufy-security-client/build/push/service.js:768:13)'
2025-06-03 06:16:15.581 INFO eufy-security-ws:eufy-security-client [http] [Station.onConnect] Connected to station T81Axxxxx on host 192.168.1.161 and port 24468
2025-06-03 06:17:25.588 INFO eufy-security-ws:eufy-security-client [http] [Station.onDisconnect] Disconnected from station T81Axxxxx
2025-06-03 06:18:07.367 INFO eufy-security-ws:eufy-security-client [http] [Station.onConnect] Connected to station T81Axxxxx on host 192.168.1.161 and port 28007
2025-06-03 06:18:40.205 INFO eufy-security-ws:eufy-security-client [p2p] [Timeout._onTimeout] Initiated closing of connection to station T81Axxxxx for saving battery.
2025-06-03 06:18:40.206 INFO eufy-security-ws:eufy-security-client [http] [Station.onDisconnect] Disconnected from station T81Axxxxx
2025-06-03 06:20:12.168 INFO eufy-security-ws:eufy-security-client [http] [Station.onConnect] Connected to station T81Axxxxx on host 192.168.1.161 and port 20759
2025-06-03 06:20:43.743 INFO eufy-security-ws:eufy-security-client [p2p] [Timeout._onTimeout] Initiated closing of connection to station T81Axxxxx for saving battery.
2025-06-03 06:20:43.744 INFO eufy-security-ws:eufy-security-client [http] [Station.onDisconnect] Disconnected from station T81Axxxxx
2025-06-03 06:21:34.499 INFO eufy-security-ws:eufy-security-client [http] [Station.onConnect] Connected to station T81Axxxxx on host 192.168.1.161 and port 14036
2025-06-03 06:22:06.753 INFO eufy-security-ws:eufy-security-client [p2p] [Timeout._onTimeout] Initiated closing of connection to station T81Axxxxx for saving battery.
2025-06-03 06:22:06.754 INFO eufy-security-ws:eufy-security-client [http] [Station.onDisconnect] Disconnected from station T81Axxxxx
2025-06-03 06:23:40.020 INFO eufy-security-ws:eufy-security-client [http] [Station.onConnect] Connected to station T81Axxxxx on host 192.168.1.161 and port 25697
2025-06-03 06:24:11.785 INFO eufy-security-ws:eufy-security-client [p2p] [Timeout._onTimeout] Initiated closing of connection to station T81Axxxxx for saving battery.
2025-06-03 06:24:11.786 INFO eufy-security-ws:eufy-security-client [http] [Station.onDisconnect] Disconnected from station T81Axxxxx
2025-06-03 06:25:23.970 WARN eufy-security-ws:eufy-security-client [p2p] [Timeout._onTimeout] Tried all hosts, no connection could be established to station T81Axxxxx.
2025-06-03 06:25:23.971 INFO eufy-security-ws:eufy-security-client [http] [Station.onTimeout] Timeout connecting to station T81Axxxxx
2025-06-03 06:25:34.117 INFO eufy-security-ws:eufy-security-client [http] [Station.onConnect] Connected to station T81Axxxxx on host 51.21.93.39 and port 14606
2025-06-03 06:26:09.681 INFO eufy-security-ws:eufy-security-client [p2p] [Timeout._onTimeout] Initiated closing of connection to station T81Axxxxx for saving battery.
2025-06-03 06:26:09.682 INFO eufy-security-ws:eufy-security-client [http] [Station.onDisconnect] Disconnected from station T81Axxxxx
Hey guys. I acquired the Eufy S120 due to the light and solar panel feature. It seems the light does not stay on indefinitely when I toggle it from HA. It shuts off in less then a minute and the state in HA stays as on even thought the light has been turned off.
From the app, the light stay on when toggle on. However, the light will turn itself off if the app goes to sleep or if I browse other features within the eufy app. How can I have the light stays on until I toggle it off??
I have exactly the same problem. Were you able to solve it?
This thread seems to be going all over the place, so I apologize for adding to the chaos. I have an Eufy C210 T8502 lock and I had the integration working for a little while. But, I was only able to get the entity “Update” from the lock. Ideally, I would like to simply monitor (and control, in a perfect scenario) the lock status (locked, unlocked) and possibly the battery level would be nice to know.
Recently, I tried to reinstall the add-on/integration and now I’ve broken it altogether. I deleted and re-added the host but now all I get is a request for captcha authorization. When I type in the captcha it says “Code is received…*” after a minute or so and then goes right back into error state. According to GitHub, the T8502 is supported but I am struggling to get the integration to work. Any help is most appreciated.
Hi Guys loving the integration and had it running locally fine but trying to connect to cameras with homebase abroad and keep getting this error after the stream starts.
Infinite loop detected (limit >= 1000) during parsing of p2p message
Any ideas why?
I have several eufy3 solar cans and eufy doorbell and
homebase3 and no luck setting it to work properly with this integration (tried homebridge as same results). Usually I’m getting some old events and camera feed works 1% of the time.
did you ever get your stream working?
I can’t find a way to get the stream for the E340 / T8214 doorbell working at all.
Latest error I get is mse:stream codes not matched
and mse: wrong response on DESCRIBE
Any help is appreciated, I don’t know where to look anymore.
Same hete
Any help is greatly appreaciated
I have a new specific problem with this integration, which might be caused by some eufy firmware update changes:
I have a door sensor which is configured NOT to give a push notification within the eufy app. The eufy-security-ws runs with it’s own eufy account which has access to my home.
Since a few weeks, the sensor does not update within HomeAssistant when the door is opened. When I change the sensor to give a push notification in the eufy App, the integration recognizes state changes for the sensor instantly.
When I change the push notification setting for the sensor, it is changed globally for all accounts which have access to the home. However, I would not like to receive push notifications for this specific sensor, but I would like to trigger my HomeAssistant automation by it (to start a light show when the door opens, inside the house).
Is this because eufy changed something on their end?
Can you please share the code you used to get the Eufy cam 2 pro streaming in HA? I have these cams but dont get them streaming.
hi all, I will be releasing a major change soon;
  1. I will try to contribute to eufy-security-ws with two new functions start_go2rtc_stream and stop_go2rtc_stream, so all video generation will be handled inside add-on (or app) and home assistant will only consume the video URL from go2rtc. this will also enable audio generation. I always felt that, home assistant based video generation is too fragile. so, we do not need to carry the video/audio bytes from add-on to home assistant anymore, it will be tackled at source.
  2. I also need to update the integration to comply with these new two functions. I want to deprecate HA based video handling at all, so I would prefer to remove all references of it.
From end user perspective, if p2p based live stream was working for you and you are just interested in getting RTSP url and streaming inside HA, nothing will change for you. If you were somehow interested in bytes (??), I would not keep them inside HA anymore.
If the p2p based live stream was not working for you at all, it is a different problem and I am too tired to debug further cases.
Please raise any concerns.
Great to get your feedback here.
Is this then related to the custom go2rtc and or the HA internal one? Or completely not related to this?
Sorry for the question, but I didn’t understand the WebRTC Camera goto2rtc and the goto2rtc which is now in HA and if I have now two installed or have better to do this and that to only use the internal or only the external, …
If you install go2rtc standalone, webrtc will use it.
If there is no go2rtc, webrtc will download and run it in the background.
For the integration, it doesn’t matter as long as one of them is up and running and available through default port (should be 1984).
Still not get it.
What do you mean with “install standalone”. This was my question. It is already in HA since 2024.11 per default existing and enabled, sin’t it.
So no, not installed (myself) standalone, but already there from HA. Different to before.
So I should deinstalling the webrtc integration (what would deinstall the go2rtc server, installed by webrtc before? And install again and only then it is using the inbuild one?
But then I read the the inbuild is using 11984, etc. and I’m lost again.
I remember that I have already answered that question back then, do you have a new question on top?
Feel free to rephrase it.
Either I didn’t understand or didn’t see it back than. But o.k. then I will stay without an anther to that.
What a great idea!
Generating P2P streams from HA Eufy to GO2RTC puts too much load on Home Assistant when running in container mode.
I have Frigate with GO2RTC integrated. If I could generate streams directly from Eufy WS to GO2RTC, I could integrate them into Frigate and, if needed, into Home Assistant without affecting Home Assistant!
I searched now again you docs and the discussion in your repo and this thread and still don’t get how the integration would work with the inbuild go2rtc, which is in HA now and the inbuild webrtc which is in HA now.
Your install doc is still only refering to the seperated installations and I dont find the items, which you remember where you have answered that questions back then. Might it be possible to point me to them?
