I see that your device looks supported. You should create an issue under this repository GitHub - bropat/eufy-security-client: This shared library allows to control Eufy security devices by connecting to the Eufy cloud servers and local/remote stations over p2p.
I think thats still strange, cause it worked before.
So we dont get any pictures with the eufy can 2C
Although it worked before
I was able to understand this better now.
Picture URL is correct, data is flowing from source to target. Home assistant is calling eufy servers to fetch the picture but not able to fetch it because of http1.1 vs http2 thingy.
I will double check in integration if i can fetch the picture using http2.0. on the other hand, i have 4 unit of 2c cameras and not having this issue, so it is not generic.
I see that existing python libraries inside home assistant (aiohttp and requests) do not support http2 requests yet. I donāt know how and why your camera picture is served over http2 protocol, but, i donāt have a very straightforward solution for you.
Any thoughts on this question?
I would very much like to access my custom quick responses through HA, but when I choose for ID 4, 5 or 6 in the scripts it does not return anything. 1, 2, and 3 work perfectly fine!
Mmm already thank you for even investigating it.
Is there a way to force it over http1 then?
If not, are you willing to request inside HA to support http2
Or can bropat try to only accept 1.0
I dunno all this is above my skill
I dunno why it worked before either
You say you have 4x cams 2c why dont you have it then?
And is the other person here in this topic, having the same issue as i (he was willing to share his cam)
- add on is reading states and events and handling it over to listeners
- integration connetcs to add on to listen
PictureUrl is correctly moving around but to download image from this address, the call has to be made with http2 supporting library which i havenāt found yet. I checked the ones i am aware and there is no support, so it is not about home assistant, add on or integration, we need a library to support http2 calls. Eufy had changed their backend to accept only http2 calls, it would eventually fail if you stick with older add on versions.
So, sharing devices would not help until i find one library supports http2. I will continue investigating this but do not hope a lot.
Can you create a request in repository so i can expose this as a user control rather than you call scripts directly
Done, thanks!
Maybe, it is time to request a sensor for last updated at
? Just create github issue if you think many users will get benefit with this
Guess it all depends on what ālast changedā timestamp @mht2k wants. The solution above allows for any of the timestamps to be usedā¦
Is it possible to list the last events, mimicking the EufyCam mobile app, in Home Assistant, with this integration?
I have the integration set up, and its working well btw!
Hey, i donāt think HA is a good or suitable environment to record and present these. Do you have anything your mind about UI and benefit? As all these events should be captured by motion sensors etc?
Ahoi @anon63427907 I try to follow your eufy_security installation guide on github and I get stucked on point 6.3.3 - Install the Eufy Secucirty
repository.
After I click on the added Eufy Security
repository, HACS start endless loading. Inside the browser console (F12) there is no hint why. I have no idea how can I solve that issue.
This looks like a problem between home assistant -HACS and GitHub. You can always manually install the integration while copying latest release files into custom_components folder.
Later on, without any change (maybe a restart), it works fine. Sorry for the wrong alert. No I try to create some simple automations with the Eufy 2k Doorbell (Wired). A lamp should switch on, when someone is ringing. Atm I donāt get it to work. It seems the ring event get not register by HA. Are there examples about eufy device automations?
alias: doorbell_ringing
description: turn light red if door bell ringing
- type: turned_on
platform: device
device_id: 6d8b
entity_id: binary_sensor.doorbell_ringing_sensor
domain: binary_sensor
condition: []
- type: turn_on
device_id: 1a57
entity_id: light.livarno_lamp_level_light_color_on_off
domain: light
flash: long
brightness_pct: 80
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
- type: turn_off
device_id: 1a57
domain: light
mode: single
Please check integration configuration options page if you had enabled binary sensor fix yes, we have an option for a fix
@anon63427907 and bropat,
First merry christmas to all of you (also the rest of this forum offcourse) and best wishes !
Bropat is pointing out a http2 library here, is that an option?
Merry Christmas to you too and all.
I will work on this, thanks for reminding me.
