@anon63427907 now the integration works well. Thanks for all so far!
I test the following setup:
device
ringing
flash light
motion detection
person detection
eufy doorbell 2k wired
eufy floodlight cam 2 pro
mean I was not able a register a state switch in Home Assistent. For motion/person detection I modify the settings of eufy floodlight cam 2 pro (detect persons/detect all motions). I can confirm that the camera it self detect each event successfully (see screenshot).
Is it possible that the integration do not support the eufy floodlight cam 2 pro?
I work as a software developer, if I could help you (at least with testing) to improve the integration, let me know.
@Nusserdt I don’t think that the Eufy floodlight cam 2 pro is supported yet.
fuatakgun’s integration finds my floodlight cam 2 pro, but apart form turning the light on and off (which actually works), I cannot start RTSP, there is no streaming and no events are coming from the camera.
Yes to all, just need couple of days to release the new version. Having some family time I always test every new version locally before releasing it, i don’t want to skip it.
In Lovelace, the cameras update just fine on regular motion detection, and show me an image from the latest motion detected!
The issue I’m facing is that when checking history of all the binary sensors for a specific camera, while using the Home alarm setting, attached above, no binary sensors inside home assistant show any change, despite there had been a motion.
Could someone shed some light on this matter?
I’m thinking that at least the streaming sensor should been enabled upon motion?
Hi @anon63427907 ,
I think I need help. I’m trying to setup Frigate to record events.
Using the same RTSP proxy you are using should be fine.
Sadly I can’t find out the correct “path” for my cameras that it expose.
Can you help me?
But in Home Assistant, none of the binary sensors that derive from that camera has triggered.
Every binary sensor shows zero change during 10-12, se below.
Check the screenshot you had posted (Eufy Security Integration - #430 by KaherdinTristan), push notifications are not enabled. If push notifications are not enabled, most sensors would not work, yes, in your case, it is expected
Ok. Thanks.
I understand the correlation between the push notification in the app settings, and that it is this specific push notification that triggers binary sensors.
Just one question; Since the cameras update their “last recorded image” (or is it called entity_picture maybe?), could that be used to trigger some binary sensor?
The goal here for me is to have Home Assistant to see (binary_sensor update) when the camera has detected motion, without having the notification on all the phones connected to this account (wife, kids, etc).
@anon63427907 , I have started to migrate to your awesome solution from the “old” iobroker one. but I wonder why there is no service call to set alarm_home. is that by design?
