Eurotronic Z-Wave-Plus loses connection
I’ve running Home-Assistant (HassOS 3.11) on an Raspberry 3b+ with the Z-Wave USB Stick ZMEEUZB1.
Everything worked well for weeks but now the Eurotronic seems to loses the connection when I don’t use it. So then I have to power it on manually (the Eurotronic has an Power Button for full heat for 5 minutes). After that I see the connection icon on the display of the Eurotronic and I can also change heat modes with home-assistant. But after a while the connection icon on the Eurotronic is gone and I can not change heat modes or anything with home-assistant.
Does anyone has an idea or same problem?
