[EV Charger] ABB Terra AC Wallbox - Modbus RS485
ABB Terra AC EV Charger Modbus RS485 RTU Bridge - FULL LOCAL HA Control
Tags: esphome modbus ev-charger esp32 rs485 abb
Overview
ABB Terra AC Wallbox chargers future multiple wired and wireless interfaces but communication protocols differ for each interface,
  1. Ethernet / Wifi can be used for ABB chargersync app. (connection is actually OCPP to ABB’s server)
  2. My charger model is without LCD, I’ve read here on the forum that it doesn’t support - Modbus TCP, didn’t bother to check that.
  3. My charger model has 4G daughter board, located on top of main board.
The charger supports Modbus RTU over RS485, so I built a small ESP32-based bridge that translates Modbus into ESPHome’s native API. Total hardware cost: under $5.
The result: real-time voltage, current, power and session energy readings, plus full start/stop/current-limit control, all appearing as native HA entities.
Hardware
Component Notes
ESP32 (any devkit) I used a generic ESP32-WROOM-38pin
HW-519 RS485 module Powered from ESP32 3.3V
DCDC 5V Leeched 12V from 4G daughter board supply
Wiring:
ESP32 GPIO17 (TX) → HW-519 TX (yes it's not a mistake - TX)
ESP32 GPIO16 (RX) → HW-519 RX (yes it's not a mistake - RX)
HW-519  A+ → ABB Terra A
HW-519  B- → ABB Terra B
Power:
Direct solder to 4G board header (need to take out from charger for soldering)
12V (4G Board) → JST Conn. (W2W) → DCDC 5V → ESP32 5V Input
HW-519 powered from ES32 3.3V pin
The ABB Terra exposes an RS485 port on its internal terminal block — refer to the Terra AC Installation Manual for the exact terminal numbers.
What It Exposes in HA
Sensors
Entity Register Notes
Voltage L1/L2/L3 0x4016–0x401A 0.1V resolution
Current L1/L2/L3 0x4010–0x4014 0.001A resolution
Active Power 0x401C Watts
Session Energy 0x401E Wh, resets each session
Active Current Limit 0x400E Charger’s actual applied limit
Max Hardware Current 0x4006 Set via Terra Config app
Modbus Error Code 0x4008 0 = no error
Charger Status 0x400C Decoded text + binary sensor
Controls
Set Charging Current Limit 0x4100 Slider 6–16A, sends mA to charger
Start Charging 0x4105 Writes 0
Stop Charging 0x4105 Writes 1
Binary Sensors
Entity Notes
Charging at Rated Current True = full power, False = throttled
ESPhome YAML file:
esphome:
  friendly_name: abb-terra-bridge
  on_boot:
    priority: -100
    then:
      - number.set:
          value: 8    # ← 8A default on boot, writes 8000 to 0x4100
esp32:
  board: esp32dev
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32_BROWNOUT_DET: "y"
logger:
  level: DEBUG # Change to VERBOSE if you need to see raw Modbus hex bytes
  baud_rate: 0
api:
  encryption:
    key: "YOURKEY"
ota:
  - platform: esphome
    password: "YOUROTAPASS"
wifi:
  ssid: !secret YOURWIFI_SSD
  password: !secret YOURWIFI_PASS
  ap:
    ssid: "Abb-Terra-Bridge"
    password: "YOUR_AP_PASS"
captive_portal:
# Built-in ESPHome web UI (shows all entities)
web_server:
  port: 80
  include_internal: true
  local: true
# --- ABB BRIDGE LOGIC STARTS HERE ---
uart:
  tx_pin: GPIO17
  rx_pin: GPIO16
  baud_rate: 9600
  data_bits: 8
  parity: EVEN
  stop_bits: 1
modbus:
  uart_id: mod_bus_uart
modbus_controller:
  - id: abb_charger
    address: 1
    modbus_id: modbus_bus
    update_interval: 10s
  # --- WiFi link quality (for web/debug) ---
  - platform: wifi_signal
    name: "WiFi Signal (dBm)"
    device_class: signal_strength
    update_interval: 30s
    name: "WiFi Signal (%)"
    unit_of_measurement: "%"
    accuracy_decimals: 0
    lambda: |-
      if (isnan(id(wifi_rssi).state)) return NAN;
      float rssi = id(wifi_rssi).state;   // in dBm
      // Map -100..-50 dBm to 0..100% (clamped)
      if (rssi <= -100) return 0;
      if (rssi >= -50)  return 100;
      return (int) (2 * (rssi + 100));
    # Optional smoothing to avoid jitter:
    filters:
      - sliding_window_moving_average:
          window_size: 5
          send_every: 1
  # --- Diagnostic Data ---
  - platform: modbus_controller
    modbus_controller_id: abb_charger
    name: "Max Hardware Current"
    address: 16390
    register_type: holding
    value_type: U_DWORD
    filters:
      - multiply: 0.001
    unit_of_measurement: "A"
    entity_category: diagnostic
    name: "Modbus Error Code"
    icon: "mdi:alert-circle"
    address: 16392
    value_type: U_DWORD
  # --- Charging Status ---
    name: "Raw Charging State"
    address: 16396
    value_type: U_DWORD
    internal: true # Hide this from HA once the templates work
    icon: "mdi:ev-station"
    internal: true
    lambda: |-
      return (uint32_t)id(raw_charging_state).state & 0xFF;
    name: "Active Current Limit"
    address: 16398
    value_type: U_DWORD
    filters:
      - multiply: 0.001
  # --- Phase Currents ---
    icon: "mdi:current-ac"
    address: 16400
    value_type: U_DWORD
    filters: { multiply: 0.001 }
    accuracy_decimals: 3
    address: 16402
    value_type: U_DWORD
    address: 16404
    value_type: U_DWORD
  # --- Phase Voltages ---
    icon: "mdi:lightning-bolt"
    address: 16406
    value_type: U_DWORD
    filters: { multiply: 0.1 }
    unit_of_measurement: "V"
    accuracy_decimals: 1
    address: 16408
    value_type: U_DWORD
    address: 16410
    value_type: U_DWORD
  # --- Power and Energy ---
    icon: "mdi:flash"
    address: 16412
    value_type: U_DWORD
    unit_of_measurement: "W"
    icon: "mdi:battery-charging"
    address: 16414
    value_type: U_DWORD
    unit_of_measurement: "Wh"
# --- User Control Interace ---
number:
    name: "Set Charging Current Limit"
    icon: "mdi:ev-plug-type2"
    address: 16640          # 0x4100 — Set Charging Current Limit (ABB manual §5.13)
    register_type: holding  # ← required, was missing
    value_type: U_DWORD     # size 2, resolution 0.001 A per ABB manual
    min_value: 6            # IEC 61851-1 minimum (ABB manual §5.13)
    max_value: 16           # adjust to your breaker / Max HW current
    step: 1
    multiply: 1000          # HA sends amps, charger expects mA (e.g. 16A → 16000)
    use_write_multiple: true  # U_DWORD = 2 registers → forces FC16
    skip_updates: 2147483647    # ← this is the correct param for number
output:
    address: 16645        # 0x4105 — Start/Stop register (ABB manual §5.15)
    value_type: U_WORD    # Size 1 register per ABB manual
    write_lambda: |-
      // x is the float passed in from output.set_level (0.0 or 1.0)
      // We write it directly as uint16_t: 0 = Start, 1 = Stop
      payload.push_back((uint16_t)x);
      return x;
button:
    name: "Start Charging"
    icon: "mdi:play"
    on_press:
      - output.set_level:
          level: 0.0      # 0 = Start session (ABB manual §5.15)
    name: "Stop Charging"
    icon: "mdi:stop"
    on_press:
      - output.set_level:
          level: 1.0      # 1 = Stop session (ABB manual §5.15)
text_sensor:
    name: "Charger Status Description"
    icon: "mdi:information-outline"
    lambda: |-
      // Isolate Byte 0 (Bits 0-7) as defined in manual section 5.6
      int state_val = (int)((uint32_t)id(raw_charging_state).state & 0xFF);
      switch (state_val) {
        case 0:
          return {"State A: Idle"};
        case 1:
          return {"State B1: Plugged In (Pending Auth)"};
        case 2:
          return {"State B2: Plugged In (Ready)"};
        case 3:
          return {"State C1: EV Ready (S2 Closed)"};
        case 4:
          return {"State C2: Charging (Energy Delivering)"};
        case 5:
          return {"Others/Transitional"};
        default:
          return {"Unknown State"};
binary_sensor:
    name: "Charging at Rated Current"
    icon: "mdi:speedometer"
    device_class: power         # shows as On/Off with power icon in HA
    lambda: |-
      uint8_t byte1 = ((uint32_t)id(raw_charging_state).state >> 8) & 0xFF;
      return ((byte1 >> 7) & 1) == 0;   // true = at rated current, false = throttled
Installation pictures:
References
