EVCC Add-on is running but shows that it is not
Hi
After starting the EVCC add-on the UI could not be opened. The message is shown:
Add-on is not running. Please start it first
But I can open the log and following text is shown:
Using config file: /config/evcc.yaml
starting evcc: ‘EVCC_DATABASE_DSN=/data/evcc.db evcc --config /config/evcc.yaml’
[main ] INFO 2023/04/16 17:14:29 evcc 0.116.2
[main ] INFO 2023/04/16 17:14:29 using config file: /config/evcc.yaml
[main ] INFO 2023/04/16 17:14:29 starting ui and api at :7070
[mqtt ] INFO 2023/04/16 17:14:29 connecting evcc-641671617 at tcp://192.XXX.XXX.XXX:1883
[site ] INFO 2023/04/16 17:14:30 site config:
[site ] INFO 2023/04/16 17:14:30 meters: grid ✓ pv ✓ battery ✓
[site ] INFO 2023/04/16 17:14:30 grid: power ✓ energy ✓ currents ✓
[site ] INFO 2023/04/16 17:14:30 pv 1: power ✓ energy ✓ currents ✗
[site ] INFO 2023/04/16 17:14:30 battery 1: power ✓ energy ✓ currents ✗ soc ✓ capacity ✗
[site ] INFO 2023/04/16 17:14:30 vehicles:
[site ] INFO 2023/04/16 17:14:30 vehicle 1: range ✗ finish ✗ status ✗ climate ✗ wakeup ✗
[lp-1 ] INFO 2023/04/16 17:14:30 loadpoint 1:
[lp-1 ] INFO 2023/04/16 17:14:30 mode: off
[lp-1 ] INFO 2023/04/16 17:14:30 charger: power ✓ energy ✓ currents ✓ phases ✗ wakeup ✗
[lp-1 ] INFO 2023/04/16 17:14:30 meters: charge ✓
[lp-1 ] INFO 2023/04/16 17:14:30 charge: power ✓ energy ✓ currents ✓
[lp-1 ] DEBUG 2023/04/16 17:14:30 phase timer inactive
[lp-1 ] DEBUG 2023/04/16 17:14:30 pv timer inactive
[lp-1 ] DEBUG 2023/04/16 17:14:30 guard timer inactive
[site ] DEBUG 2023/04/16 17:14:30 ----
[lp-1 ] DEBUG 2023/04/16 17:14:30 charge power: 0W
[site ] DEBUG 2023/04/16 17:14:31 pv power: 449W
[site ] DEBUG 2023/04/16 17:14:34 battery soc: 90%
[site ] DEBUG 2023/04/16 17:14:34 battery power: -23W
[site ] DEBUG 2023/04/16 17:14:34 grid power: 6W
[site ] DEBUG 2023/04/16 17:14:37 grid currents: [-0.64 -0.56 1.09]A
[site ] DEBUG 2023/04/16 17:14:41 site power: -707W
[lp-1 ] DEBUG 2023/04/16 17:14:41 charge currents: [0 0 0]A
[lp-1 ] DEBUG 2023/04/16 17:14:41 charge meter total import: 4163.198kWh
[lp-1 ] DEBUG 2023/04/16 17:14:41 charger status: A
[lp-1 ] INFO 2023/04/16 17:14:41 car disconnected
[site ] DEBUG 2023/04/16 17:14:41 ----
[lp-1 ] DEBUG 2023/04/16 17:14:41 charge power: 0W
[site ] DEBUG 2023/04/16 17:14:42 pv power: 450W
[site ] DEBUG 2023/04/16 17:14:44 battery soc: 90%
[site ] DEBUG 2023/04/16 17:14:44 battery power: -18W
[site ] DEBUG 2023/04/16 17:14:45 grid power: 9W
[site ] DEBUG 2023/04/16 17:14:48 grid currents: [-0.64 -0.56 1.09]A
[site ] DEBUG 2023/04/16 17:14:49 site power: -699W
[lp-1 ] DEBUG 2023/04/16 17:14:49 charge currents: [0 0 0]A
[lp-1 ] DEBUG 2023/04/16 17:14:49 charge meter total import: 4163.198kWh
[lp-1 ] DEBUG 2023/04/16 17:14:49 charger status: A
[site ] DEBUG 2023/04/16 17:14:50 ----
[lp-1 ] DEBUG 2023/04/16 17:14:50 charge power: 0W
[site ] DEBUG 2023/04/16 17:14:50 pv power: 453W
Obviously the app was started correctly and is also running safely in the background, as I also have access to my inverter via the modbus in EVCC. Otherwise I could not see any data of the inverter in HA.
The whole problem only arose after the last upgrade to HA core 2023.4.4. With the upgrade, I could no longer start both evcc and the solar add-on (Hauwei). After a restore with the backup, the add-ons are running again but I can no longer operate EVCC.
Does anyone have an idea how I can solve this problem?
THX Lars
Problem solved… no idea why, but suddenly add on is reachable again.
